Changing Cabin Air Filter
Old May 19, 2009 | 08:27 AM
nrasche's Avatar
nrasche
Default Changing Cabin Air Filter
How do I change the cabin air filter in a 2006 LS 430? I know where it is located. Just can't figure out how the get the current filter out of the housing behind glove box. Can anyone help?
Old May 19, 2009 | 09:32 AM
Hayk's Avatar
Hayk
isn't it in your manual?
Old May 19, 2009 | 07:26 PM
AlexusAnja's Avatar
AlexusAnja
Default Behind all the junk...
1. Take all the "stuff" out of our glove box of course.
2. Remove the little shelf unit. It "snaps" in, so you merely pull it towards you slightly and you'll feel the catch release.
3. Once out, you'll see the door on the back side of the glove box. Open the door.
4. Once the door is off, you'll see the filter unit. Pull the unit straight out.
5. The filter is the element inside the housing. Remove the old element, put in new element.
6. Reverse order to install.
Good luck, easy 1 minutes deal, if you know what you're doing.
Old May 21, 2009 | 09:44 PM
Hayk's Avatar
Hayk
Seems like it's the same as on the IS. On the RX you have to swing the whole glove box completely open and it's behind it..
Matsui
GX - 1st Gen (2003-2009)
37
Sep 1, 2024 04:38 PM
yumseyo
Jan 1, 2019 03:39 PM
iowadawg
HS 250h Model (2010-2012)
Mar 22, 2015 02:31 PM
murphym1
Jan 8, 2009 09:26 PM
np20412
Dec 7, 2005 01:36 PM
