View Full Version : Maintenance
- RX350 Transmission Oil Change DIY?
- 99 GS3 running lean, opinions?
- Question about oil change
- intake help!!
- SC wants to die after i start it
- Winterizing Your Car 101
- Do we still have a Lexus tech on the forum?
- looking for good repair shop/mech in the Boston, S.Shore area
- oil filter for 1jzgte???
- SC400 wont start every time
- Brake Fuses keeping burning up!
- Oil leak!!
- IS 250 30k Service Help
- can i just boost it? no rebuild necessary?
- Sc400 won't start
- Need help with a dashboard indicator light
- HELP cant figure this one out!!!
- Vacuum Diagram for 1993 Sc400 images/pictures needed..
- ABS help
- LS 400 dash lightd
- Help a newbie out!! 1st oil change!!
- what's the indication of worn or damaged wheel hub bearing?
- braking noise and engine noise
- Best dealer for sevice in DC area
- How does TSB work?
- Looking for a good DC/MD/VA shop
- 2005 GX470 Maintenance Schedule
- Q Motor Oil
- Radiator: Upper Tank Nipple Broken
- LS 400 exhaust leak and vibration.
- climate control dead 92 SC400
- Need help. Wheel Lug Adapter cracked
- '98 LS400: Best way to re-tighten crank pulley bolt?
- MAF and IACV Question
- Strut Bolt
- UAE service for USA car
- Mixing R12 With 134a, Yes We Can
- 98 gs300 Hood won't close ..:-(
- question regarding spark plug change
- Lost Keys
- Error code P0171 - lean bank 1
- Power Window fuse, 1994 Es300
- Just hit a HECK of a bump...
- starter problem?
- only a few weeks left
- Synthetic Score
- Power Door Lock Problems - 94' LS400
- Check engine light
- 2006 GS300: directions on how to replace brake pads?
- '96 ES COP Housing, Connector
- Please help, is this a fair price for a repair?
- Brakes repair places in SoCal?
- IS300 annoying constant popping, clanking, knocking sound...
- Difference between 97 clusters
- are Toyota dealers certified to make all repairs on Lexus vehicles?
- 92 LS 400 not starting NEED HELP PLEASE!
- ls 400 cooling problem
- Maintenance for 2003 GS 300
- A/C drain pipe for 2008 IS 250
- Sluggish Acceleration - Loss of Power
- Required lease maintenance
- 1992 sc300 starter replacement
- IS300 Bank 1 Sensor 2
- Help me diagnose my car's problem...
- question about crank...
- Any Ideas out there?
- What is the Best Overall Brakes for Lexus
- Car Battery - How Much Water Does it Hold?
- Head scratcher
- engine noise..... help plz.
- Dome Fuse keep blowing. HELP!
- know a good place to resurface my rotors in the South bay?
- new battery still draining power
- 97 ES 300 radio not working?
- Don't top off gas after the fuel pump stops. Topping may turn on Check Engine light.
- Auto-Leveling Headlights Warning Light On
- Looking to buy this sc300
- 98 gs400 timing belt change at 60k
- Re: Engine Overheat Troubleshooting
- Please help me diagnose a problem
- Restore Products?
- Good deal on synthetic oil
- Car bobs(shakes)
- NEVER Use Blitz Oil Drain Pans
- 98 es300... Sensor question...
- sc400 trans. interlock
- How to change the transmission fluid on the GS350.
- When to change my Toyota LLC (RED)?
- extended warranty for 100,000 until end of july
- Question about burning smell after performing 100K maint.
- possible scam on ebay for service manuals
- 1991 ES 250 No brake lights
- need your low profile jack recommendations
- air conditioning blow very low
- Questions about torrentreactor.net and GPS upgrade!
- Diy rotors and pads replacement
- Helpful site if you're looking for a hard to find part and have the part #
- Odometer Reading
- 2000 ES300 Dashboard Clock went out
- Please help. wipers!
- HELP Almost broken key fob
- Cigarette Lighter Problem
- Quick question (speed issue)
- What do I really need at 90K?
- Recommedation of a good shop in Cincy?
- Leaking power steering pump
- Problems after starter replacement on my GS400
- throttle body cleaning?
- Low Oil Pressure Warning After Lexus Service
- Please help ASAP!
- Changing Cabin Air Filter
- 04 LS folding door mirror going crazy
- Brake Cleaner
- "Please Help" SC400 Problems Starting
- Replacement headlamp washer actuator
- sc 4
- Timing belt
- time for new transmission fluid? need opinion plz..
- car stalls when i turn a/c off, pls help
- 1997 GS 300 Firing Order
- from 92 sc front bumper to 97
- air conditioning out of whack
- Spark plugs covered in oil!!
- 1998 GS400 P0100 and misfire on all 4cyl drivers side
- 07 sc430 tpms /vsc /afs problems
- Carbon build up through throttle body.....
- Window Not Working
- How often is transmission fluid change?
- Seat belts
- HUUUUUUGE suspension issues
- Airbag control modual
- synthetic and normal oil
- Oil filter wrench
- Octane Booster
- brakes maintenance question
- need brake pad and rattle TSIB, but VIN doesn't qualify
- HELP: Need Advice on seized Oxygen Sensor thread?
- How can you tell what oil was used on a used car?
- Cost of parts!!
- how can you tell if the window "motor" or "regulator" that need to be replaced ?
- Rear end Clunking noise GS300
- Help: Brake Cylinder issue?
- iac valve trouble shooting
- engine harness
- 94 LS400 RPM and Climate Clock LCD
- starter on gs 400
- HELP;Very Confused
- Bosch wipers
- Oil Pressure
- Magnetic Drain plug (oil)
- CEL Code P0121 help
- 1992 1UZ-FE timimg marks on 0, or 50 degrees?
- Power Side Mirror Is Not Working. Help!
- P0420- Catalyst inefficiency
- GS300 Trunk Won't Open
- gs450h hybrid power
- Please help me identify the AT Cooler hose
- ?throttle body/intake cleaner (spray)?
- ATF oem or amsoil
- 1998 GS400 Question--Spark Plugs
- best oil for 2003 1mz-fe?
- 2004 Lexus ES330 Transmission TSB
- How hard/easy is to replace rotors on RX300?
- Use of aftermarket brake pads on '06 GS300?
- Help with diff fluid change sc400!!!
- Gasket size?
- intake issue
- 12V and ground connectors on harness?
- Question regarding Royal Purple
- ArmyofOne's DIY Workshop-Front Brake Pad and Rotor Replacement
- Oil pan spacer
- ArmyofOne's DIY Workshop-AutoTrans Drain and fill (w/out drain plug)/Filter change.
- ADVICE PLEASE! oil change gone bad!
- Weather Seals?
- 93 LS 4000 Fan bracket?
- cleared up: seat belt light,etc
- "Coolant" vs. "Engine Coolant" under the hood
- 93 sc300 window regulator
- valve cover gasket leak & bad 02 sensor
- ABS engages at near stop, can occur for or rev
- Trac light won't go off???
- Gasoline Smell in the Trunk
- Steps to checking/fixing power steering leak?
- HELP 95 es300 Noise and Fluid Leak HELP
- 1990 ES250 engine/ timing belt
- Navigation Update
- Does anyone use Mobil 1 oil filter? I received 6 for free, but are they any good?
- Heater unit please reply
- Question on Honda CRV maintence
- CEL + TRC on ES300: P0300+P0301+P0302 .. mechanic says sludge issue?
- creaking noise
- Code 25 kicking my
- IS x50 Spark Plug Replacement?
- Best shocks, springs, and struts for '98 SC300?
- can choose a radiator
- my Lexus dealer only does ATF drain & fill, no filter or gasket change...
- tires tread mark
- need help bad gasket and filter for tranny
- WitchHunter Performance Injector Cleaning Service
- timing belt change change + fixed oil leak=engine noise
- Code 25 92 SC400 Auto
- what componets usually fail/need to be changed b/t 60-90k miles?
- Hood Release Cable
- Rotten egg smell
- **help please burping coolant issue
- P0440, P0441, P0446 + crackling sound from cats i think
- How Do I test this Coil??(with Pic)
- What is the best car battery ?
- Vibration in steering wheel
- forgot to change oil fiter after changing the oil... what do I do now?
- my cat caused engine oil to spill over the engine... how to clean up?
- willl using Chevron Techron(fuel system cleaner) void Lexus warranty?
- Engine Oil / Filter ?!
- anybody using Mobil synthetic ATF($8.79) instead of Toyota Type-IV ATF($4.61)?
- Cluster exchange problem.
- What kind of service at first 100o miles
- Cluster problems
- HELP**I can't get it up!!!!
- wat brand is best?
- a question for you oil gurus
- 1LS400 code 12&13
- Less Oil Mess
- What does your dealerships charge for labor?
- Valve cover gasket/labor $350 ?!?!?!?
- Battery always draining car. What if I disconnected a Terminal?
- GS400 Ever seen a timing belt break?
- ABS ECU location.
- brake light on...
- mis firing?
- I think I have an axle problem...
- Info on Air compressors for the house??
- New Disc Brake Rotor Question - 94 LS400
- Maintenance schedule RX 330
- anyone use penzoil high mileage oi?
- problen in my GS300 2004
- Just got alignment done....
- 2000 GS3 90K Service
- Code reader
- P0100 & P0110 car not starting..clicks only.
- 1992 SC400 A/C Compressor RELAY Location??
- Transmission issues
- code 35 for traction
- fuel problem 93 LS400
- SC400 tranny fluid help.
- Uh-oh... Wrong Filter?
- <<how much do you pay 4 engine oils.>>
- Needing help on error codes
- car is sputtering 99 GS400
- 1998 GS400 Alternator Repair
- Sc400 a/c line repair???
