Broke trans pan bolt
Old Jul 26, 2005 | 07:53 PM
jag_600's Avatar
jag_600
Default Broke trans pan bolt
I broke off the head of a 95 SC400 transmission pan bolt. It appears I should just be able to drill out the stud or tap it and reverse it out . It is one of the middle bolts on the front of the pan. Looking at it, I believe I can do it without removing the pan itself.
Any have any experience with this?
Old Oct 12, 2005 | 10:53 AM
jag_600's Avatar
jag_600
I can't be the only one who has done this....
Old Feb 23, 2012 | 01:55 PM
brawls43's Avatar
brawls43
Digging up an oldddddddddddddd thread here... How did fixing this go? Did you drill it out and retap it or helicoil it? I was going to try dropping the pan on my SC400 trans and the first bolt snapped. Haven't even tried the rest yet.
Old Mar 1, 2012 | 07:42 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
you are on the right track... might not have to helicoil it... just drill it, run a tap... worst case scenario, then you helicoil it...
Old Mar 5, 2012 | 06:43 AM
brawls43's Avatar
brawls43
Got weirdly lucky. When I went to drill it, it actually threaded what was left of the fastener higher up into the threads. Having broken it loose, I press hard into it, reversed my drill, and it backed right out. So weird. Luckily didn't have to helicoil, just need to get a new bolt.
Old Mar 5, 2012 | 06:46 AM
mikecu's Avatar
mikecu
8th Gear
That is lucky. Now give us the lottery numbers.
YODAONE
Nov 22, 2017 06:37 PM
greens6
Jun 16, 2014 02:16 PM
PlotPoint
Jan 13, 2013 03:50 AM
MicahBerry
28
Jan 28, 2012 05:27 AM
Banshee365
Jan 4, 2011 08:36 PM
