Auto-Leveling Headlights Warning Light On
Old Jul 8, 2009 | 01:59 PM
sway162's Avatar
sway162
Default Auto-Leveling Headlights Warning Light On
I posted this over in the my.is forum but wanted to see if I can get some feedback in here as well.
I just swapped out my front OEM springs with the Prokit and will finish the rears later today. The headlight auto level warning came on when car was running and stayed on. How is this possible when just swapping out the front springs? I thought that this issue only happens when installing the rear springs. I've searched and only found ways to fix this on the driver side rear but I didn't even messed with this side yet.
I must of messed with the headlight sensor on the front, but I don't know if it's located on the driver or passenger side. Does anyone know how to fix this for the fronts? I want to try and eliminate that warning light before I continue on to the rear springs.
I like I said before I've read and search on this issue which seems to be a common problem but only found pictures and diagrams for the rears. Maybe, the rear is identical to the front??
Would this picture from the rear help me with adjusting the front?
Old Jul 8, 2009 | 04:30 PM
VVT-i's Avatar
VVT-i
It's on the driver side. You either left in unplug or installed it upside down.
Old Jul 9, 2009 | 12:43 PM
sway162's Avatar
sway162
Thank you, I am going to double check everything today.
Smooth1
Suspension and Brakes
99
Aug 24, 2020 12:37 AM
TomTom236
Jul 7, 2015 08:08 AM
ni8done
IS F (2008-2014)
18
Mar 27, 2009 09:10 AM
vietpr1nce
Sep 30, 2006 03:47 PM
xs2kdriver
Sep 11, 2006 06:39 PM
