- New European SC400 owner - Engine Problem?
- Question about Hooker Maximum Flow mufflers
- How to cure lifter noise?
- Anyone around here with the 1.5JZ swap...?
- Blitz Realize TT Exhaust
- Need help saying goodbye to my 95 SC300 Turbo
- Electrical
- Timing +- 25 degrees??
- my 2JZGTE buildup
- rear mount turbo idea
- acis..... ?
- What?!!! Another NA-T on the road?! PIX of my Na-T install!
- Car won't idle + a 97 conversion question
- SC300 vs GS300 - Need FACTS!!
- Late model SC400 LSD question
- 624 rwhp stock 2JZGE
- Tt Maf
- Opinions on the H.V.S.
- 2jzgtte wiring question
- car dying???
- 1JZ swap (general questions)
- newbie question?
- Best exhaust for the SC400?
- New Dual Exhaust, and other updates....
- o2 simulator
- starter contact points
- Torque converter
- Hi Flow Cat or Gutted
- I'm thinkin' it's about mod time!!!
- Custom Piping...what are the differences?
- TT SC400 race results..
- i need an oil change
- Oil leak
- engine running poor
- ATTN: 5-speed guys with loose/notchy shifts...
- Soarer with RB26!!
- sc300 headers
- Apexi S-AFC2
- JIC Exhaust Questions?
- what size pipe for exhaust
- FMIC Install Pics
- Hate the slowmatic? why not go clutchless shiftronic?
- What parts are need auto > 5 speed swap?
- Stalling on hot starts - easy troubleshooting (Searched)
- Vacums Wiring and oil lines for Na-t? help!
- NEED HELP ASAP - Clutch
- bolt pattern on 1UZ and R154 bellhousing (SC400 auto to 5speed project)
- NEED help to pinpoint problem
- heater question for 95SC300
- SC300 Engine vibration on idle
- SC400- "won't get out of its own way"!
- New Here,please Help heater not working thread
- e-manage wiring help
- fan switch sensor?
- power steering leakage
- How much power?
- 2jzgte question
- SC stock dual exhaust.....anyone know the weight???????
- How much whp is the 5sp sc300 making?
- SC400 Mid pipe. question
- update on turboing my sc: need some help
- Intake snorkel
- If you had 5 grand to spend...
- Tranny will not shift until warm? whats going on?
- Fan Bearing
- BFI underway... need help with decisions
- What tool for large lug under center cap?
- Car Wont Start !!??
- 2 quarts low . . . what's going on?
- Frame straightening
- supra downpipe and driveshaft on SC?
- power steering question (whine, fluid, etc?)
- Xerd header finally arrives!!
- This is one very clean 1UZFE
- Adjusting Transmission Cable
- Changed timing belt & water pump - Car won't start!
- 98 trnas in 93?
- First engine upgrades in CA
- ps system... really really bad plz help
- $134 supercharger adds 30 hp????
- What are obstacles swapping 2JZ-GE VVT-i into a pre VVT-i SC300
- lower compression of 1uz?
- EGR question and a little smoke...
- is300 headers work with sc300?
- Help!! Car stalls in this morning!
- Would a 5spd Supra Diff work on a SC400?
- What are the worst things you guys have heard about JDM motors?
- mumumumumumufflers
- forced induction?
- SC400 engine harshness increase
- Got my 96 sc300 Check engine??
- Car won't start, loud ticking noise under hood
- The Ultimate SC400 Question: Supercharge or Turbocharge
- SC300 Single Exhaust?
- Check Engine Light due to Intake
- Serpentine belt on SC300
- HELP: loud wheezing sound under the hood!!!
- Car dies when I press in the brake
- Heater problem
- SC4 Shifting probs
- electric fans on for 3 seconds???
- Current/future mods
- What goes here on the SC300 Engine?
- Need Intake Manifold Removal Guide for SC300 - Engine/Spark Problems again!!!
- battery problems?
- A look inside
- hummming noise?
- listen to this crap... sc is amazing
- stock spark plug gap on 96 SC400?
- intake and exhaust valve question
- performance chip
- SC400 Fan belt?!?!
- rear main seal
- shift problems
- power steering pump...best price oem
- Where can I get a Valve Body??
- for the second time in a row, I washed my engine
- BFI + Weapon R?
- Quad Exhaust
- power steering reservoir
- transmission whinning..did search
- bad ass twin turbo V8 crate motor just for some ideas
- Twin Turbo V8
- BL T61 Pics
- QUAIFE Sequential gearboxes
- More air = less power? Why
- To much transmission fluid
- leaking from the car
- Who's supercharged SC is this?
- low power, lots of noise, AND it's smoking...
- revisit to the dyno. 92 SC400 results
- car stalls after electric fan conversion??
- any advice on clutch wear?
- strange vibrations (no jokes please!)
- Whistle and idle problem?
- Engine Noise
- EGR location and Replacement
- Help with Valve cover gasket job
- newb here considering sc400
- Will the Dragon TC and supra lsd work for a 98 sc4?
- What's the best intake for SC400?
- idle
- Installed Torsen diff and 6-puck into SC
- One Piece Driveshaft
- need advice on mufflers
- Fuel Pump Location???
- overdrive..help please..sc300
- O2 Sensors
- Ticking noise from the rear what could it be??
- Engine not getting fuel
- need some advice...
- el chepo exhaust (free)
- 5-Speed Trannie Stall
- Need help from CL SC members
- Another Twin Turbo SC400?
- part numbers for certain items?
- Charcoal Canister ?
- Changing My Clutch, Ever Do Yours?
- Where can I get the Tex's Headers?
- exhaust
- Car starting problem...
- I REALLY hate my car right now...
- Question on a headlight
- Can someone tell me the size of these bolts? (plastic engine covers)
- SC300 2jz-ge into a SC400?
- I had a sqeaking coming from my belts. What else could it be??
- Trouble code 14
- Vaf
- 92-95 SC300 vs 95-99 Maxima (both 5 speed)
- About to order TRD LSD..questions
- SC300 5 speed conversion questions?
- Rear strut for SC300?
- Sc400 exhaust
- SC400 owners - Help Part 3 - OLT too!!
- Bolt on exhaust / muffler.
- Turboing a '92? Whats the deal?
- best place to buy cheap egr valve
- SC400 owners - I need your help
- considering buying sc400 but...
- WTB: Dragon TC for my SC400
- dave h NA-T kit
- Unsightly shifter in older SCs?
- New Turbo Manifold
- V-mount on an sc300
- What is a flex plate?
- Will TRD LSD fit a 5spd SC or is N/A auto Supra diff needed?
- 5 Speed Auto Tranny
- need to find a switched 12v source in the engine bay
- my swap! need serious help
- HP mods - what and how much did u gain?
- hard steering
- compressor problem
- Installed flex a lite fans *pics*
- Bolt On Exhaust for SC400?
- Latest pictures of the teardown.
- xerd headers
- Starting Problems
- Engine Management... What To Get First?
- TRAC light comes on when driving on freeway
- changing from park to drive
- Engine Block Heater
- Cat going bad?
- DaveH kit - Alternative to nonturbo.com
- Changing MT Fluid and Diff Fluid
- what kind of boost/fuel management r u using?
- EGR/Emission problems- Please help
- LSD users, weigh in!!
- is it legal?
- What is interchangeable between the ge and gte motors?
- IAC (Idle Air Control motor)
- fuel_filter
- x pipe or y pipe?
- Noise, tranny or PS pump????????
- 1JZ in a SC4?
- 6-speed or Auto
- Car Dies & Hesitation?
- Tranny is acting up...
- 1jz-gte vvti upgrade mods-???
- Strange Noise from Engine
- sc 430 rear end
- turbo kit or 2jzgtte
- How pracitcal is the 1jz swap??
- Who's running a LS400 MAF on their Turbo setup
- Some troubleshooting questions
- Exhaust Question
- i need some clearification..........................
- Loose vacuum hose???
- Engine swap.... do it myself or pay $1000?
- Soarer vs. SC300 Exhaust.... same?
- Fuel Pump Trouble
- Tranny shudder?
- Flex-a-lite fans are vibratin the ***** outta my car
- CAP AND ROTOR, cheap maintenance for better performance
- faint burning smell after changing water pump & thermo
- BFI intake redone from last time
- TT internals, will I need HG
- A'PEXi S-AFC on sc400?
- Newbie
- Water in Intake Manifold Spark Plugs
- Will the 91 LS400 engine fit?
- Egr
- Clicking when trying to start car
- Intercooler Kits
- labor rate to install Torque Converter
- Supra TRD LSD question
- DIY Starter Solenoid Repair
- Loss of Power turns into no start engine??
- 1996-1997 SC300 what aftermarket intakes are you using?
- SC4 Smoke/ steam?
- 1jz swap w/ ac?
