View Full Version : Maintenance
- SC400 pwr steering noise and fluid from reservoir
- Inner Tie Rods -do they wear out?
- Serpentine Belt noise
- Brake Sensors
- O2 sensor
- Stoopid question of the day: Can I use sc300 brake pads for LS400 brakes?
- Transmission fluid question?
- Serpentine Belt noise - LS 400
- sc300 noise problem
- need help with strange noise
- need part number for gs400 belt tensioner
- radiator replacement procedure
- Coolant Flush
- Full Syntactic Oil
- Best Price for a K&N Air Filter
- sc400 loss of power HELP
- oil filter removal?
- brakes
- Smell of Type 4 ATF vs Dexron - Long
- belt squeak when revving
- Timing belt for my GS
- LS400, 1996 - fan clutch R&R?
- '96 LS... where do rear O2 plug in?
- Changed Transmission Mount ! Long
- How to open hood on ES300
- Dallas Sewell Alignment experience
- NEVER EVER use belt conditioner....
- Small rust spots in pearl white paint
- How to change Tranny mount
- A/C Control Panel LCD dark
- Highway vibrations - Tranny Mount
- Dont Panic, I just put Kerosene in my OIL
- Valve Cover Gasket holes?
- LS430 Brake Tutorial
- Car pulls to the right - Sticking left calipers LS 400
- SC400 100K recommended maintenance
- Omission in lexls.com on changing rotors
- Brake Pad Thickness
- Steering problem
- Greasing '95 LS400 front Calipers??
- LS 400 with 200K - Tranny Flush?
- Help! Oil Change Gone Wrong!
- Testing of Calipers for 1992 LS 400
- Removal of Rotors LS 400 1992
- Suspension
- Lost some refrigerant
- SC300 Coolant Drain Cock
- Ramp Problems
- Air Suspension is Uneven after replacing Driver front shock
- o2 sensor removal
- Crash sensors removal
- Timing Belt & Water Pump
- Techinical and Maintenance Information
- 95 LS 400 PS Pressure Hose
- Installing brake rotors 1992 LS 400
- Brake Rotors - Steering Vibrations
- CHL problem
- Night Tailights went out need help
- 92 LS 400 - Steering Vibrations
- Fuel Filter
- What do Lexus techs earn per hour?
- Low on oil?
- quaker state higher mileage mix?
- How to check if control arm bushing is bad
- High miles 94 ES300
- LS 400 alignment
- engine oil problem?
- help again pleas? (how can I get better gas mileage and what about 'the tornado')
- Advice on Lexus Body Shop??
- How to remove Glove Compartment '92 LS 400
- DTC reader
- Mechanic recommendation in Los Angeles?
- 1992 LS 400 - P/S Fluid
- lexus roadside assistance
- Jack stand location for IS 300
- Replace high brake light bulb
- A/C Not working
- Looking for good service provider in San Mateo
- My 1997 LS400 will start but then shut off HELP
- Deposits on Heater Valve??
- Battery Leak? Rust? Suggestions?
- Upholstery Shop in San Francisco Bay Area ??
- Brake Rotors for 92 LS 400
- TSB Recalls etc
- Does Freeman Lexus Not Want Our Business?
- Any of you ever used Lubro Moly synthetic?
- Anyone heard of AMSOIL?
- Really Bad Gas Mileage
- 94 LS400 Rear Wheel Bearing Replacement Help ???
- Totally pissed @ lexus service
- Mobile 1
- Maintenance Moron question
- Quick A/C Question
- where is my engine oil ?????
- any smog techs, need help!!!!
- Does anyone here flush coolant the old fashioned way?
- GAS - What octane do you pump?Does it matter? How about different gas stations?
- is the Master Cylinder damaged
- ac went dead need help!
- Fuel filter
- 1994 GS 300 spark plug gap size
- Anybody here try PPG Aquapon on their garage floor?
- If the problem isn't the flashing unit?
- 60,000 mile service
- sc300 car problems
- South Jersey/Philly area shop
- flx a flat?
- Loud Start
- '94 LS400 without Dash Lights
- Mad Fuel consumption.. HELP ! a.s.a.p
- Spark Plug Test...
- Torque value for radiator plate?
- Best Replacement Windshield Washer Nozzles?
- Alternator Replacement in 99' GS400 --HELP ASAP
- what type of engine oil do u use?
- Transmission mount for 99 RX300
- Spark Plugs - Should I stay or should I go?
- 90 Ls400 misfiring Replaced coils wires etc still missing
- Idle Air Controller
- 1997 Ls400 Starter Problem
- Torque Wrench deal @sears
- pros and cons
- clanking and whine sound in engine bay
- Dealerships are outrageous!
- SST 09228-07500 Worth It?
- Can you service your Toyota at the Lexus dealer?
- changing negative wire, and door lock???
- Seattle area help
- Synthetic over normal oil.
- 90 LS brake pad clips.
- water pump HELP!
- Windshield Wiper Question
- Cleaning your Windshield Washer Nozzles
- Need Help. Trouble starting
- How to hook up an external temperature gauge?? (gauge says car is running hot)
- Is my steering rack & pinion bad?
- Gas Is Crazy
- Battery dies after a 3-4 days without starting
- Oil Change at Toyota Dealer
- Which dealer to take my car to for service?
- 1992 SC400 engine(timing belt broke)!
- New York State Inspection
- Blackstone Labs dust article
- Engine pinging
- car wont start, battery problem?
- I just shorted my new battery-did I kill or damage it internally?
- rant about sewell body shop
- Major Maint. Work at Lexus
- Accel Kool Blue Air Filter
- What oil?
- Service Manual
- Can anyone recommend a good independent mechanic in OC?
- Water pump - how long did yours last?
- Can someone help me out with oil filter?
- Seat Belt Help, Thank You.
- check engine
- Yes, there is such a thing as a non-remote master key
- could it be wearing out already?
- Battery questions?
- Replacing front bumper LS400
- GS 400 Oil Leak Help Fast
- Leak!! need help, Pics included
- Ignition coil out
- Where is my oil filter?
- Air Flow Sensor B1 S1
- 2nd Gen - Ignition system exploded diagram?
- coolant flush question
- DIY RX330 oil and filter change
- Where to buy factory paint?
- Bad Ride...How do I tell if I need to Replace the Springs vs Struts (not air) LS400
- Fuel
- Anyone Lengthen/Replace Battery Cables?
- ES300 cabin filter debris
- 45k maintanance
- Good battery for the SC and where to buy?
- Gen 1 LS reverse sensor
- need help on identifying a fuse (GS400)
- ABS/VSC/VSC OFF lights on
- try Blue Devil before??
- sc400 main o2 sensor removal
- A/C code 23.....??
- sc400 power steering info
- 91 LS400 all air suspension problem
- i did a bobo
- Very strange sound form head unit in SC400
- Vibration
- AC doesnt work...
- ECU pin out for 1st gen GS
- trani too full
- injector cleaner
- changing oil on '99
- 60 K Service
- 2nd Gen - Tensioner & Idler Pulleys...
- What do you think about oil
- seat belt problem help!!!
- excessive oil sludge
- Code 24 Air Intake Temperature Sensor??
- Help! which O2 sensors do I need to order
- AC Line Removal? Assistance ASAP
- Problem with replacing sparkplug while engine is still hot
- ABS Fuse
- A/C on a 1993 SC400
- 5 warning lights randonmly turned on
- Takin my SC300 in for a tune-up
- 132,000 miles on my SC400....what to do??
- Strong gas smell on start up
- DIY replacement parts.
- Toyota Parts Number List?
- Anyone know the low side ac fitting size
- How common is AC failure on first gen vehicles?
- Steering wheel locked 1991 ES250
- Does the check engine light come on for "engine maintenance"?
- Broke trans pan bolt
- Key stuck in lock position???
- GS300 60k revisited
- Timing Belt Replacement
- Tire rotation for AWD
- Need help finding tune-up parts
- tranny fluid change - dextron?
- Jim Hudson Lexus..NEVER AGAIN
- Service in Cleveland-Akron, Ohio Area
- Prepping advice for x-country trip
- A/C recharging problem
- coolant draining
- Hiccup when accel in SC400
- IS300 Brake Issues??
- 2001 GS300 Battery Replacement
- 86K miles service ? tune up?
- Oil Service cost a big surprise
- CEL P0770 error code. Help!
- SC300 Tune-Up
- Airbag Warning Light & OBD II
- Excellent Power Steering Rack thread
- Trac bleeding method
- Air Filter - Change Interval?
- ac compressor on/off too soon
- Low coolant light
- What grease to use on Window sliders?
- Extended Warranty
- Sevice Manuals
- Can Bad wires and plugs make you run lean?
- SC400 driver's side window cost?!?! please help!
- Strut Tower Bar Install Question
- cali people...with "engine" light on...for smog
- finally did it jump to synthetic oil
- 93 LS400 Brake lag
- 60K mile service gs430
- Evaporator bad
- lexus brake question...
