View Full Version : Maintenance
- ES oil leak problem
- Shift Solenoid E
- seat rebuild info
- "Clunk" from the rear...
- fuel system cleaners
- changing 98'ES300 tranny fuild
- Head gasket blown on a 98 LS400
- well I failed emissions!
- Transmission Flush-frightening results
- ACIS cleaning/Modification (5/8hp)
- ES300 smells like oil is burning
- Moonroof failure!
- Valve Clearance @60k or 90k?
- Steering Wheel Squeaking
- So I got the timing belt done....
- ES300 Mount location
- Servicing help needed
- Stripped ATF plug
- LX and LS climate control diff.
- tire inflation problem - slow leak
- fuel filter
- 98 gs300, should i switch to synthetic, did search
- Maintance schedule for 99 GS 400
- Oil to use in 02 gs430
- Check Engine Light - How do I find out what's wrong?
- RX 330 Rear Windshield Wipers
- Help me calm down
- Black Transmission Fluid (ATF)
- Correct Brake Flushing Order with ABS?
- Muffler warranty question
- is it ok to use 5w 20 oil?
- where can i get black pearl done?
- Repair Success/ website link
- Burning oil?
- warranty question
- Proper Brake Bleeding Sequence?
- Sticky Rear Brakes?
- Front Suspension Noise
- Who used TOYOTA Dealer for service!!!
- 97 ES300 Winter Wiper mode question.
- My 98 gs300 has the flu!
- sc400 head gaskets
- sc400 fuel pump (bubbling?) noise
- 1997 ES300 head gasket leaking problem
- suspention, ball jonts and dust cover inspection
- Sounds like something is rubbing against my tire
- maintenance parts
- Strut mount? Clunk and squeak noises
- Mobil 5000 Motor Oil RX330 AWD
- Forget about the 3000 and 5000-mile oil change debate!
- HELP! Front Rotor won't budge
- Special Break-in Oil 5000 miles First Change?
- Oil additives / Gas additives etc. Engine Flush etc
- What spark plugs for a GS400?
- Warning Messages on the dashboard.
- LX heater control valve location
- lx470 height control question.
- [b]theft Deterrent Problem[/b]
- odor and question
- Gettin HOT now!
- LX470 tire pressure/hard steering
- Low idle when coming to a stop....
- any damage from low ATF level?
- Factory Service Manual for 01 GS430
- 92 Es300 -- transmission fluid level
- 99 GS400 Warning Light for Tail Lights
- Midas Brake Service
- Local OC California Recommendations
- Low fuel tank pressure problem.
- Valvoline MaxLife anyone?
- radiator sensor light
- my A/C out of comission
- Leaking water pump after Thermo Replacement
- Knock Sensor Location on a 3vz-fe
- A/C light blinking, a/c not working
- Putting V8 On Time....
- fuel in my lexus drive me crazy...help
- Transmission fluid and power steering fluid intervals?
- Online Lexus parts catalog?
- Looking for rear window motor
- Lexus electrical problem related to weather
- Keyless Entry Problem
- 98 gs 300 mpg
- Wheel hub assembly question
- scratched windshield driving me nuts any ideas how to fix?
- Starter problem..... driving me CRAZY!!
- 1st Gen LS 400 Timing Belt
- how to change/flush coolant out of gs300
- Power Steering leak
- Anyone try Valvoline SynPower fully synthetic oil?
- GX470 Front Bearing Maintenance
- Mobil 1 Extended Performance
- 93 ES300 - 50mph to quick stop, engine dies like tranny is not disengaging.
- 93 ES300 . Driving= temp ok, stop driving= coolant res boils ???
- Oil change for RX300
- 01 lx wiper question
- acceleration hesitation / brakes relation.
- Starting problem on a 98 ES300
- GS300 Oxygen Sensor / MAF
- Brakes: "normal" squealing vs. "change your brake pads!" squealing
- engine light
- anti-freeze question
- Trac light wont go away !
- Smoke?
- Visible Exhaust
- TPS look alike sensor for TRAC
- Hard Gear Shifting
- Es300 Timing Belt Replacement
- 01 LX climate control issue
- 01 LX rear wiper question
- $100 to change the filters in my AC vent...
- saw smoke fumes out of hood.
- help with EGR Value
- check engine light
- Need some advice regarding the timing belt
- Toyota v/s Lexus Maintenance Cost Diff?
- Where can I find this part?
- Lexus Dealer's estimate on repair
- Identify Part
- Help removing rear door panel in rx300
- Just bought '04 Rx330 with 22K mi....smoking/dripping exhaust; what does it mean?!!
- How to replace alternator on 90' LS400
- Timing Belt
- Need to take my Lex in which is best??
- Salt corrosion/rust -How to address on Alum. engine and underside-EastCoast question
- Radio problems
- weird noise when turning(sc300)
- What's Up With My Lex?
- GS300 Transmission Fluid Change
- problem with Toyota?!?!
- Alignment
- wiper blades
- POLL: The Longo Lexus Experience
- Parking Assist
- Longo Collision Center Sucks
- loose rear spoiler
- Tried to cancel my GS deposit at Southbay lexus and salesman cursed at me
- Test a starter
- Why won't the side view mirrors move?
- brake work done at dealer?
- A341E Transmission Problem
- 2001 GS300 O2 Sensor Problem
- Transmission drain plug is stiff
- Traction control not working on left side. What should I do?
- Fuel gauge stays in neutral position
- 1998 gs 300 tilt control will not work, please help
- 1998 gs 300 check engine light,please help
- Possible oil leak, what should i do?
- Hood is falling
- Turn heat on, smoke comes in.
- is 10w30 oil ok for a sc400??
- Door Handle on my 97 ES!!
- Changing a Fuse
- 45K service & Longo Lexus
- What is the OEM oil in the A/C Compressor?
- Computer re-learn , gas East Coast vs West Coast -want to pass SMOG test
- Service Intervals?
- tool kits
- Sc300 Steering Wheel
- Leak between transmission & Differential
- rear license plate screws........please help
- Starter contacts
- 97'SC400 Where can I find what a 60,000 mile service includes, I searched
- Universal Code Readers
- Oil pan problem...HELP!!
- LS400 brake issue
- Oil Usage
- problem (clicking noises from the drivers side wheel)
- Leak Fest
- Aribag Computer - Will a 93 work in a 92?
- Illustrated Guide for Troubleshooting Timing Belt Failures
- SC300 Radiator Flush Tutorial?
- radiator problem on 99 RX300
- 94 ES300 Interference engine? (timing belt)
- Loss of Engine Oil, Why?
- 95' Fan blowing hot air
- Oil or power steering fluid on header causing smoking?
- Another oil filter thread. . .
- Ways to test brake pads??
- Whew $ of trunk air springs shocks
- lexus gs300 complete maintance price
- Fuel Filter
- 1994 LS400 (150Kmiles) Trac Light on Instr. Brd. turns on in Dry Weather/Pavement.?
- tail light replacement.
- 98 ES300 Blower Motor Wiring Help
- how can you tell if the A/C works in the winter?
- Oil Level Light Wiring in Harness
- What is the average expected life of head gaskets?
- A/C blower not working, 97 es300
- Dealership Car Wash?
- Small coolant leak (pics enclosed) - expensive to repair?
- New Engines from Dealerships?
- Fluid amounts for drain-and-refill on '90-'94 LS400?
- Best Sealant for Headlights?
- Opinion on actron OBD II scanners?
- LS430 Engine oil
- ABS, Brake, VSC lights on. Please help
- Windshield Wiper Washer Hoses ?
- Manhattan Lexus: folks out of the area need not apply
- Need help on ATF change!
- Help please. This smell is killing me
- LX 470 Seat adjustment
- LS 400 Crank & Cam Sensors
- play in steering column
- did i get a fair price for 100k service?
- Rounded bolt -- AAAAGGGHHHH!
- Change Oil or not-it's been 3 mos but only 1500miles
- Engine Sludge Issue...
- Identify Seals by Part #
- lug nut lock key missing
- my lexus dealer is shady
- Advice on tuning up a 100k mile GS400?
- Oil filter amazement
- Equivalent Toyota Part #'s
- New Prestone coolant
- Power Antenna Question - HELP!
- Part# for Oil Filter GS300
- Difference between red and gold engine coolant
- SC4 tranny fluid.
- sc300 problem
- rx300 timing belt replacement
- Car Died- Problem with ECM?
- Temperature problems on my SC300
- timing belt for 1998 gs 400
- Who makes the best air filter for a SC300?
- heater problem
- stalling
- Just a few last questions before doing my clutch!!
- How can I test the starter?
- lexus platinum warranty question
- ABS Light and Battery Light
- GS400 Timing Belt
- Jacking location?
- Lindsay Lexus of Alexandria BAD Service
- Parking light not working
- No start
- Lexus SC400 - Thumping noise?
- ES Headlight Adjuster??
- Replacing Egr tube
- 90915-20004 still available at Carson Toyota
- 97 ES300 AVS Strut Conversion
- 95 ES Differential and Trans fluid change ?
- 5-speed rebuild info?
- noob- info needed for Mark 2
- Removal of Arm Rest / Center Console on 1994 LS 400???
- New Lexus Service in Maine
- LS400 horn problem.
- Water Leaking Under Rear Carpet
- Bottom line on LS400 valve tick ??
- Motor Oils
