Quick question (speed issue)
Old Jun 11, 2009 | 11:12 AM
gs300_94's Avatar
gs300_94
Default Quick question (speed issue)
I just bought a 94 gs300 with 101k miles SHOWN and everything runs fine. only problem is the speedometer doesn't move, nor does the odometer acculate miles when i drive. The previous owner my friend which had the car for 5 years, said the odemeter and the speedometer stopped working about a year back so im guessing the car has about 125k on it. He also stated that they stopped working after an after-market alarm with auto start was installed. I was wondering if anyone else has had this problem and if so has an idea of where to start to fix this. Thanks!
Old Jun 11, 2009 | 11:35 AM
UncleRay's Avatar
UncleRay
Check the fuses for a start, if they seem fine, you may also want to check the wiring that may have been a faulty issue. The fuse sounds like the best start to go to
Old Jun 11, 2009 | 11:27 PM
gs300_94's Avatar
gs300_94
Would you know if the clusters fuses are located under the hood? or in the drivers footwell? i dont have the panel for the foot well so i dont know which fuse is which
Old Jun 12, 2009 | 02:12 AM
UncleRay's Avatar
UncleRay
Well, since you have the 300, it would be a bit different. However, I'll check in the morning
Old Jun 12, 2009 | 07:54 AM
GEORGE_JET's Avatar
GEORGE_JET
Does the aftermarket alarm with auto start actually work? Most of those alarm system have a electrical connector at the unit that interfaces it with the car. Try disconnecting that connector ans see what happens. The other thing to do while you are checking he fuses, is to check the connections that were made when the system was installed. It could just be a poor connection when they installed the alarm.
Old Jun 12, 2009 | 11:54 PM
gs300_94's Avatar
gs300_94
yeah the auto start works. thanks for the ideas guys imma have my friend look into it
Old Jun 15, 2009 | 11:59 AM
UncleRay's Avatar
UncleRay
Find the problem? Sorry for the late response, have been sick lately.
wayman28
Dec 19, 2014 04:51 PM
gs300_94
GS - 1st Gen (1993-1997)
Jun 11, 2009 11:25 AM
