Radio Install ????
Subscribe
Sep 8, 2007 | 03:09 PM
I got my new unit in today from a seller on ebay. It is a 7" screen, dvd, tv, radio, cd, etc. I want to replace the factory unit. I went to competition sounds and they told me around $75 or so to install it. Said they had to bypass the amp and subwoofer. I am going to install it tomorrow myself. I saw the tutorial on http://www.lexls.com/tutorials/audio/headunit.html. At the shop, they said there was no harness for the car and the harness would be cut. Can anyone fill me in on this and give me advice before I tackle the job? Thanks!!!
Reply 0
Sep 8, 2007 | 04:21 PM
Well, I got everything out and it was pretty simple until I saw all three wire harnesses. This is a problem, or is it? Any wiring suggestions?
Reply 0
Sep 8, 2007 | 04:32 PM
I found this on sfxaudio.com. http://www.sfxaudio.com/products/ins...S400&Year=1992 I don't think this is right. This is two harneses and there are three to the factory radio?
Reply 0
Sep 10, 2007 | 01:17 PM
hey bro im not sure if this will help but i ran across this tutorial for a Pioneer AVIC d3 install in a GS300....im using it as a research model for My AVIC d3 install to My LS400 when i get home in 2 months.
its not the exact same but this might give you some direction....
PD, Lexkost, AKxx, or anyone, correct me if im wrong, this tut. should apply for a 1LS.
https://www.clublexus.com/forums/sho...t+radio+gs+300
good luck man. hope this helps!
-Phil-
Reply 0
Sep 10, 2007 | 01:30 PM
Quote: hey bro im not sure if this will help but i ran across this tutorial for a Pioneer AVIC d3 install in a GS300....im using it as a research model for My AVIC d3 install to My LS400 when i get home in 2 months.
-Phil-
il look at the wiring diagrams for a 2GS3 and the 1st gen LS4 later today and see how things compare.
offhand im pretty sure its NOT similar as the 2LS and 2GS share a similar radio setup but the 1LS is pretty different.
Reply 0
Sep 10, 2007 | 01:32 PM
You need one that's for Toyota cars 86- and above. It's only 2 plugs, though some of the Scosche ones have 4 to work with older cars too. They don't need to "bypass" the subwoofer, the harness plug will just sit back there not plugged into anything.
BTW- 1LS is a bit different. Much easier. I don't think a write-up is even necessary. All you gotta do is wire up the headunit for any Toyota vehicle, plug it in, and you're all set.
Reply 0
Sep 10, 2007 | 04:22 PM
Thanks for the thread. So, the two plug haraness I ordered will work? What about the other 2 harnesses that connect to the stock radio? Do they become obsolete?
Reply 0
Sep 10, 2007 | 07:15 PM
I'm guessing your car is CD-changer equipped from the factory too? My Pioneer (with no CD) has 3 plugs into the back, not including the 2 antennas. The one that is used for the subwoofer becomes obsolete, and I'm guessing in your case, if there is another one for the CD changer, that becomes obsolete too.
Reply 0
Sep 11, 2007 | 09:12 AM
Thanks pfantom. That answers my ? I had a feeling that was it but could not determine it. What about the antenna? There are 2 metal plugs, a small one and then a regular sized one?
Reply 0
Sep 11, 2007 | 11:40 AM
Usually, the small one will work in the aftermarket stereo. It's usually good enough to get you full reception. You could also not wire up the power antenna wire (blue, I think) on your harness so that you can disable the power antenna from going up and down, since it's not really necessary.
Reply 0
Subscribe
