View Full Version : Maintenance
- Bizarre Steering Problem Solved
- Lexus service at Toyota?
- How to clean Power Steering filters?
- How often do you really change your plugs?
- 94 ES Seat Heaters not working
- Wiper blades...
- Hunting for the elusive radiator drain plug
- brake question in LS form
- ES300 Vibrating Question...please help
- 75K maintenance
- Bay Ridge Lexus
- Lexus Service costs: Getting Worse?
- catylic converters?
- sc400 trunk shocks failing - aftermarket source?
- Winter oil time!
- Leak detection dye?
- SC400 Timing Belt
- Radio master/security code?
- buying a new lexus !! changing keys ??
- oil
- Where to go for KYB shock?
- center consul button illumination
- Engine Braking
- whistling sound at 40-50mph
- Changing Transmission Fluid
- Wanna Swap
- Brake light on dash goes on and off... (00 GS4)
- 90k Svc on LS
- oil change
- wiper blades
- tranny filter
- Lexus in michigan
- 2nd gen. wiper blade size???
- Garage Floor Protectors
- Which repair manuals to get from dealer for 93 GS3
- Oil Changes are now $11 (!) at Firestone dealers.....
- 60K mile Service
- Fumoto Oil Valve
- Rear brake pad replacement on '97LS
- Help locating Power Transistor 93 SC4
- Changing the gas filter?
- suspension
- best service for Lexus in Las Vegas, NV
- check engine light
- Is the '93 GS service manual sold on ebay any good?
- Brake problems
- Bad smell from AC
- brake pad's
- Tilt Steering doesn't work well.
- rumbling, rolling, vibration
- How much brake/power steering fluid do I need?
- Where is a good place for service in NYC?
- NavTech database errors
- Quick help from a Tech..
- Changing fog light bulbs on 93 GS 300
- My high mileage oil experiences
- Oil filters comparison for your lexus
- storing vehicle...
- 1st GEN GS300 rotors
- hesitation???
- jack stands
- lx470 shocks
- How to Break-In Your New Car
- Winter Storage
- Oil Filter Clarification V8
- yellowing of door trim
- Timing Belt Change Frequency: Need or ?
- Coolant drain plug locations SC400
- Synthetic Oil starting at 86,000 Miles
- Questions for DIY oil changers
- Door lock not working?
- HELP HELP- what can it be
- Tire Rotation
- Changing a brake light in 93 SC400
- funny story about my alternator
- My 99 GS has bad radio display
- Healthiest/Unhealthiest American Cities
- TCS warning light
- ever had your GS serviced by Longo?
- Anybody's GS400 emitting LASER that sets off their radar dectors?
- Tail light on 99 GS 300
- Brake Job
- Over Heating
- Interior lights don't always turn on when door opened
- Swapping brake pads
- Drivetrain rumble/vibration sc400-basics done
- 130K service issues?
- Antifreeze mixing ratio???
- retail source for Mobil 1 0w40 ???
- First Oil Change
- Fluctuating Idle Speed
- LS 400 Washer doesn't squirt
- Please help with recommendations....
- help with headlights
- rumbling noise anyone have any ideas
- Problem with Window
- Plug replacement in 95 ES300
- LS Leans to the left
- after market equipment / spoilers LS400/430
- Help on dealer rip off
- Removing GS400 plugs
- Best and Worst Lexus Service Advisors
- No VA / DC Body Shops
- stock rotor life expectency.....?
- What's the difference between slotted and drilled rotors?
- Popping noises when turning steering wheel
- Does Lexus use special break-in oil?
- Brake Fluid Change
- 15K Service on RX300 - Re-torque Flange
- Low washer fluid light on LS400
- 3 dealers and a Lexus engineer can not figure out what’s wrong with my car
- highest octane gas?
- newbie here with a weird problem
- Can I replace the brakes myself?
- Poor Service at Lexus of Fremont
- What's the diff. btw Professional tint/DIY tint
- Any Lexus Techs out there?
- Lexus of Riverside SUCKS!!!
- Steering fluid & Injector cleaning
- 93 LS 400 odd problems
- Chevron Supreme motor oil?
- A/C freon pressure R134a 93 LS400
- DWD cleaner
- Rear Humming Noise
- cleaning headliner
- 10000 mile mark.....need your help.
- Changing Spark Plugs NEED HELP
- major fluid drop?
- Horrid mold & mildew odor, spontaneous windshield fogging, and NO DEFOG CAPABILITY!
- Power steering /alternator 91 ls400
- needles died. help?
- How do i change the timing belt?
- Broken Door Please Assist!!!
- ES 300 will not move in reverse!
- "Brake" light is on!!
- Safest and best way to clean engine
- Lexus of Manhattan is the worst dealership
- Time for 4-wheel alignment and transmission service
- Replacing the main seal
- Please Help! (how do I manually bring down stuck antenna)
- Warnock Lexus in NJ Sucks big time !!!
- Dealers taking items from car
- maintenance prices
- Kuni Lexus (Denver,CO) car wash.
- I know what the book says, but...
- 94 GS300 - Dashboard question
- 94 GS300 - Auto AC Problem
- 94 GS300 - Musty Stank from AC
- Where are the spark plugs???
- Toyota service nightmare
- es300 fuel filter and a/c filter
- Dead SC400 Dont know what to do!
- I would like to introduce myself..
- how to remove the front bumper
- Oil level light
- repair manual
- how to change your differential oil. see my webpage
- Headgasket ?
- Door Trim
- What wiper blades are people using?
- headlights
- ES 300 collant question (I do not get it)
- Good Chicago dealer
- Lexus Oil filters are a rip off
- A lotta scratches! WHAT TO DO!
- Where to buy LS400 brake pads @ wholesale prices?
- rate your dealer
- Rear Brake Pads For Ls400 Forever!!!!
- 94 GS300 console light problem
- Lexus book
- Maintenance Questions
- Dead GS please help
- lexus tech's.... please help me!!
- gs3 maintenance
- Changing Your Coolant and Thermastat
- Power window switch "BUZZ"
- Maintenance
- changing engine oil and transmission oil, my version
- A/C filter Change for 93 SC400
- outstanding dealer
- Car Totally Crap
- Air Tools - What are decent tools?
- Exhaust shop in Silicon Valley?
- fixing power window , how much $$$
- HOw many belts are there in the engine. . .
- Rear seat and instrument panel removal
- Rust!
- ES300 Problems
- Timing Belt Maintenance
- gs430 black interior, what should I use to clean?
- AC fan whistles at high high speed
- Cut Waxing Time by 1/2...Amazing!!!!
- Got Sludge??????
- Custom Mats
- Water Gurgling Sound
- Gas gauge 1/4 off???
- automatic transmission fluid
- Any GEN1 GS owners have this problem?
- !!Cruise Control is Gone!!
- Production Numbers
- Repair Manual/Workshop Manual for a 2001 GS430
- Help Installing New Emblem Kit
- The most detailed oil change for GS 400 (with pics).
- Instrument Panel Lights Going, Gone
- "lexus service" what a joke
- 30,000 Mile Service Horror Story!
- how to take off armrest of 98 gs400?
- Brake squeaking!!!!!
- timing belt change questions...
- Transmission Filter, SC400
- '02 IS300 Console Removal?
- Trunk Release not working
- Where are the fan relay and sensor??
- Quick instructions on plugs
- Brakes are occassionally squeaking?!?........
- How much?
- HELP 92 LS400 question
- Lexus Code Retrival for "Check Engine Light"
- Quality oil change without the Lexus price
- how important is the 30K service
- Co2
- Dealer's maintainance quality in doubt !!
- What could cause this?
- Which spark plugs to get for '96 GS300?
- Where should I get tune-up parts from?
- stock spark plugs
- wheel bearings
- electrical problem
- A well-oiled back bumper
- First Oil Change
- Bay Area Dealership NIGHTMARE!
- 90 LS40 RPM's move in bursts on acceleration
- Toyota & Lexus lead in quality!
- re:How to fix "Check" & "VSC OFF" light for GS300 ??
- Minor body damage at Lexus Dealer
- Fuel Injector Cleaner
- How to fix front window damage from stones ??
- Electrical problem
- Very minor scratches?
- SC300 Upper / Lower Ball Joints
- Any way to remove scuff and scratches from chrome?
- 30K Miles Maintance
- Coolant... and...
- fuel filter location 91 ls400
- Drying the car...Tips???
- is this normal? (noisy engine start)
- Can a car involved in accident become a Certified Pre-Owned?
- What kind of questions would you like addressed on ClubLexus.
- Re-Programming Keyless Entry
