PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. Want Opinion's
  2. Just can't seem to get that ride back...
  3. Holy goabs of torque batman!!!! And less pinging too!!!!
  4. Did you buy the S&S/JBrady Headers?
  5. 93 LS400 starter clunk noise
  6. 1991 LS 400 radio system is a mystery!
  7. heavy rear end vibration
  8. Got the windvisors from luxurymods, need help can't read japanese.
  9. Car Stolen and Damaged. Need some help
  10. AC fans not kicking in...where's the sensor switch located?
  11. my 1991 LS mod's and info/common probs fixed
  12. Power steering SHOT?:(
  13. Clicking coming from front suspension when turning slowly
  14. Noltec Bushes in Aus
  15. Major Electrical Please Help !!!!!!
  16. DIY - Cheaper and BETTER alternative to Exact mats (clear mats)
  17. PureDrifter appreciation thread
  18. 93 LS400: Air Intake Hose Cost?
  19. Changes, changes, changes....HELP!!
  20. Changes, changes, changes....
  21. Running Power wire on a 2nd gen LS
  22. Front end clunk
  23. Bumper cover Smashed by Jackrabbit
  24. 96 LS Clock & Climate control dead????
  25. cold-air Intake mods for 93-94Ls
  26. front SEAT problem( only one side leans back)
  27. alarm problems
  28. Arnotts Industries Front airbags fitted
  29. Service manuals...By popular demand...
  30. '91 blower motor the same as '99?
  31. Street name
  32. my 92 ls400... socal...
  33. "Aero USA" body kit from hyperrev mag
  34. 98 suspension and general
  35. What should I Do?
  36. 2000 LS 400 Platinum or 2001 LS 430?
  37. ECU/ECM question 1st Gen
  38. Check Engine Light Code 71
  39. Score of the Year 98, HID, NAV,Air Susp
  40. Ghetto Fab! Stupid warning lights.
  41. warning lights
  42. Buying an LS400 at Auction, Air suspension busted? Any thoughts?
  43. Questions: 94 Ls 400 Rim Gurus
  44. fuel gauge problem
  45. New Tires...
  46. 1991 LS.. Poor student about to lose my mind
  47. 90-94 LS400 EGR Pipe
  48. My New Interior (large pics)
  49. Just installed Axxis pads
  50. $7k Ls400?
  51. Service Repair Manual
  52. Rear Knuckle bushings - source (pic attached)
  53. Change your cap and rotors! :)
  54. HELP Lost Power
  55. 90LS400 Electrical issue
  56. Inside fan blower not working . HELP!!!
  57. '90 LS400 woes..
  58. Dealer wants $5400 in repairs......What do I need?
  59. More help!!!
  60. Pics of Windshield and Window Glass Manufacturing Stamp Needed
  61. looking for wheel set for 98 ls4000
  62. Some pics of my 1st Gen
  63. A formal introduction...
  64. 1st gen gold grille bezel, anyone?
  65. I want to install these puddle lights.
  66. 95 Ls400
  67. Seat belt retract...
  68. 1991 LS400 for 2000 is that cheap?
  69. I could kick the previous owners ***!!!
  70. What do you guys think of the lextreme tt ls?
  71. Hot wires / spark plug wires for the 97 ls400.
  72. Rear Tail lights
  73. LCD and hood strut question couldnt find it with search...
  74. Trenz Billet grille, what size drill bit for stumps?
  75. Limited slip friction modifier / Differential Oil
  76. Questions on buying LS400
  77. Reseting Factory Keyless Entry On 93ls400
  78. tilt steering wheel problem
  79. S&S headers for righthand drive models
  80. Need Help - Fan/Fan Pulley loose??????
  81. Ls 400 Starting Then Stalling Problem Fixed!
  82. Ordered two new Arnotts Air Shocks
  83. 1992 LS 400 - using oil
  84. Brakes upgrade on 1st gen LS400
  85. Whutzit Worth ???
  86. Park Place Lexus in Plano !! Furious!!
  87. Question about tire cupping!
  88. Idle Control Valve
  89. Secret Hidden Button/switch
  90. LS in the cold
  91. Idle Question
  92. H3C HIDs???
  93. Just installed Daizen CA Bushings and new ball joints
  94. Diy Grill????????? 98ls
  95. Upper Control Arm Balljoint Fix
  96. Miles to Kilometers-LS400 1997
  97. Anyone ever try BG44k???
  98. JDM headlights!?
  99. $665 for a new window?
  100. For The Factory Air Suspension Lovers
  101. Microphone near rear view mirror
  102. Easiest Way to Replace EGR Valve Pipe on 95 LS400??
  103. Changed my exhaust agian *Short Vid*
  104. 1990 LS400 Nakamichi - dead speakers
  105. Coilover noise, anyway to keep it quiet??
  106. Cleaning Mass Airflow Sensor?
  107. Remote starter is killing battery?
  108. 91' LS400 front seats
  109. ATF dipstick help measure
  110. 1994 Ls 400 Cd Changer
  111. Question about air susp. (1990)
  112. Optimum Batter Size for '98 Ls 400
  113. tilt steering wheel
  114. 1990 Sun Visor Help
  115. Transmission Flush
  116. Gap behind rear seat
  117. Is This Bad?
  118. Color Chart for 1st & 2nd Generations?
  119. Replacing Door Weatherstripping
  120. upgrading interior? on UCF20 with Side Airbags
  121. '96 LS400 Steering Column Position Memory
  122. Location of Air Suspension Controller/Computer
  123. Take A Look At This LS.
  124. 1998 Coolant Drain Plug Locations
  125. Rear Main Seal Leak HELP!!!
  126. VIP Garage photoshoot
  127. Ordered black pearl emblems but...
  128. A few pics of my LS400
  129. Performance chip for LS400? What's the best first mod?
  130. Part number for water inlet nut gasket - LS 400
  131. 00 Subwoofer is 8"!! Not 10"!
  132. 2nd gen Daizen bushings
  133. Another example of Lexus quality
  134. 1997 Ls 400 Transmission Question
  135. Lower front strut rubbers
  136. new LS 400 owner
  137. is this possible in a 98 ls 400?
  138. Maintanance
  139. engine light.....sometimes
  140. exhaust systems
  141. 92 LS400 headrests
  142. LS400 error codes
  143. need help with trac light
  144. Common Problems
  145. Differential Question
  146. Tanabe Hybrid Airbag+Coilover suspension thread - link
  147. UCF10-11 Rotor / Caliper Swap?
  148. 90 LS integration relay diagram
  149. Powers Mirrors Don't Work
  150. Power Lock not working on Drivers side Door!
  151. 98 LS400 Starter won't engage
  152. LS 400 on 19's post your pics!
  153. tape player stoped working
  154. New to the forums, question on first gen!
  155. Performance Mods for 98 LS
  156. Road Trip with 20"" rims ?????
  157. whats the widest tire u can put on 98 stock rim?
  158. Anyone want these wood grain kit pieces? FREE
  159. TRC light on?
  160. 98 LS 400 Tailight Mods?
  161. Cel codes after maintaince
  162. Noob w/ quick question?? LS400 air ride??
  163. Questions about 98-00 LS400
  164. 12V Switched Power / Overhead
  165. Strange Vibration in the Rear
  166. front end knocking on 99 LS400
  167. Service Manual?
  168. 93' LS possibly power steering issue......
  169. Lip Kit(add-ons) for 90-94 ls400??
  170. 92 LS400 seat removal
  171. Tom's Advox coilover - how to adjust?
  172. iPOD install
  173. Are ASA ST4's any good???
  174. Pioneer or Nakamichi Stereo
  175. Transmission
  176. ACC Cabin Filter
  177. Pinging under hard acceleration between 3000-5000 rpm?
  178. How do I spice up a pearl white LS400?
  179. Ethanol-related Fuel Pump Probs in 1st Gen LSs?
  180. Rear Seat Removal
  181. Issues with 18 or 20 inch rims
  182. New Strut bar.. now engine sounds different?
  183. Just did the paperclip trick (pretty neat)... received a code 13.
  184. JDM celsior cluster on LS400 ??
  185. 2 Cars One Dilema
  186. AC doesn't work. Need a diagnosis
  187. '90 LS400 - Valve Adjustment
  188. Engine runs fine cold, heated not good??
  189. Need help, do I buy the 97 LS or 99 GS?
  190. Purchase : 1999 LS 400
  191. Just got my 99, coilover, suspension questions...
  192. 1991 LS400 Suspension Problem!!
  193. LS pics from NELOC meet 7/22
  194. Timing Belt
  195. Any ideas how to retrofit a cabin air filter for 91 LS400
  196. HID Kit
  197. whats A good coilover setup for 90-94 Ls400?
  198. Question about these tail lights for a 1st Gen LS400
  199. 92 LS Interior Light sQuestion
  200. Just bought a Toyota Celsior...need help
  201. 00LS400 Wind visors from luxurymods.com?
  202. '98 LS400 with Odd option combination
  203. question with ac on and off
  204. LS dies all of a sudden, but is fine when jump started and while running.
  205. Are the lugnuts for 90-94 and 98-2000 LS400 the same?
  206. LS on 20's :-)
  207. Its been awhile....two pics
  208. 20" rims on LS 400
  209. Lexus Transmissions
  210. Engine dies after cranking. Will run w/foot on gas!
  211. replace master window switch
  212. Window Motor
  213. Engine stalls while shutting off AC or switching to neutral
  214. Nakamichi Stereo 1992 Model LS400
  215. help (help me with stock alarm reset)
  216. Just Installed my Tokicos
  217. 93 LS 400 stereo probs
  218. Power Tilt Binding
  219. 98 ls 400
  220. 96 LS400 Panic button issue
  221. Just picked up a 93' LS400 DD'er
  222. DIY guard flaring – My photo’s.
  223. Mechanical Locker – No one knows?
  224. Car jerking at a stop
  225. 1992 LS 400 - A/C problems
  226. question about dash
  227. Moonroof LS 400 '90
  228. 2jz Conversion
  229. Catasrophic paint failure on 94 LS400
  230. question about knob under dash
  231. Car just took a ****. :(
  232. new owner - few general questions
  233. driver seat problem
  234. Need Help for High TEMP gauge
  235. Some Drifting Fun (Video) NWS for language
  236. Simple wheel question
  237. Strut Installation Problems
  238. How much is it to get the L Sportline kit painted and installed?
  239. Will the new Tein CS with EDFC fit on a 00 LS400?
  240. Key cutting in Dallas?
  241. Need '98 LS Purchase Advice
  242. Headlight Wire/connector help.
  243. Gentex Mirror in the LS400
  244. 1st gen drivers side window intermittent, lets get to the bottom of this.
  245. Hood Strut
  246. Suggestions: Going to look at a 93' LS400
  247. Newbie gearbox worry
  248. 91 LS400 shape simple questions
  249. A/C Fans??
  250. need a little help
