PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 [101] 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. 1st Gen Dash Kit
  2. Will the Wood/Leather Steering Wheel from a 98-00 LS400 fit my 96LS 400?
  3. Need Diecast Model of 1998-2000 LS400
  4. My One Complaint-TIRES-DUNLOP
  5. What I found on my driveway today
  6. LS 400 wire and transmission problem
  7. Need a few buying tips....
  8. my new mod~
  9. RX330 and LS400 comments
  10. More sway bar bushings
  11. Engine mounts: medicine for all illness ?
  12. Newest Mods on 95 LS400
  13. 1999 LS400 – What to look for….
  14. Master Cylinder pushrod adjustment
  15. New Mods for the Celsior
  16. whine in the morning when car is cold
  17. first gen LS400 Nakamichi info.
  18. Picture of underside of LS400
  19. Question about lowering
  20. Please help with TRAC/TPS problem
  21. quick question....on yellow fogs
  22. Sporty feeling
  23. Rear right Caliper sticking
  24. Bumpstopable?
  25. Zaino Effect
  26. Looking to get a 93 LS, tips and advice?
  27. major power lost, cats glowing
  28. 2nd GEN diamond cut bumper lights!!!!!
  29. Anodize the STB?
  30. starting new project
  31. 96 LS 400 purchase - what to look for?
  32. Ca Supra TT F rotors fit LS400 one?
  33. How much is to much
  34. Do all air susp have a height switch?
  35. Junction Produce Clear Corners for 98-00 Lexus LS400
  36. Looking for aftermarket parts
  37. Blower motor not working in low or med speed
  38. Want a smoother running engine?
  39. Tein CS available
  40. Creaking Noise From Drivers Seat Back
  41. upgrade air suspension
  42. Where is this oil leak coming from?
  43. Seats
  44. '95 Starting...take two
  45. key fob cracking
  46. Windshield Washer Sensor Replacement
  47. A question For all
  48. Smoke
  49. Car Phone without a purpose
  50. my worst fear has been realized...
  51. Trunk Question
  52. HELP please: engine problem now after i cleaned throttle body
  53. 95 Ls400 Headlight aim
  54. rack solenoid filter removal
  55. Repair Manual
  56. Quick Question - Wheels Tilting back.
  57. Vehicle Weight
  58. How to get back that door "THUD".
  59. snow wheels
  60. broken seat
  61. Engine Warning light on
  62. Cooling fans not running
  63. Colder=smoother? Go figure?
  64. Talk about Lexus on Lexus violence...
  65. A/C hose replacement?
  66. Sewell Lexus Touch Up Paint.
  67. Colors
  68. Second gen LS400 owner (need your help)?
  69. LS 400 and 430's 98 thru 02 Wholesale Transactions
  70. Airborne debris hit my '98 LS
  71. Hit Head on in my '95 LS400... totaled the car
  72. Auto Dimming rearview mirror in 99 LS400
  73. removing rear view mirror
  74. Would L-tuned GS shocks/struts fit 98-00LS?
  75. Aftermarket parts....
  76. dead spark plug wires
  77. Inner Rear view mirror "knocked Out" in a 99LS400?
  78. Need help
  79. reading codes
  80. whinning noise
  81. My '94 LS400
  82. Help, where is the transmission fluid return hose to the radiator?
  83. Clunking noise when braking
  84. Lowering an 1994 LS400
  85. Bent seat frame or Bad motor or gear?
  86. Please Help: need definitive answer to replacing ball joints
  87. clears
  88. Rear bumper removal?
  89. to upgrade or not?
  90. 92 LS 400 - Brake is getting stuck
  91. Need definitive answer to replacing ball joints
  92. O2 Sensor replacement
  93. headlight housing rusted
  94. air suspension
  95. TRD Radiator Cap for LS400 1st Gen.
  96. Will a 95-00 rear bumper fit in a 89-94?
  97. Where can I buy white signal lamp-glas for LS 400 -96?
  98. Swap Lexus Premium to Nakamitchi Sound Systems
  99. vacuum Testing
  100. Help !!! Got error code 41 (TP Sensor Signal ) on my 1994 LS400
  101. Where is 1994 LS400 diagnostics terminal?
  102. 95 or 96 LS400 w/ Engine Stall Problem?
  103. Never Seen So Much Wood In A 97' LS Coach - SEE PICS
  104. What do you thing about these mufflers???
  105. 1995 LS400: remote key or just remote fob?
  106. LS 400 Air Suspension Conversion
  107. A Lil' Something Something : -)
  108. Programming a remote off Ebay?
  109. Trany switch?
  110. Some great Press releases on LS400 and LS430
  111. LS400 High Speed run Pic
  112. Chirp chirp sound!
  113. Where to Buy Ball Joints? quick question
  114. Remote Starter Kit for LS400??
  115. New Owner - Heated Seats Question
  116. has anyone done this mod to their LS?
  117. Pics of my project...anyone got an OE lip?
  118. Headlights and A/C weakening during braking
  119. Which parts to replace?
  120. How To
  121. 89-94 Celsior Intrusion Bar
  122. engine serial number location for ls 400
  123. air suspension
  124. 2nd LS400 photos
  125. JDM Celsior 1990 features...
  126. spacers
  127. need a little guidance
  128. 94 LS400 Instrument panel lights fixed!
  129. Traction and Check Engine Light Coming On
  130. Acceleration = Vibration?
  131. persian451 !!!!! (smoked tailights)
  132. Wood Shifter Knob
  133. headliner falling
  134. random things...
  135. First Car...What Too Do With It???
  136. TEIN CS finally mounted!
  137. Gen 1 LS Leather/Wood Steering Wheel Conversion
  138. alternator fuse melted
  139. Air condition just shuts off when car is idling
  140. Solved TRAC light on problem, might help to older LS400 owners
  141. carrier bushing Help!!!
  142. Cluster needles and guages
  143. 1st generation question
  144. All 95-97 LS owners
  145. window regulators
  146. TDI Supercharger system
  147. 1996 ls400 light question
  148. Glove Box light
  149. New mod for my car, what a difference
  150. SS brake lines info needed
  151. C's Shift Set for 1st Gen.
  152. Win Aluminum STB
  153. Confusing if you ask me.
  154. Sport Mirror's
  155. need headlight for inspection
  156. What Is The A/C Filter?
  157. Euro Suspension (Taste of Luxury Event)
  158. 95 LS400 Engine Pulsing?
  159. free owners manual
  160. Another LS400
  161. 1st gen. accessory question
  162. Questions on LS400 Mods
  163. Manual
  164. airbags
  165. Class Action: Luxury Car road test
  166. Platinum Intake Twister?
  167. Need Kit For PS Pump
  168. Help! 99 LS400 fog light won't go off!
  169. LS Chrome grille
  170. Adding to the Stables
  171. LS430 prototype?
  172. Bose suspension video
  173. Car Info on door tag ? ? ?
  174. Why get the Ultra Luxury?
  175. Need Airbags For My 96 Ls400
  176. Replace shock/strut mounts??
  177. Simple Question, Help please (Where is the oil filter)
  178. new suspension has been retrofitted into a 1994 Lexus LS400 sedan
  179. good+cheap intake for UCF-21
  180. LS400 Radiator Replacement
  181. 2jzgte swap???
  182. Cheap Body Upgrades?
  183. Bang in driver rear side over bumps
  184. Replaced Engine and Transmission Mounts
  185. Airbag electric adapter???
  186. 1990 Air-Ride Suspension Problem
  187. Seat Heater install
  188. Collateral
  189. Window Switch Auto Up/Down
  190. Supra TT Brake
  191. No Power At All - HELP
  192. Installing new steering wheel
  193. LS 400 Overheating
  194. Best wood trim kit?
  195. question about what to check in a car that hasnt been serviced in 28000 miles
  196. Please Help!!
  197. 02 sensor
  198. Addco sway bar issues
  199. Finally a pic-BIG PIC, sorry
  200. LS strut bar
  201. Windows & Sunroof Stop Working Help!!!!!
  202. Need some advice. Another stater problem?
  203. 1st gen gear shift
  204. Need help with Half working suspension
  205. changing headlights
  206. Click!click No Start
  207. New to the board
  208. $5 Project - Painted Corner's (pics attached)
  209. low tire
  210. Chrome or Pearl Black? - Pics
  211. ls400 or economy car???
  212. Fixing a 1990-1992 LS Instrument Cluster
  213. Where to attach Cargo Net??
  214. Engine & Transmission Mount$
  215. How can we LS/Lexus owners protect ourselves from criminals?
  216. Help On 96 Ls400 Lip/roof Spoilers?[/
  217. Questions Comparing 98-00 LS400 vrs 01-04 LS430
  218. Replaced Rear Trans Mount Replaced
  219. 1990 LS400 A/C recharge
  220. A couple of GPS 2004 questions
  221. Help please
  222. bad solenoid switch on accumlator
  223. Red 1st Gens
  224. Pinstriping
  225. Lexus dealership troubles
  226. read the manual but...
  227. Exhaust tips
  228. source for uper control arm bushings
  229. Chrome tips
  230. Daytime running lights weird?????
  231. Lsportline for the LS
  232. muffler tips
  233. Need Rear Coil Springs
  234. keyless entry - LS400
  235. How to replace signle sidemarker bulb on a 98?
  236. Light Configuration
  237. How to take off Front/Rear bumpers ....
  238. New LS400 owner
  239. Major Repairs Needed... Help
  240. LS 400 sounds loud
  241. Stalling Problem
  242. Yes or no to Extended Warranty
  243. any1 ever had a problem with the rear main seal leaking?
  244. My Transmission has complete loss of power!
  245. 3rd brake light
  246. Help Who Makes This Spoiler ? ?
  247. 1st gen. LS400 Exhaust
  248. changing serpentine idler pulley
  249. Knock Sensor and Trac Light
  250. Fuel Gauge Needle
