1993 SC400 Heater went out this morning...Help!
My wife's heater went out this morning. Has anyone had this happen before, and if so, where would you recommend looking to troubleshoot the problem? Thanks for the help,
Chris
Chris
use our secret weapon, it was talked about last week or so... Low water in the cooling system probably, or the $250 servo in the engine bay that u can use a zip tie to get heat, or bad fuse?....
probably just low water
Thanks again guys!
Chris
Originally Posted by ravencr
What do you mean?
Chris
Chris
The coolant level looks fine. When you hit the Auto button, the A/C comes on, then as I turn the temperature up to heat, it automatically turns off the fan and the A/C. I tried hitting the A/C button off and doing the same thing, and nothing changed.
Is this the servo causing this problem? If I turn the fan on manually, it just blows cold air with or without the A/C on. It's about 40 degrees outside here in Colorado.
The engine temps look normal, the fluid level is fine, and I need to know where the servo is located and where the fuses would be for the heating system. Anybody?
Chris
Originally Posted by MRAD
I have the exact same problem, any help would be appreciated.
Chris
Tantrix
01-20-17 05:41 PM
TTCUPS
Performance & Maintenance
02-15-05 02:52 PM
