- how much oil does your engine eat up?
- Sc300 and Gs300 engine compatibility?
- Replacing stock Cats with new high flow cats?
- Replacing Transmission Mount on 92 SC300 - New Mount doesn't Match
- power steering help
- obd1 code scanner?
- sc400 V8 manual transmission conversions?
- 3uz-fe swap
- Recomendations for my new SC..
- Very Important 1JZGTE 1st Gen Recall info!!!
- best 1j bang for the buck mod
- 100K Tune Up?
- trans dont shift until slightly warm??
- cel code 25 and 26 ANY INFO PLEASE?
- What do i need to do to get rid of my distributor?
- Sc300 Mods
- is my starter gone?
- Changed PS pum and car won't start
- serpentine belt idler pulley question SC400
- What does this vacuum hose attach to?
- GE buildup with GTE parts
- help!!!! anyone using this
- SC400 low idle
- Changing clutch
- sc300/supra master cylinder question
- Whistling intake
- whining / screeching noise when turning engine off
- WhereTB OEM crank pulley
- Problem with my SC300 staying on
- Rising Temperature
- How much power can the stock 5spd tranny handle?
- auto to r154 swap help
- Hesitation, temp problem
- 1JZ auto + NA ecu = ??
- SC300 MAF Resistor Pin Location?
- Does Soarer 5 speed have LSD
- started 1JZ swap and damn it!!!
- Budget Cold air intake
- Anothe power steering question.
- My 1JZ swap.
- Transmission
- charging system diagram
- SC300 tranny
- First post.. WHAT'S THIS CAR WORTH? - and other imponderables.
- TX emissions
- TX emissions
- Question for those with 1JZ swaps
- Heater problem
- got_trd's 2nd vid
- A/C Compressor question
- BLown Transmission
- what are the fuses for???
- Noob with 2 questions.
- car still wont stay on!!!! help me!!!!
- JIC Dual Exhaust (SC300)- Where to buy?
- sc300 cat and gs300 cat
- So I think it's time for an ATC.
- Clutch pedal stiffness and doesnt return properly
- HK$ Timing belt, worth it? Other related questions...
- Power Steering; yet another one
- high rpm exhaust smoke?
- What does a 4in Exhaust & DP sound like you ask?
- HELP NEEDED NOW!!please
- Harness question
- ECT Sport switch not working
- How come the SC430 gets a compressor?
- Whats going on??????
- what cams can i use for the 2jzge
- Which setup for daily driving?
- CAI installed
- Custon Exhaust system headers 3" pipe cat hks exhaust
- SC400 Motor-mount questions
- swapped 1jz dudes... can you still get ECU codes with US dash?
- Gas smell from enging
- Need some turbo advice please....
- How to Tune your SAFC I/II Courtesy of NPM
- What's missing from this list? (r154 swap)
- need a starter!
- 5-speed parts interchange
- Official SC exhaust thread! post up.
- 1992 SC300 5spd runs great at startup, HESITATION once warmed up..
- 1uz vs. 3uz weight
- sc 400 manual transmission
- Heater Problems
- Car hesitating. Used Seafoam and compression spikes.
- 1jz dyno runs
- Other make parts
- i got a damn light popping up
- catalytic convert hollowing/removal
- JDM To USDM Auto GTE into 99 Sc300 Swap Info
- Sc300 Jerking at 4000 RPM
- Problem installing shifter on a 95 SC300...
- ebay turbo?
- What is that light?
- Good sites for 1JZ/2JZ swappers
- driver side muffler
- something wrong with my car
- Too much engine/transmission noise from console area
- Tell me about the SC's traction control system
- idle rise and fall
- Throttle body question (sc300)
- Flashing Lights in console
- Wanting to buy SC400 99
- Auto>Manual conversion SC300 - What is needed?
- will IS300 5 speed trans fit sc300 5 speed?
- Supra TT harness
- 95 SC400 MAF Problem
- Weird problem with the sc...
- vvti motor in non-vvti car?
- Ever seen this 1uzfe clip?
- turbo/distributor clearence issues on ssautochome manifolds?
- what should i do??
- Immediate Help Please!!!!!!
- 1JZ Is In!.... But have some questions..
- Vaccuum Leak!
- Exhaust Questions on my SC
- HKS F-Con Fuel Management with 1JZ swap
- RDMS SC400TT-dyno results..
- 1jzgte parts....
- SC300 Muffler upgrade?
- SC300 NA-T Muffler choice?
- sneak peak before the big numbers come in
- Turbo kit??
- what you guys think
- Car requires two cranks to start
- HELP! possible ECU issue.
- Faster
- Transmission rebuilding, 98' sc300
- VPC resistor location for 93 2jzge
- Master/slave cylinder question.
- Help! S&S Headers, now no Start!
- intercooler piping route?
- 500hp civic or Lexus sc300-T
- Exhaust and Catalytic Converter questions
- all-motor route??
- Has anyone supercharge there SC300?
- Air In The System Need Help
- sc300 na-t
- aluminum 1JZ spark cover
- How many 1jz SC300/400's on this board?
- for the sc400 guys
- 2JZ-GTE swap into a SC400
- Dyno'd my sc4........
- Is this a good 1jz price?
- gt35 sc400 project (stuff)
- Anyone using SP's na-t kit?
- Preppin' for the 1jz swap
- Exhaust 4 99SC300
- Please Help Me Out WIth A Vibration Problem...
- Couple Questions on swaps
- So...I got a new starter....
- value of soarer R154
- Help!!!!!!!!!!!!!!!!!!!!!! (trac and check engine light)
- If you're new READ THIS FIRST!! Please Sticky.
- K & N intake kits
- sc300>400 transmission
- Central Jersey Meet 11/26!
- bypassing fuel pressure pulsation damper
- Help. What did I break?
- This is a stupid Question but.....
- Updates on my SC300
- Intake discussion, and BFI
- help with supercharger for sc400
- My 1st MOD
- important 1JZ swap info learned
- Price premium for 5sp SC300
- I need the NYC to help me on the come up
- So I dropped my girl off at the dealer tonight...
- weird start up
- convertin trannys between auto nd manual!!
- Random 1jz questions
- Vibration
- how much is this setup worth
- Intro, questions on Distrib Seal and Fuel ECU
- built AT on 98+
- Strange noise problems in sc400
- NX NXL and NOS Noszle direct port nitrous systems
- afc and f-cons
- New to the Lexus game
- SC having trouble speeding up
- Internals
- 1993 SC400 Heater went out this morning...Help!
- Which turbo for my car?
- Hypothetically speaking, what's a low mile 1UZ worth?
- Shifter Moves....
- Weekend work done... advice needed..pics inside - 56k Beware
- Exhaust Cap?
- Check Engine Light Coming On - 1998 SC 400??
- Radiator Blew
- Go outside and start your car, then................
- Steering growls somtimes
- So when did YOU admit to yourself that your SC had a problem?
- It has begun (again)
- TT auto tranny swap
- $5000 cash... what would you do?
- hello all question on performance websites
- Sc-400
- hks f-con
- What would be the best way to clean these (valve covers) underneath
- powdercoating vs. painting (engine parts)
- S&S Headers Install
- Now i need a clutch
- MKIV Supra shift boot = SC300 boot?
- passing emissions
- What is wrong with this picture?
- 1jz upgrade path
- Exhaust Question
- Headers and SRT on 99 SC400
- the revealing....
- Power steering hose
- Hks Vpc
- RMM downpipe?
- Is it worth the extra hassle of swapping a 1jz from a supra?
- for all of you who believed that stupid 1.5jz would work
- Is it normal to hear crackles after shutdown in the exhaust?
- Help Please , need expansion tank
- Need Help ...... Potential purchase of car with problems
- $1000 to spend... on what?
- Car won't start, could use a little help =D
- Thank you to all my CL brothers...
- VSC on 2000 sc300's
- Flex-a-lite 210 Install Guide
- different gasket kits?
- Any ever try a LS1 swap?
- Hmm, so I have the opportunity to get free Supra parts....
- size of bolts for diff drain and fill plug
- Squealing when AC turned on...
- Will this swap work for me?
- What to do
- SC300 Alternator the same as the Supras?
- my single turbo sc 400 (progress)
- noise in rear
- Anyone running this setup?
- what do u get with two honda injen air intakes?
- Help needed
- oil feed and return lines?
- replacment crank pulley
- SC400 auto can't shift fast enough?
- Project Finished, for now....(pics/info)
- i need traction!!!!1
- Shifter moves on acceleration and braking
- What clutch are you turbo guys running?
- What in the world is this?
- MAF question
- 6 speed in 99sc300
- strange sound and fuel smell at start
- 98+ sc4: resonator or cat???
- s&s headers + borla cat back
- harmonic balancer
- Anyone test their LExus with a G-Tech? I get 7sec
