PDA
View Full Version : Maintenance
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Coil Ohms
  2. GMB waterpump?
  3. Fuel pump problem SC 400 codes 13, 21, 78
  4. SC 430 Code P0440 and P0446
  5. JiffyLube knuckleheads
  6. New Pistons
  7. Any promotions on Lexus oil & filter service?
  8. Wix 51515 on 1UZ-FE?
  9. PO330 Knock sensor 2 circuit malfunctions rx 300 2000
  10. DIY Engine Light Codes?
  11. WS Fluid Change & Color at 102400 miles
  12. IS300 security light
  13. need detailed parts diagram - GS400
  14. GS400 master window switch - electronic board
  15. Maybe dumb question on service advisors
  16. ATF Castrol Transmax ATF substitution for Toyota T-IV
  17. GS300 Power Steering Squeal
  18. help with dealership
  19. Help!
  20. fuel guage does not work 1992 sc400
  21. Thread size ?
  22. Car won't start
  23. best oil for high mileage ls400??
  24. CHECK PULLEY & RPLC PULLEY - what does it mean?
  25. Got Error Code P0430, What To Do?
  26. Parts cross-reference ???
  27. 1997 es300 sensor inquiry
  28. Lexus sc300 running rich
  29. P2238 and P2241 codes, '02 ES300
  30. Austin, TX (Bluebonnet Lexus Specialist)
  31. G-oil
  32. Mobil 1 or Toyota 0W-20 Oil
  33. Bad voltage problem
  34. Need help - engine won't start with AC on
  35. Shock replacement?
  36. PPI mechanic near Lexus of Route 10 Whippany, NJ?
  37. Starter/Battery Connection Problem
  38. Oil filter part - quick question
  39. synthetic oil question
  40. Would I be able to paint leather steering Wheel?
  41. Where does everyone get their maintenance done?
  42. is Eneos oil good?
  43. Any good Service Shop/ Mechanic in Central NJ
  44. Big problem when Idling
  45. Oil Control Screen
  46. 2000 Lexus GS400 Ignition Problem
  47. 1JZGTE issues
  48. Clunking
  49. why different mpgs...
  50. DIY 2jz-ge channel
  51. SC300 OBD1 Check Engine Issues
  52. Clamp request
  53. duplicating remote key
  54. 2nd gen Gs300 clicking sound
  55. suspension helps
  56. 1st Gen GS, Steering wheel shakes when braking.
  57. stupid 90s tilt steering wheel!!!!!
  58. Refrigerant charge in 1999 gs400
  59. How often to change oil in 2011 IS F??
  60. Maintenance Description Deciphering
  61. A/C smells funky on my 30k mile IS350
  62. Loyalty Discount on Service
  63. Driver brake pads wearing faster than my passenger
  64. Brakes
  65. need help with 2000 lexus gs400
  66. 2002 LS430 noise is driving me nuts
  67. Auto Mechanic learning material
  68. bought a CPO IS350 have question about fuel injection service
  69. K&N Cartridge Filter - RX350 application could it
  70. danger: something is wrong here... please share info
  71. Thoughts on this.
  72. 1999 gs300 radiator leak and overheating
  73. SC300 fan clutch
  74. Please Help with spark plugs
  75. Question about how adding A/C refrigerant!
  76. PLease Help with Timing Belt & Water Pump
  77. new with IS300
  78. Injector or oil tick?
  79. Turn Signals on GX 460
  80. Cross post on broken glass
  81. Tips for dealing with Lexus service and warranty claims
  82. Help with an overheating LX470
  83. OEM Parts
  84. 65k service but im at 70k.
  85. Throttle Body Problem
  86. rattling / ticking noise ..here is a video of it..
  87. Messed up exhaust stud removal?
  88. cleaning the A/C system..
  89. How to tell if the water pump is going bad?
  90. Replacing Fuel Injector
  91. Few questions, tranny oil, engine oil
  92. My new fluid exchanger
  93. How to keep the rust away
  94. Torque converter going bad
  95. Decarbonization & Throttle Cleaning
  96. 1994 GS300 Code 41 & 71
  97. 1994 Ls 400 sometimes dies when accelerating...
  98. different brand of engine oil
  99. Front, rear rotors and pads. 07 GS350
  100. Replacing Timing Belt AND Water Pump?
  101. Windshield wipers dont turn off
  102. dealer rates?
  103. Lexus IS350C Pulls Right with new tires and alignment
  104. car problems p1349 cylinder misfire
  105. coolant leaking w/ pic
  106. 02 LS430 Nav DVD Player software reload
  107. First oil change
  108. personalized settings
  109. Repairing a faulty Vanity Light Switch
  110. Help with throttle body/mechanical fuel pump on 2007 IS350
  111. 1991 Lexus LS400: How to Remove Steering Column Cover
  112. Air conditioning filter
  113. Strange sound
  114. Replace Sway Bar Bushings on LX470
  115. 90 lexus ls400 axle popping out
  116. Safety Recall, Special Service Campaign (SSC) and Limited Service Campaign (LSC) Gene
  117. Surging at Idle (when warm only) SC400
  118. 2006 RX 400 H clicking/clunking noise when idling
  119. Water pump
  120. Evap system problem - from mofoco
  121. Little bit confused with parts
  122. vcs check engine
  123. cel,vsc,vsc off, and abs light on?????
  124. Weird Buzz sound
  125. New replacement calipers rusted...why?
  126. Serpentine/Accessory Belt recommendations
  127. Thinking of replacing PCV Valve- Who has done it on the 3uZ?
  128. Check VSC light
  129. Help with Changeing the Serpentine Belt on a LS400 1993
  130. Engine sound from inside
  131. Meet your Maintenance Forum Moderators: Mitsuguy and ArmyofOne
  132. SMOKE, Whats going on here?
  133. How much does Lexus Technicians REALLY make?
  134. Have you heard about CataClean?
  135. Faulty ECT Sensor 2jzge vvti
  136. Winter Is Coming, Get Your Vehicle Ready!
  137. Aftermarket filter = void warranty? (also oil change question)
  138. 94 lexus es300 white smoke help plz
  139. Short Ram Intake - the horsepower increase myth
  140. MOBIL 1 Facts and Background - Also re: "SYNTHETICS"
  141. I Need A Mechanic
  142. Taking Lexus to Toyota for Service
  143. 1995 sc300 auto climate not working!!!!
  144. IS350 suddenly lost power After install IS F exhaust
  145. 100K Service...Need a good facility
  146. 08 ISF Dash lights are going crazy
  147. normal practice at dealer?
  148. My car is smoking, what does it mean?
  149. Glossary of Terms
  150. Wheel Alingment '10 IS 350
  151. Tanabe new springs advice
  152. Q - Toyota 4 life coolant only ?
  153. Ordering OEM parts
  154. sc300 5spd suggestions for headers???
  155. 95 sc300 5spd 200,000mile service
  156. Coolant leak from....
  157. SC400 intermittent starting issues...
  158. coolant flush now???
  159. Windshield glass cleaning?
  160. New battery advice
  161. driving car without aircon gas
  162. One-way passage vacuum hose attachment
  163. 1992 SC400 Accessory Belt Slack?
  164. 3-button key fob question
  165. DIY forum
  166. Ignominy
  167. Oil Fill Pics - Crud Buildup
  168. Oil change valve
  169. Change Transmission fluid 1992 sc400
  170. Gs400 help
  171. Throttle Body Installation Mistake
  172. First time Lexus owner needs tips
  173. A Battery Problem...
  174. Evaporator problem...Need Advice
  175. Service Intervals
  176. Factory cats
  177. Did he clean the MAF the right way?
  178. EST: Labour Time on shock replacement
  179. RX300 Rear-end Issue?
  180. The "Warped" Brake Disc MYTH
  181. Battery Acid Cleanup
  182. Anyone know how to put in engines? and how much would you charge? SO CAL Area!
  183. Why won't Texaco change my ATF?
  184. Need advice on replacing brake pads
  185. 1994 sc400 trans problem
  186. Is300 Speaker problem
  187. Loose wheel centres on 96 ES What to do?
  188. (RX300) VSC Problem
  189. Check seat belt sensor on
  190. Push-in clip and Push-in style clip fastener Size for IS350
  191. Help!!!!
  192. ignition coil 1
  193. ac 300rx?
  194. eneos 0w50
  195. Drivetrain Noise on Coast to Stop
  196. 90' LS400 Brake Booster Replacemet?
  197. My radiator cracked and now my car doesnt start?
  198. How do you Reset the Maint Reqd Light?
  199. Is the AMSOIL Signature series 100% synthetic 5W-30 oil better than other synthetics?
  200. *CAUTION* with the Lexus Savings Card
  201. LX470 front brakes & rotors
  202. Let's Talk Motor Oil
  203. 2000 LS400 battery replacement
  204. Replacing Brake Fluid DIY?
  205. DIY check and change cam and crank sensor?
  206. Check Engine Light
  207. Struts Help
  208. IS250 Fuel Filter
  209. check engine & VSC light on
  210. paper clip/light constantly flashes
  211. Various Parts for Oil Change
  212. engine oil change
  213. Noise When backing and then applying the brakes
  214. Spark plugs
  215. Reputable, discounted OEM Lexus parts e-tailers
  216. No A/C at idle
  217. Ishino same as OEM Toyota parts?
  218. engine light 1996 ES 300
  219. How to remove a worn screw?
  220. battery drain 2001 rx300
  221. anyone ever rebuild a Vortech Supercharger?
  222. HELP! AC on = no power steering and low voltage
  223. Help: Cranks but doesn't start?
  224. Manufacturer Control(code 1305) Please Help....
  225. Sc with a 1jz not wanting to crank
  226. Lexus dealer refusing to service your car
  227. Lag on start up
  228. 2006 RX 400h transmission leak
  229. Instrument panel is dead
  230. Cd button on stock head unit does nothing *searched*
  231. Sway Bar Endlinks
  232. Anything else besides change timing belt and water pump? at 119,000 miles
  233. Center Console Gear **** Light went out
  234. Compression Test Throttle Body Question
  235. Spark Plugs drenched in oil, 2jzge vvti
  236. 93 SC400 AC Compressor Oil Question
  237. ECU car will not start
  238. Check Engine Light
  239. Gs300 power steering.
  240. Keyless Entry Remote questions
  241. 1999 RX300 with P0500 and ABS codes
  242. Technical Help (by Mitsuguy and ArmyofOne)
  243. Windshield Wiper
  244. Tranmission downshift problems
  245. My is250 suddenly lost power, vcs&trac lights on....
  246. Certified Pre-Owned - what does it really mean?
  247. Great mechanic
  248. Jeep Commander
  249. Synthetic Oil??
  250. Tire pressure warning light on.
