- Burning Regular for the 1st time
- Hyper Yellow Bulbs! anyone else in love?
- code 25?
- oem cd changer doesn't work well in cold weather ??
- ...brake problems...please help!!!!!!!
- HID + DRL...full voltage possible?
- New Guy.
- Cruse control not working on 1995 LS400
- With much work is it worth keeping my '91?
- Sc400 Intake?
- Which ADUS bushing goes with which arm?
- Shift Lock Solenoid
- Height line flashing?
- keyless entry programming instructions
- Fuel Guage Problems.... Help!!
- 5th Power Steering Pump - boiling fluid
- 05 LS430 5 spoke wheels on a 1st Gen LS?
- Ls400 parts crossreference with Camery
- Eibach Sport Spring for Gen1 LS at TireRack!!!
- Power steering pump
- Quick Audio Question
- KYB GR-2 with Eibach combo
- just sold my wheels, what do i do with teh money?
- LAST pics of my LS before i take off wheels!
- pinku frake
- Need some help on buying this Ls 400
- Weird, loud crazy engine (A/c) noise...help!
- First Gen LS 400 Tailights
- Check-in: Post your current mileage.
- Can't find an aftermarket intake for a 91.
- Some pics from yesterdays drive.
- Nature's CAI.
- Got my JDM LIP
- Seized pulley -- need replacement pn
- driver side door prob. on 92 LS
- replacing a cartridge fuse-HELP
- Gauges Went Haywire After Hitting a Curb!
- 1995 ls 400.My serpentine belt broke.
- 97 SC RIMS on a 92 LS...
- slight but distinct steering vibration
- NGK iridium's on my98 LS400
- New Member Intro
- Where to take my car for timing belt and valva adjustment?
- input on possible new car.
- My LS' first time in the snow.. pics
- I think I have an electrical issue that is beyond simple cluster repair
- Help...95'LS seatbelts dont snap back to place
- Replaced my rear axle carrier bushings in my 96
- HELP again (Please read sticky on thread titles)
- TEIN CS, v1, v2, CST?? Difference? UCF20
- Strange Braking/electrical Issue just started today!
- '91 LS400 horrible gas mileage and gas meter off?
- New To CL...Love it....
- Help identify this vacuum coolant switch ??
- LS 5 speed pedals and clutch pieces?
- 100% Custom Dual Exhaust (video)
- 98 LS remote lock, unlock and trunk not working
- Megan Racing Coilovers
- Stabilizer link nut
- Looking for OEM Chrome Wheels for '98 LS 400
- do you know where the parking brake wire is?
- 98-00 wheels on my 95 LS4
- Looking to buy a 1998 LS400.
- water pump replacement
- Beeping sound coming from speakers '91 LS
- Anyone use BBA Remanufacturing to repair their cluster?
- dealer or independent shops
- TPS Sensor? ('91 with 250K)
- Aftermarket amp with factory radio?
- Junkyard near me has first gen with Air Susp...
- 1994 LS400 rocks back and forth when shifting
- Gauge Cluster AND dash lights AND R D N lights dont come up... help pls
- Will aftermaket Remotestart/alarm--make factory system not work?
- hi guys!
- New LS owner here.
- Clicking noise at the shifter...getting louder
- Quick Question about Gen1.5 LS400
- Rubber Coil Spring Inserts to Raise Spring Rates
- Any DIY info for back rotor replacement? (98-00)
- Sound Deadening. Any info?
- LS430 Coil Covers on LS400?
- LS400 problems, please help
- 1997 LS400 keyless remote....
- 94 LS400 Surges at more than half throttle...
- Start-up Whinning Noise
- Tokico Blues
- Tranny shifts hard on Park
- is the "Accessory and Main Drive Belt" the timing belt?
- 1991 LS400 starts for split-second and then dies!
- Replacing 98 LS 400 Transmission Mount
- newb so cal ucf10 member
- will 20x10 fit in the front ucf10
- Navigation unit where ashtray is?
- 95 LS warning light..What does it mean?
- question about back of ls400 '96 stock radio
- SC400 tranny in an LS?
- W/S washer low fluid warning
- What do i need to do to lower my ls400?
- 92 LS 400 Engine Stalls
- Nav in a 2LS
- LS Commercials & Articles
- wide body ls4 on ebay
- 93 Cluster Problem
- LS vs. SC
- ugh, airride wont go down
- AME Shallen test fit pt.2
- UCF10 F&R Kevlar/Ceramic brake pads
- I need serious help (headlights on affects engine)
- Cleaning up the front end with some JDM
- Need Help!!!!!
- All Weather Mats?
- Best scale model or diecast LS400?
- Help Cluster Is Blacked Out
- Happy 2008 From Australia
- bluetooth for 00 ls400? recommended technology/products?
- good buy or stay away?
- Best Clear bra?
- My Son Locked The Keys In The Trunk On My Ls400
- Help! Electrical Issue!
- Aftermarket Catalytic Converter for 93LS
- Timing Belt Issues on 99 LS 400
- Wheel Fitment
- Car cranks every other day
- Bad ground? Taillight goes off when brakes applied... also marker light questions
- Stalling and vibration
- My Cabin Air Filter
- Left rear tire Bald
- Starter bad?
- Update on projects
- DIY: 98-00 LS400 Navigation System Update
- two things, Paint and Hid's
- same poopy different thread
- 95 Idle high when cold?
- Can't find accesories!!!
- Speedometer Needle stopped lighting up...
- Looking to get a UCF 21...QUESTION
- 3 Problems with my 99 LS All on Christmas day
- Help - replaced timing belt, car wont start, backfires through intake.
- About to buy the Wald executive kit
- Should I swap my 20s for these 18s
- "rumbling" type vibration on my friends LS 93'
- Christmas
- My 99
- Pics Finally!
- 1994 LS400 trunk release
- GOT some NEW rims(again) 18 MRR HR3..Last pixs of the year!!!!
- 1990 Ls400 rear wheel bearing specs
- Ls400 Auto To Manual Conversion.....
- Wiring into the existing sub?
- Truck street/sport tires on 98 LS400
- Need front struts and/or springs?
- Update on my LS400.
- LS or GS
- Khumo Solus tires
- Delayed start
- 1992 Lexus LS400 for sale....Funny car?
- Quiet Exhaust????
- Will these LS430 wheels fit an LS400?
- Roof Spoiler, do they make them?
- Fuel pump fuse?
- 93 LS: Few recent fixes
- Question about Nakamichi AMP for GS and LS
- LS400 windshield wipers and steering wheel noise
- HELP! Need to compare Starter specs...
- Steering Creaks
- Need HELP - Tell me what you like!!
- LS400 lunges when you drop it in (drive) '94
- what to pay for ls400 95,with 47k miles
- my 92' LS stalls every now and then
- Paint estimate please 94 ls400
- Newbie from New York in the house...
- 2000 Ls400
- 95 LS400 Starter dead....DIY replacement in progress
- For my 1000th post...
- Rear side panel body repair estimate. Any info?
- What mileage did your starter go out?
- Front Struts are going
- Can Someone Verify This...
- 1996 Lexus LS400 Limo for sale.........
- Really Need Advice on Exhaust Leak
- 1996 wiring harness / double din dash kit
- 1999 stereo install, please let me know what you think.
- Sound as I step on gas before start cranking
- 98-2000 front end??
- Just picked up an 1997 LS400 for my "wife" lol.
- Just purchased '99 LS400 - Pics inside!
- Driving to Vancouver from SF this friday. Any tips?
- Starter paranoia and no trunk remote
- Bought 1990 LS400
- Friends car - rubber burning smell under hood?
- 1991 LS400 remote keyless
- My car is ready
- My car is ready
- Steering wheel no adjusting.
- Just bought a LS400 Suspension will not pump up?
- Oil leak?
- woohoo! fixed my heater.. well.. sort of..
- Sport Edition CD Wheels.. crap or ok??
- Power Acoustik 8inch monitors installed
- Mono-toned
- New OEM Parts Ordering Site
- Engine Problem
- would a sc300 rim fit my ls400
- Need Parts (97 Ls 400 )... Please Help!!!
- Lights By The Gearshifter And Lights On The Hvac Are Out... Info? Also, antenna quest
- Aux Power Mod (pictures)
- Alternator Pinout?
- Tach "stuck"
- radiator fluid!
- Brake time! A couple Q's '95
- hood struts from es300 for ls400
- Heated seats problem!
- electrical problem question 1991 ls400
- New today Nokian WR TIRES...GOOD CHOICE???
- Roof Spoilers
- Parking light problem!
- Cryo rotors
- power steering pum
- 1991 Lexus LS400 - need new struts HELP!
- Looking for Good aftermarket battery terminal connectors...
- Those that have to drive on snow and ice.
- is this normal operating temp(pic)
- Rolling Shot
- My GF is never driving my car again. (pic)
- Dealer vs nondealer costs for repairs
- Power Steering Fluid Change
- Rental Cars and the LS400
- problem need HELP!
- Signal Light issues after crash - 92 LS400
- Discontected MAF and lots more power
- My LS 400 is dead!!!!!!!!!!!!!!
- will 255 tires fit the front
- How easily does the ls resist rust?
- Strut Bar Problem
- Main a/c fan
- 5spd auto swap into 1LS?
- heater blower
- 95 LS Belt Tensioner Dillemma
- Part numbers for Chrome trim?
- Pics of my LS400/Mercedes Front.
- I just got a 1996 LS 400, need help
- please help...getting cold!!! (heater fan not working '93)
- i have my LS400 finally
- LS400 Electrical problem solved
- How much for install on leather seat covers?
- UCF10/11 Side Visors\Window Vents\Rain Guard
- 1st gen LS brakes on 2nd gen LS?
- Oil pump light stays on '96
- What do you guys think of these wheels?
- buying an LS
