New shock time, what to buy?
Old 09-05-07, 08:44 PM
nthach
nthach's Avatar
Default New shock time, what to buy?
I'm debating between Monroe Sensa-Tracs, KYB GR-2s, or Tokico Blues. What would you guys get?
Old 09-05-07, 08:55 PM
LiCelsior
Retired
LiCelsior's Avatar
kyb = oem ride, tokico = stiffer ride, monroes i have no idea.
Old 09-05-07, 09:42 PM
RA40
Super Moderator
RA40's Avatar
Monroe is similar to OEM dampening.
Old 09-05-07, 09:50 PM
avalon42
avalon42's Avatar
I heard Monroes are junk...any truth to that?
PureDrifter
BahHumBug
PureDrifter's Avatar
monroes iirc have a higher premature failure rate than the others.
KYB is the closest to OEM i can think of.
Old 09-06-07, 05:48 AM
Blavatsky
Blavatsky's Avatar
If you want OEM KYB, try irontoad.com or l-tunedparts.com....less stiff than aftermarket KYB shocks, and not much more $.
Old 09-06-07, 10:20 AM
RA40
Super Moderator
RA40's Avatar
Monroe, Gabriel, no-name...if they are matched incorrectly to the car, failure will occur. Most these have a lifetime warranty so replacement is not an issue. Certainly they don't have the name or reputation of a high line sports unit. Since it is a part unseen it is usually a non issue for most motorists and one they will not be able to discern. Key point is a unit matched for OEM dampening spec.
Old 09-07-07, 12:26 AM
nthach
nthach's Avatar
I know Monroe/Tenneco does OEM work for Ford, GM and Toyota. I've seen the Sensa-Tracs and they look like decent units.
Old 09-29-07, 09:38 AM
Lexstacy40
Lexstacy40's Avatar
ok, guys...I know...READ the old threads before posting questions... and I have...but I have not found anyone who's addressed this: what IS the real difference between swapping oem susp for coilovers?
Need a cost-effective way to get a firmer ride plus about 1-2" drop.
but..coilovers...are $$$
advice?
Old 09-29-07, 08:34 PM
PureDrifter
BahHumBug
advice?
coilovers are good if u want ADJUSTABILITY.
spring/shock are good if u are just going to be driving onthe street. but coilovers will go down lower than spring/shocks (most of the time) and will ride better when lower the majority of the time.
Old 09-29-07, 10:06 PM
nthach
nthach's Avatar
I got the KYBs for $77 a shock, and then made a trip down to Exact Motorsports for some Daizen bushings, and I'm also doing the lower ball joints.
Old 09-30-07, 08:58 PM
JDMCelsior
JDMCelsior's Avatar
Puredrifter: how do you like your set up (Bilstein Shocks + Eibach Springs (LSportline Spec.))?
Old 09-30-07, 10:06 PM
PureDrifter
BahHumBug
i LOVE IT!!!
i can go as low (dare i say: Lower) than someone on Tein CS
the ride is pretty damned good for how low the car is but it does get rough on bad roads which is a given.
but keep in mind that the LSportline setup has differently valved shocks compared to normal Bilsteins and the Springs are custom rate as well.
Old 10-01-07, 05:08 PM
Thermactor
Thermactor's Avatar
New factory shocks
Old 10-01-07, 10:33 PM
nthach
nthach's Avatar
Originally Posted by Thermactor
New factory shocks
KYB is OEM for these cars
BayAreaLex
08-16-17 12:23 PM
alfredutzo
05-29-17 06:53 AM
Lexuses71
13
11-29-11 02:16 PM
nytoy
Suspension and Brakes
10-25-07 01:04 PM
YerMajesty
08-31-07 01:54 PM
Quick Reply: New shock time, what to buy?
