- weird problem!!!
- Hard to describe clanking/clunking/knocking sound... with pics!
- 1990 LS400 "rims for snow tires"
- Antenna mast never had inner nylon feeder?
- temp gauge never moves....
- LS400 out Door Handle Replacement guide?
- Hood shaking a little bit on highway...whats up??
- LS Double din
- Urgent help needed - timing belt replacement.
- What color to paint the stock wheels.
- Need (only) 1 spark plug wire
- i wanted to share my joy today
- Power steering noise in cold weather help!!
- 98LS Starting Problem
- Oofer-New Member New Owner
- No heat 1991 LS 400
- Added auxilary power to center console ('95 LS400)
- 95 Ls 400 Alignment Related Question
- Upgrading to CarbonFiber Seat Heaters
- yet another MPG thread..
- Rims And Tires Questions
- 92 LS Steering Rack
- Camber, Toe setting.
- MPG on a 93 LS400 Help!
- Chillin in my car
- Suspension On 96 Ls400 Rolling On 20s
- Parking brake problem... NEED HELP!
- California Alternator
- Missfire during accelaratiion ...HELP!
- UCF20 Grille Retrofit into my UCF10
- 1997 ls400
- Power steering lower hose-line!
- Interior customizing options? Interior trim, etc.
- where can I find seats for my '94
- Any idea when to replace timing belt '00
- how do i tell which trim i have?
- Weird engine vibration, Serp belt related... i think
- Pics of my 99 LS 400
- jdm one piece headlight install DIY (with pics)
- New owner: Vibration, TRAC-OFF Light, and More!
- tIs there a way to disconnect he power to the antennae?
- What size wheel/tire combo did your LS 400 come with...
- Shipping A Lexus (abroad)
- I want to put newer style headlights on my '94 (Possible?)
- Need Advice On Some Parts, Power Antenna & WiperBlade
- Question about moonroof/sunroof.
- headlight adjustment question
- 2LS first aid kit
- O2 Sensor plug access
- Quick Fuse Question
- Amsoil 0W-30 Signature Series=Better MPG!
- 93 Ls wont start
- Rear End Lowering while car is off.....
- Where to find '92 Chrome center caps?
- Fuel mileage WAY DOWN.. dicoverd why too.
- Charging problem
- jacking points?
- Error 0420
- Bad AC evaporator
- 91 LS400. Cats glow red, won't rev, no power.
- Rear heated seats - 97-00 LS400
- rear ate rotors for only $26 each at tirerack
- 1991 Lexus LS400 - bushing/lower ball joint replacement...
- the one thing Toyota forgot . . .
- Quick tips needed on what to look for on 95-96 LS400 purchase...
- Looking at a 93 Ls400 with a few issues HELP!!
- how to remove coolant level sensor and how much does it cost?
- Curious about history production numbers for gen I ls400 lexus
- Ignition key cylinder light
- '98 LS w/ HID lights?
- Window sticker
- Headlight Question
- sway bar size
- 98LS - Noise from suspension when braking
- noise power steering
- Leaks, leaks, and more leaks!
- Exactly what NOT to do with a LS 400
- can someone help me out?
- sway bars
- '90 LS400, electrical and engine questions
- a/c problem '00
- New Ls 400 Owner
- Tach Signal Where does it come from?
- 91 ls 400
- Service schedule?
- Need to return to stock height
- Change ugly stock yellow foglight bulbs!!!
- Dyno of my 99 LS400 / Wild Ride in a 450whp EVO
- 92 gas guage- different problem
- Dealer service costs...?
- Steering wheel quick Qn '91
- Another Stereo Install Question '00
- Changed Plugs
- Brought home new baby tonite
- A running LS 400.
- HAs anyone ever opened up their tail lights?
- Got my new 20's put on.. let me know what you think!
- which cluster caps for 92 gas gauge??
- Lexus LS 400 Suspension Problems. '90
- 1990 ls400 electrical problem
- Timing Belt tensioner change?
- 98 LS w/ Nakamichi + phone
- Question about trans. mount
- Took a drive, 27.7 mpg.
- Considering LS- Your Opinion Appreciated Greatly
- Will Supra TT Brake lines work for gen II (97 lS400)?
- Climate control bulb(s) question
- 1990 Lexus LS400 Starts but won't stay running. :(
- Tricking Navigation to think its night?
- Auto tilt steering wheel
- Really weird knocking noise while breaking...
- Very bad gas mileage :(
- Help with instrument cluster - 92 LS400
- Absolute best door speakers? Price is not a problem...
- CAR WASH---Your Opinion?
- hot wire
- gas prop strut hood support replacement ebay 1990 ls400
- Do you have a vibration issue that comes and goes and comes and goes?
- how to replace parking light bulb on 1st gen?
- Brake of 96 LS, 140K
- 95 Lexus fender and bumper?
- Mysterious stall-out/electrical power drop
- 98GS4 wheels on 95 LS.......spacers??
- Computer for 93 LS400
- Seat Heater Bulb - easy to replace?
- Stock Wheels....Good Price?...Finish?
- First Break Down :( (not too serious)
- Radio Probs - Audio Weak - FM Fades away
- 95 ls400 alternator??
- Full exhaust/exhaust tip pictures??
- Any way to increase treble? 98 w/NAK
- Where is the exterior color code located?
- Size (and snow) matters
- Have you ever used spring clamps to lower?
- Links to articles of praise for the LS400??
- Well I finally replaced the propeller shaft assy - '95
- Longevity questions LS400
- Help!! 1994 LS400 Engine hard to start in morning
- Looking for engine mount diagrams/instructions.
- what to look for on a '98LS
- Interior from UFC21 into 20?
- LS400 Video on YouTube... sad, sad, sad....
- Who is the best place for control arms?
- www.carsteering.com experience?!?
- Power window motor source... anyone have one?
- Need some suspension info pls (2nd gen)
- Can I add an MSD blaster coil to the LS ignition?
- 2nd installment: My LS mpg on $25 super-unleaded.
- Added an Electric fan and power steering filter to my 98 LS400
- '92 LS400 Nakamichi Amp
- help please
- Whats my car worth - 1996 LS400 w/ 49k miles
- Missing(running rough) '95
- a 1gen LS on 22's!?
- '90 LS400 keys
- new ecu or reset?
- Bouncing hood
- Battery Q?
- Going lower with Coilovers...
- Engine Code 25
- '90 LS400 subwoofer removal
- 10 thousand for a lexus ls400!!
- Strange noise from rear passenger side suspension ....
- I have a rim question thats been bothering me...
- How hard is it to change your own lowering springs?
- Airbox mod Debate and questions.
- VSC still on after Batt Change
- LED interior lighting
- How to program the garage opener
- What size is the Optima Yellow Top for 00 LS400?
- Fluid Drip To Driver Side Exhaust
- Will 275/30/zr20 rear tires fit on 92 LS?
- Did anyone here buy their LS....
- In Dash DVD/ Navigation
- THERMOSTAT DIAMETER /No app listing
- '90 LS400, deacceleration whine
- Hi-tech ipod dock for LS400 console
- Differential lube...
- Low mi. '94 LS for me?
- any fix for ABS not working
- Help, my moonroof might be leaking
- Help needed diagnosing 97 LS tranny!
- 98-00 Factory LS Wood Color Names/Codes
- It's the little things (tire PSI)
- Brakes squeak when going in reverse.
- Factory NAV question
- H&R Sport Springs on '90 LS400
- Transmission life???
- Am I nuts for thinking about buying a 96 LS400 with 198k on it?
- Non-technical foglight issue 1995 LS400
- repair shop near me
- Blown EFI FUSE
- Hello, need help with steering wheel replacement.
- Another newbe question
- Painted Grille
- Timing Belt DONE!!!
- How do I know if my distributor cap is bad?
- New to the LS Family
- Gen 2 LS crystal park lamp lense
- Traction control button not working!!!
- Name your price
- What parts to replace in AC system on a '90 LS400?
- New member Intro - 96 LS400
- Driver's School question about my 1999 LS trans.
- Ever have one of those true "oops" moments where you hate yourself?
- 98-00 LS400 Xenon Foggies...
- Regular to Synthetic Oil at High Mileage...
- 1991 LS400 w/ nakamichi sounds components factory crossover ?
- '91 LS Radiator Replacement.
- LS400 Model 1993 goes Slow
- new shoes
- Ball joint replacement
- To tint or not to tint?
- Just purchased a 1990 LS400
- Lexus Ls400 2000 brake problem
- My last mpg on $25 premium.
- Hello there, new owner of an old 94 LS400
- New Mounts Fitted
- Trunk Lift Struts
- warning speed signal ls400 1990
- Magnaflow Wide Open Series 95 LS400
- I lost my TRAC and ABS!
- Problem with tilt function
- "LS400" emblem for 1990?
- LED tails for gen 1 LS400
- Tein EDFC Range...
- Steering wheel
- Quick pic...
- What is the absolute quietest, smoothest tire for a 2000 ls400 stock?
- battery disconnect, elec. ?
- '93 LS, check engine, trac light on...
- How gentled do I need to be with a high-mileage LS400
- What do you guys think about this LS400 fixer upper?
- WOT Shift Points
- Powdercoat stock rims for 1990 LS400?
- These rims gonna fit?
- 93 ls4, 161k, need help with codes.. 51,22
- Why would your heater not be very hot?
- Shhhhh
- Ball Joint awareness
- what are these called?
- Looking for new wheels
- Leaking Raditor Fluid_HELP
- Daizens - WOW!
- Ls400 New Info On Problem
- Looking for a 98-00 repair manual..
- need help with 1990 ls400 coolant leak
- Sirius radio install in 99 with Nakimichi
- 1990 LS400, brake upgrades?
- 1990 LS400, power mirrors not working
