Leaking power steering pump
Old Jun 2, 2009 | 06:58 PM
greyBLITZ's Avatar
greyBLITZ
Default Leaking power steering pump
Running a '94 SC400 and just recently replaced the power steering with a new pump. I am having a really bad leak on a new power steering pump but I'm not sure what the area is called. I do know that it is opposite of the "high pressure side bolt". I have circled it on a pic of the old pump. Every 2 days or so I will have to fill it back up with fluid. What might the problem be? And how can I fix it?
Old Jun 3, 2009 | 08:52 AM
habeeb89's Avatar
habeeb89
If I am not mistaken, there should be a small rubber gasket (washer), is it in there?
Old Jun 3, 2009 | 08:53 PM
greyBLITZ's Avatar
greyBLITZ
I do recall that it wasn't easy to get in because of the rubber o-ring, but whether or not it is still in there is unknown until it is all taken apart. Not something I would like to do again. I believe it is a brand new o-ring too. Would there be something else that is causing this problem?
g35c
May 30, 2010 09:35 PM
Lsportline43
14
Apr 3, 2010 01:31 PM
SaskaSc
Aug 8, 2007 08:28 PM
ozzie
GS - 1st Gen (1993-1997)
Apr 29, 2006 09:41 PM
khepera
Jan 22, 2006 11:39 PM
