PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 [107] 108 109 110 111 112 113 114 115 116 117 118 119
  1. 1990 LS 400 first mods???
  2. Ski's trunk pass through?
  3. Cabriolet LS sighting
  4. clunk sound in diffrential
  5. My Junction Produce LS, Quality Pics this time(56k warning)
  6. Spark plugs for 98 LS400
  7. Need help? Replaced struts to Tokico and not happy
  8. cheap hp restorer
  9. pays to have a camera..in person 2004 LS430 pictures!
  10. '92 LS With High Idle
  11. Amsoil Dual Remote Oil Filtration system
  12. did the toyota dealer screw up my car?
  13. need some help removing rear rotors..
  14. should i consider a corolla ?
  15. Front Calipers on my '95 LS400
  16. K-Break strut bar update II
  17. UPDATE II: Stainless Steel Mufflers
  18. New Rear Brake Caliber Instruction Online
  19. some snap shots of my celsior
  20. 98 LS400Nav?
  21. 96 LS-400 Timing Belt
  22. Do any of you know where I can get this LS430 console?
  23. anyone tried this?
  24. Windshield Washer Squirters
  25. brake warning light...
  26. kings of the road
  27. New owner
  28. Newbie needs info
  29. body work correct?
  30. how do i reset the brake light on the dashboard after changing the brakes
  31. 453,113 miles on a 1990 Lexus LS 400
  32. World Exclusive: First real pictures of the 2004 Lexus LS430
  33. Tach reading 200 below
  34. Dealer are starting to call about the 04 LS
  35. telescoping steering wheel
  36. New Member, What You Think Of My Ride?
  37. Any one recharged AC on LS400?
  38. Rear Spring Removal Questions
  39. LS 400 handles like a bowl of jello
  40. 92 LS400 rear deck speaker
  41. 96 LS 400 rear light failure warning light
  42. Sway Bar rubbing axle
  43. Off throttle "clunk"
  44. 1996 LS400- should I buy?
  45. front wheel noise?
  46. 2004 LS430 Brochure
  47. Hit and Run
  48. Need HELP building
  49. Brake light warning on dash!
  50. 95 and up LS400 owners!!!
  51. LS400 Exterior Colour Codes
  52. Rolled my front fenders, Low, Low, and Lower
  53. How Many Lexuses Have You Owned?
  54. What should I do with a '91 LS?
  55. Winding Road Performance...
  56. Purchase 03 or wait for 04??
  57. tranmission, engine or fuel cut off???
  58. Celsior Ad Clip
  59. Body Kits, Fenders, and Hoods
  60. 1996 LS400 Oxygen Sensor
  61. IF you can do it all over again LS or GS?
  62. '91 Nachamichi Head
  63. Compression
  64. License plate screw thread?
  65. Rear Under-Brace Question
  66. I love my LS
  67. Newby Lexus questions, please bear with me.
  68. Coach leather
  69. Rearview Mirror!
  70. I fixed my AC problem
  71. new distributor cap had a crack, can I use this?
  72. 40k service due any suggestion on what to have checked out?
  73. make sure the folks at the tire center tighten your wheels down
  74. My acceleration
  75. coolant tank question
  76. grill i am making *in progress
  77. 90K/120K service advice.
  78. New owner, good to be here.
  79. Replacing 92' A/C Compressor
  80. Take a read, it might work for yours too.
  81. Fuel consumption problem
  82. Gas shocks for the front hood
  83. Show & Tell In Japan - '04 Celsior
  84. New Key
  85. SC430 Wheels on 96LS400 Please advise.
  86. I have done it HID's with middle foglights still on.
  87. Ls400 underdrive pulley?
  88. What component controls engine braking?
  89. Saw an First Gen LS w/SC430 rims last night. Cerritos Area
  90. LS 430 power locks
  91. Rim fell of my Lex today (pix)
  92. i think i might need a new battery. please advise
  93. Autospies Article
  94. Messed Up Power Steering!!
  95. 2004 Ls430?
  96. I have a question about my LS
  97. AMCI Declares Lexus LS 430 "Finest Luxury Sedan in America
  98. Ls 450
  99. Check Out My Bling Bling LS400
  100. Check engine light??
  101. DIRE need of 2 Bridgestone Turanza Revo's 225-60-16
  102. What's that humming under the hood?
  103. JIC Magic VIP FLT-A2
  104. Air Suspension wiring/how it works HELP
  105. Humming noice after engine stops
  106. Ls400 underdrive pulley, flex fans
  107. Failed emmissions test on '92 LS400
  108. Official 2004 LS430 pics (& Japanese version specs if you can read Japanese)
  109. electric fan conversion
  110. K-Break tower bar
  111. *** New Pictures '04 Celsior ***
  112. No more overheating... A/C Fan works
  113. LIMITED: New Celsior TURBO CHARGED
  114. Strut Replacement 1995 LS 400, will this work.
  115. JIC Magic Coilovers
  116. Fuel System cleaners
  117. A/C, Heater control head removal, 92 LS400
  118. New Diagrams!
  119. UPDATE: Stainless Steel Mufflers
  120. LS430 video 0-60
  121. Air Intake Box Question
  122. Recalls?
  123. Rear view button question
  124. I Just Love My LEXUS!
  125. Can you put a 99 Navi system in a 95-97 LS
  126. importing a bodykit
  127. UCF10, 11 or 21
  128. New LS430 seen
  129. What & where is a level Control Unit
  130. Lowering a LS400
  131. Is it a Air Strut or compressor problem?
  132. My photoshoot with Celsior Master
  133. White Walls
  134. New Body Style with a V12??!!!
  135. will not shift into gear LS 400
  136. Why would you buy an LS400/430?
  137. flashing light on AC switch on LS400
  138. part charts
  139. 1992 LS400 Foglights
  140. 1992 LS400 Seat Covers
  141. remove cats
  142. hmmm..... custom or chrome, need help fellas
  143. Jdm Series 1 Ls400 Headlamps
  144. Devils Japan Website
  145. After market Air suspension
  146. Do any of you guys have a pic an LS430 with Lsportline Model 1 evo's?
  147. Diag codes #420 & #430
  148. Changed O2 sensors MYSELF!
  149. '92 LS400 A/C problem
  150. Hestitation @ 42 mph
  151. Should I Chrome My Rims?
  152. Quick Headlight Question
  153. A/C Thermal Switch
  154. what color is your LS!
  155. Suspension Switch in Trunk ??
  156. part# on this
  157. 1st post!!! looking for a good ls400
  158. anyone know what kit?
  159. under car braces??
  160. TOM's exhaust vs. stock on LS430
  161. Tail Lights for my 93 LS400
  162. exhaust tips for ls 430
  163. black pearl
  164. A/C Filter
  165. Importing LS or SC from US to Canada
  166. supercharger avaliable now!!!
  167. '95 LS400 Grease Fittings?
  168. Wholesale price 2000 LS400?
  169. Air suspension strut prices
  170. Power steering too soft !
  171. 1995 Ls400 Gold Emblems
  172. Rim Instalation HELP....!!!!!!
  173. 1991 LS400 Air Intake
  174. My old exhaust on it's second life..
  175. 1992 LS400 security system
  176. Oxygen Sensor
  177. Front Upper Ball joints
  178. How Much Re-design?
  179. More 2004 LS430 details from AutoSpies
  180. Supercharger in the works for 1st LS...
  181. Rear Suspension really low
  182. Windshield Washers & Fuel Gadge quirks
  183. New Coilovers
  184. Clunk when breaks are depressed
  185. Need some Advice (Looking @95LS w/137k)
  186. Whining noise in my engine
  187. Considering buying another LS400- 1990
  188. climate console circuts shorting?
  189. performance ecu chips????
  190. GPS System Question
  191. I can't believe it!!! My car overheated!!!
  192. Question about this suspension setup
  193. Do any of you guys have a pic of the Wald bodykit for an LS430?
  194. Car Cover
  195. 93 LS400 hood lift source?
  196. 1999 LS400 Ending warranty
  197. The REDESIGNED LS430 For MY 2004
  198. LS430 Good Deal?
  199. What is the widest tire you can fit on the back of an LS430?
  200. **LS400 Poll Who has/had Fading LCD or Dimming/Flickering Speedo/ Needles**
  201. 1991 and 1993 LS400 bolt patterns
  202. Interesting topic (read!!)
  203. Lowest priced place for Power Steering Pump and Alternator
  204. Vip Mags
  205. 92 ls400 remove door panels
  206. aiming headlamps for LS400????
  207. A/C dripping cold water inside cabin ?
  208. My two babies LS and RX at home
  209. Potential trans prob...
  210. can a ls400 with air suspesnion be changed to JIC coilovers?
  211. chrome door handles
  212. Need Help with Rear Strut/spring installation
  213. Brake noise
  214. Lexus alternative Vendors for Suspension Parts
  215. rim upgrade
  216. Rear Middle Seatbelt
  217. Woofer Replacement for 97 LS400
  218. wierd air suspension problem.
  219. Ball joints and Bushings
  220. A Questionable Story
  221. Do any of you guys know what bodykit this is?
  222. refabricating hood insulation
  223. LS 400/430 count!
  224. Rear windsheild wing for 95-97
  225. Fantasy Retrofit
  226. 90 ls:incorrect fuel gauge reading
  227. has anybody experienced this???
  228. Cant Start the Engine
  229. Question on Fog Lights
  230. Lowering with bad roads?
  231. Lowering with bad roads?
  232. Integrity of your Lexus
  233. considering 91 LS400 w/201K - has vibration- info needed
  234. broken power locks and windows buttons
  235. Shivering in Las Vegas
  236. 500k+ Mile LS400
  237. Replace A/C Filter for LS430
  238. Question (Short Ram Intake & Warranty )
  239. Starting problem
  240. Help With Climate Control Seats
  241. 1998/99 LS400 Whats the diff?
  242. hi, please help me choose a nitrous kit
  243. how much???
  244. Jdm Mufflers
  245. Grill ?
  246. Pictures of my LS
  247. Parking Brake Light On While Driving
  248. Laser Cruise
  249. Need some help with P.S. Idle up valve
  250. Eibach pro springs with factory shocks
