- engine problems
- HELP..1993 LS400 Replace Bulb- Tail light
- Which of These Wheels Would You Test Fit on My Car????
- List of Service - Op Codes
- LCD Screens on eBay
- 1997 LS400 key program
- Does 94 LS400 have an external amplifier, or its built into the HU?
- Different idea on installing i-pod
- Pinstripe Removal
- 98+ Fog Lights!
- Does anyone have Stainless steel brake lines on a 95-2000 LS?
- Fuel Pump ECU location for bypass
- How to fix your speedo needle when it does not work
- Help!! Abs Pump Wont Turn Off!!!
- LS 400 interior question
- Door Speaker Grills / Guards
- What do you think of these wheels.
- So I'm picking up a 1994 LS400 with 98k miles on saturday.
- newbie question : which wheel and tire size for my 91 LS400
- 1993 LS400 sound problem!
- Replacement Headlight Bulbs for 95 LS400
- Whats wrong with this picture?
- L-Sportline bodykit instructions needed ..... do you have it?
- Just bought a 92 LS400 - Air Shock Question
- Power Seats
- iPOD Install
- pics.......
- Trac
- windshild washer reservior
- Does Any 1st Gen???
- Cant Drive At Night....
- TUTORIAL: DIY Front Rotor Change on UCF20/21 (95-00) LS400
- Gen 1 LS400 heater tap replacement
- In the market for a used LS.....
- Trunk Jammed
- Newbie Introducing myself
- Complete PPS Failure
- 1991 LS400 Engine Mount Help
- Cleared headlights f/95-97
- 95-00 LS corner tail and lid light removal
- Car won't start, clicking noise?
- Where Did The Coolant go????
- Shocks...
- Installing an after market radio in a 1995 LS 400
- Rear strut noise
- Original Pinstriping Help!
- PCV Valve where is it??
- MAF Sensor problem
- Strutbar Question
- 1995 LS400 Air Suspension Conversion to Strutmaster's "Hydraulic Strut System"
- Inconsiderate People (backed into my car)
- HID kit on LS400 1991, H1 or H4?
- bad pinging between 1000-1400rpm , had code 71
- Keyless Entry
- will the 98-00 grille fit ....
- 92 LS400 suspension
- Grounding Points in Engine Bay and Trunk
- High Humidity
- What's The Difference In These Power Steering Pumps?
- Crown Majesta conversion?
- celsior grill help
- Height Controller Help!!!!!!
- Performance mods for 98-00
- A/C retrofit & recharge
- High mileage engine
- new drop springs
- Strange vibration, worse when throttle depressed
- JDM Light for the LS400 - Help!!
- Finally got another Lexus!
- Shock suggestions??
- Advice on 90 LS 400 Sunroof Issues
- key will not come out from a 1994 ls
- 1991 AC Problem
- Head Unit Problems...help!!
- UCF20 CRASH test video
- 98LS Rear Subwoofer removal
- Any suggestions where to get a timing belt kit
- Dash Board messed up
- Thinking about going Monotone??
- car shuts off while driving
- 98 LS4-Taillight, Corner Light, Fan Belt.........
- Air conditioning to low??? 94 ls400
- The 2 tone ls400
- 1990 Ls400
- Convert. VIP Celsior Picture
- Iridium Spark Plug
- Where Is The Pre-amp???
- got bored...
- Alarm Problems car wont start
- Fuel Consumption of LS400 Lexus
- LS NAK Amp the same as the GS NAK Amp?
- sloted and drilled rotors(opions)
- Large Calipers...Please help!!!
- Ls-400 Cd Player Removal
- Need help with finding posts
- Interior Trim
- 1992 LS 400 sunroof
- Nav System 99 - 00 - Is latest data July 2004?
- Pix of my girl before she takes her bath.........
- help me !!!
- Change In Color Scheme
- A L O H A !
- wings west bodykit
- Celsior Emblem on 95-97...
- Stop/Brake light switch
- Rocker Panels / Lower side body panel
- Would these wheels fit??
- new member
- L-Sportline Body Kit for LS400 98-00
- Shifting from Park to Drive
- 1992 LS400 - Brake Light Comes On
- How to remove headlamp leveler in 99 LS400 with HID?
- Anyone ever hear of the Mythos Bodykit for the UCF10?
- height controllers in australia
- MotorSwap.. Help
- Hey All - Noob here with a couple questions...
- Rear View Dimmer
- Carlsson UCF20/21 body kit, wing pics?
- where is the air suspension computer?
- Test fitted 19s on LS400 on the weekend.. opinions!
- 3 Rims, which is best for the LS?
- opion on xenon body kit?
- A/C Cabin Air Filter - 1992 LS400
- If you could take one feature from an '04, what would it be?
- New member, A/C question
- Problem with suspension bushes?
- weird stock head unit
- What is a 1990 ls 400 worth?
- What's my 91 LS400 w/ 175K worth? Upgrading to a '98 - '00 model.
- 2 Plugs on Top of Ashtray
- Pics of the new LS! (56k prob not)
- showtime.post pic of rims,paint,drops,any thing you can about your LS
- tis.toyota.com ?
- power? button jammed?
- Junction Produce “Premiums” Kit
- Remote malfunction?
- 2001 LS Calipers on a 89-94 LS400
- Help!!! Throttle position sensor
- help electrical issues
- How do you remove headrest 97LS
- Occasional problem with keyless entry
- rims/tires for 99 LS
- how dark is your tint
- I am new
- Beeping Sound When I Turn Off the Car
- Fixing Door Panels
- New Interior Color Options
- carpet
- Tint prices?
- Hubcentric rings
- Junction produce hood ornament
- Anyone replace the fuel pump?
- location of coolant temp sensor 90 ls400
- Opinion
- endlinks
- Just purchased a new to me ls400
- Stuttering
- best dvd/nav for a 95 ls400.......avn5435....avn6600
- Water Leak From Sunroof
- Dashboard/pad Replacement 92 LS
- PLZ help question about LS 400
- 1993 LS400 burst into flames...
- 3 piece WALD spoiler in
- Looking for 98-00 LS400 Engine Cover
- idling in the lexus ls400
- water in the trunk!!
- 1991 LS 400 Alternator
- AC Fan
- Cleaning winshield washer sprayers?
- 94 LS400 engine question
- can u see ..
- changed 2 black
- Wheel speed sensors will not read under 6mph
- my lexus
- Rims For A 1996 Ls 400
- installing factory disc changer
- VSC Warning
- Problems with shift....anyone have similar problems?
- Sick of searching – UCF10 to UCF20 face lift
- Swapping H4 bulbs to fit JDM headlights
- Low traction and ABS problems after wheel bearing install
- 1993 LS400 Cabin Air Filter
- Almost 300K on our LS400
- power window master switch
- Whose LS? w/ Q45 retro headlights in Torrance, CA?
- 1990 Celsior, Air Bag Suspension, Any Advice On Fitting A Aftermarket Adjuster
- Headlamps - Auto Off? 92 LS 400
- Frustrating problems... >.<
- Height Warning Light
- Need help picking my lexus
- Buying Coilovers
- Windows & Sunroof Not Working
- Any How-To's for Spring/Shock Install on 95-97?
- help (engine shuts off while driving)
- Trunk Shock/Strut for LS400?
- Gen 2 bumper on gen 1 ????????
- Stock height?
- spark plug wires (diagram) Merged thread
- Air Intake Mod + ECT Reprogram = Power
- New rims- now the car shakes at high speeds.
- 1990 LS400 ignitor
- 1990 ls400
- EGR Valve??
- Airbag suspension & Strut Bar
- Occasional starting problem
- Problem With Navigation and Clock Timezone
- New to Lexus Forum
- How do I remove a passenger side door rear view mirror
- $700 to fix front side window
- please don't double post / spam
- Cant fix antenna
- Need catalytic converters for 93 LS400
- Proposed Upgrades: Need Some Input!
- LS400 TRENZ 1st Gen. Billet Grill (Polished)
- Is this LS4's?
- Shifter and Radio Lock
- Manual trans for an LS 400?
- Anyone have more pics of the Exclusive Euro Kit?
- Shifter
- Doesnt it feel good?
- Bodykit Help for 2nd gen LS
- Odd electrical problem
- Tinted Tails
- New Look For Lexkost
- A few questions for a potential buyer...
- Chrome Grill
- Scuff Marks/Scratches & Sm chips
- Let's welcome our newest LS moderator...
- WALD Sportline
- Blown LS400 (Celsior)
- Two kits...where to buy?
- After market rim troubles
- 235/60/16"
- Do you think this is a fair price?
- Help !! Trac Light
- New gauge light problem, yay!
- Cleaning MAF 91 LS 400
- RPM and Temp gauge does not work
- Tint
- ECT Button
- Strut suggestions
- Speedometer in LS400 stops working at times
- Door Panel ?
- Suspension. . . Need your help!
- What is this part? LS400
- Advice needed
- STinks !!!!!!!!!! help me out guys
- wheels
- 98-00 Starter Replacement w/pics.
- better mpg? LS or GS models ?
