PDA
View Full Version : Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25
  1. car wont start, battery problem?
  2. I just shorted my new battery-did I kill or damage it internally?
  3. rant about sewell body shop
  4. Major Maint. Work at Lexus
  5. Accel Kool Blue Air Filter
  6. What oil?
  7. Service Manual
  8. Can anyone recommend a good independent mechanic in OC?
  9. Water pump - how long did yours last?
  10. Can someone help me out with oil filter?
  11. Seat Belt Help, Thank You.
  12. check engine
  13. Yes, there is such a thing as a non-remote master key
  14. could it be wearing out already?
  15. Battery questions?
  16. Replacing front bumper LS400
  17. GS 400 Oil Leak Help Fast
  18. Leak!! need help, Pics included
  19. Ignition coil out
  20. Where is my oil filter?
  21. Air Flow Sensor B1 S1
  22. 2nd Gen - Ignition system exploded diagram?
  23. coolant flush question
  24. DIY RX330 oil and filter change
  25. Where to buy factory paint?
  26. Bad Ride...How do I tell if I need to Replace the Springs vs Struts (not air) LS400
  27. Fuel
  28. Anyone Lengthen/Replace Battery Cables?
  29. ES300 cabin filter debris
  30. 45k maintanance
  31. Good battery for the SC and where to buy?
  32. Gen 1 LS reverse sensor
  33. need help on identifying a fuse (GS400)
  34. ABS/VSC/VSC OFF lights on
  35. try Blue Devil before??
  36. sc400 main o2 sensor removal
  37. A/C code 23.....??
  38. sc400 power steering info
  39. sc400 power steering info
  40. 91 LS400 all air suspension problem
  41. i did a bobo
  42. Very strange sound form head unit in SC400
  43. Vibration
  44. AC doesnt work...
  45. ECU pin out for 1st gen GS
  46. trani too full
  47. injector cleaner
  48. changing oil on '99
  49. 60 K Service
  50. 2nd Gen - Tensioner & Idler Pulleys...
  51. What do you think about oil
  52. seat belt problem help!!!
  53. excessive oil sludge
  54. Code 24 Air Intake Temperature Sensor??
  55. Help! which O2 sensors do I need to order
  56. AC Line Removal? Assistance ASAP
  57. Problem with replacing sparkplug while engine is still hot
  58. ABS Fuse
  59. A/C on a 1993 SC400
  60. 5 warning lights randonmly turned on
  61. Takin my SC300 in for a tune-up
  62. 132,000 miles on my SC400....what to do??
  63. Strong gas smell on start up
  64. DIY replacement parts.
  65. Toyota Parts Number List?
  66. Anyone know the low side ac fitting size
  67. How common is AC failure on first gen vehicles?
  68. Steering wheel locked 1991 ES250
  69. Does the check engine light come on for "engine maintenance"?
  70. Broke trans pan bolt
  71. Key stuck in lock position???
  72. GS300 60k revisited
  73. Timing Belt Replacement
  74. Tire rotation for AWD
  75. Need help finding tune-up parts
  76. tranny fluid change - dextron?
  77. Jim Hudson Lexus..NEVER AGAIN
  78. Service in Cleveland-Akron, Ohio Area
  79. Prepping advice for x-country trip
  80. A/C recharging problem
  81. coolant draining
  82. Hiccup when accel in SC400
  83. IS300 Brake Issues??
  84. 2001 GS300 Battery Replacement
  85. 86K miles service ? tune up?
  86. Oil Service cost a big surprise
  87. CEL P0770 error code. Help!
  88. SC300 Tune-Up
  89. Airbag Warning Light & OBD II
  90. Excellent Power Steering Rack thread
  91. Trac bleeding method
  92. Air Filter - Change Interval?
  93. ac compressor on/off too soon
  94. Low coolant light
  95. What grease to use on Window sliders?
  96. Extended Warranty
  97. Sevice Manuals
  98. Can Bad wires and plugs make you run lean?
  99. SC400 driver's side window cost?!?! please help!
  100. Strut Tower Bar Install Question
  101. cali people...with "engine" light on...for smog
  102. finally did it jump to synthetic oil
  103. 93 LS400 Brake lag
  104. 60K mile service gs430
  105. Evaporator bad
  106. lexus brake question...
  107. What torque wrench do you use?
  108. Car is sputtering/ surging? HELP!
  109. Im going to set my car on fire...
  110. Dextron III vs Toyota Type IV Tranny Fluid
  111. SC400 @ 150K, what to do?
  112. Vibration coming from dash! help!
  113. How to Reset : " Main. Req. "
  114. 10k Service : Dealer or no?
  115. Fuel Line Woes
  116. Which spark plug?
  117. Need Private Mech. info.
  118. poping sound
  119. Check Radiator Fan Switch
  120. Maintenance for a certified lexus
  121. Need to remove air strut from LS
  122. Synthetic or MOA?
  123. Anyone use a Bosch Universal o2 sensor?
  124. Running Rich and Lean
  125. maint. suggestions
  126. 60 K miles service
  127. Check Engine Light Code #1705 - Toyota Avalon
  128. AC Conversion to 134a
  129. Radiator top tank leaking...
  130. Air Tools-on a budget
  131. brake drag?
  132. Strange smell coming from my vents! help!
  133. Suspension/Alignment Experts - Please help me interpret this alignment Report
  134. Does the 97 SC400 have two cabin filters?
  135. A/C Problems, need advice
  136. Gas smell in my '92 SC400
  137. 90LS Air suspension diagram
  138. radiator leaking
  139. 2003 GS430 - Retorque Driveshaft Flange Bolts?
  140. Tranny fluid question...
  141. '95 ES300 is bogging in first gear
  142. Question about my 1990 LS400 related to a/c
  143. Aftermarket panel air filter
  144. Cleaning the IACV (Idle Air Control Valve) on first gen LS
  145. A/C Hoses
  146. Help with AC???
  147. Pink vs. Red OEM Coolant/Antifreeze
  148. ac problem
  149. Can I charge AC myself?
  150. Help! - Does 2001 RX300 need extended warranty?
  151. PS pump change?
  152. Vibration at 60mph, not a balancing issue?
  153. Refinishing bumpers -- Carnica?
  154. How many shocks to replace?
  155. Repalcing Catalytic Coverters
  156. Removing oil seals for cams and crank
  157. accelerator pedal hard to push
  158. Help on changing spark plugs on 99 GS300
  159. Need help with an OBDII code: P2241
  160. SC 400 A/C Low and High Side Ports
  161. specialty brake shops ?
  162. Moonroof cables on '91 ES250
  163. Key Remote for GS
  164. 99 RX300 brake problems
  165. anyone familiar with A/C evaporator drainage 99 GS
  166. Cabin Filter and Cleaning Kit for '96 ES300
  167. Wood Grain Coming up....
  168. What should I get next then....?
  169. Rebuilt Calipers?
  170. Coil Wires?
  171. '90 LS400 - How to change wiper blades
  172. 93 SC-300 AC uses R134 or R12??
  173. 03 LS430 a/c Air Sweep
  174. 120K miles service.... have a list ready to go
  175. Techron Fuel Injector Cleaner
  176. Dealership dino oil
  177. proper vacuum reading LS400
  178. Part # RX300 Tranny Filter and Gasket
  179. Air Suspension 1990 LS400 (refill?)
  180. good idea to keep gas tank 1/4 full?
  181. Here is a weird one..... (overdrive switch broken)
  182. 90k Maintenance Done
  183. brake pads for 2001 RX300
  184. Engine stumbles when idling - what's wrong?
  185. maxlife synthetic oil and maxlife filter
  186. AC/Fan whistling & chirping - please help! - ARGH
  187. Flush Engine Before switching to Synthetic
  188. Radio Display Malfunction
  189. ES300 power steering filter?
  190. failing to start/starter issues
  191. SC300 Motor n Tranny Mounts
  192. Distrib Rotor
  193. 90k mile tune up for the sc
  194. Clutch pulley.... reverse threaded? ASAP
  195. Cant get SMOGGED!! help?
  196. Loud clunk in front end
  197. help: hid self-leveling warning light ON
  198. HUGE Problem HELP NEEDED
  199. Just Wanted To Introduce Myself
  200. L-Sportline Supension: Rear Rattling
  201. California Smog Check: High Emitter Profile?
  202. 92 SC300 Auto Shifting Hard
  203. Sc300 stalling
  204. '95 SC300 (55K mi) suspension squeaks over uneven road surfaces/bumps
  205. Odd Brake sound after new pads ( Rear )
  206. Help!!! Fuse 150a
  207. How do you contact Lexus zone rep?
  208. Vehicle maintenance log
  209. Lexus changed my coolant to green. Is that normal?
  210. My Timing Belt endurance test has ended.
  211. Starter Problem?
  212. Repair Manual for 93 SC300
  213. Smogging a Car?
  214. 00' RX - diff fluid red?
  215. Which NGK for a 94LS
  216. repair/service manual
  217. Car wont start!
  218. What do you use to lift Lexus-Ramp or jack and clearance questions
  219. strange braking noise on 98 gs4
  220. Code 21 (merged threads)
  221. AC not cold Sc400
  222. Rotor moved closer after new Wheel bearing???
  223. !!! Transmission Fluid Question !!!
  224. Over torquing Caliper bolts....
  225. Strange behavior with NAV system
  226. AC Filters in our cars
  227. Car service - BIY stuff - MAJOR CONFUSION
  228. Blown Head Gasket - 93 sc300
  229. Clogged Winshield Washers
  230. 30000 service on my 00 GS400
  231. vacuum reading
  232. TB / WP Question ( ES 300 )
  233. Help: Buying a 1992 Lexus Sc300 w 130k miles
  234. Air bag light flashing
  235. Problems galore
  236. is it ok to use 10w-40?
  237. 99' GS400 wheel bearing cost?
  238. Ignition Problems
  239. SC400 High Pressure Power Steering Hose
  240. lubricate steering shaft
  241. My Lug nut Snapped!
  242. 120k scheduled maintenance
  243. 94 sc300 problem
  244. Transmission Fluid Question For A 02 GS300
  245. Power steering leak
  246. driver seat swap options on LX
  247. Stalling
  248. Hood Insulation Removal
  249. 90K mile service
  250. Anyone know the details of changing out the ignition
