sc 400 manual transmission
Registered User
HI, im about to buy this sc 400 92 with 80k miles. For some reason the transmission is breaking. Is there any manual transmission that i can get for the sc400, and which is it and where can i get it?
Thank YOU
Thank YOU
I dont think they have a manual tranny for the sc400.
But once I saw on tv ( I think it was rides) where they modified an IS300. I Was not a big Lexus fan back then when I saw this episode....
They took the engine out & replaced it with a 400 engine (something like that). & they somehow installed a supra 6 spd manual tranny with a few modifications. That was a year ago or two. I cant remember exactly.
They say its an is400 on steroids
here is the car I'm talking about. Hey maybe someone thats been here a long time can give you more info about this one.
but check this attached image. This is the car im tal\king about.
Rod Millen Motorsports
3UZ-FE
there is a guy on SF or clubna-t (maybe both) that has a supra with a 1uz and its backed with a 6speed. search around over there. if i remember right it takes a lot of modifying to get the 6sp in the tunnel but all you need is a different bellhousing to make it fit on the motor.
Hmm this sounds like a fun project. I might be changing my plans in the future for performance mods. Of course this is all just thoughts and no money to back it up as of right now but I think I've got some fun tricks up my sleeve.
I'm thinking TT 3UZ with Getrag. But the getrag might not fit as easily as we'd like it to in the SC. Oh man when I got some cash...
Now that I think about it after these few posts. I think it was on speed channel.
I remember a few guys with their laptop working on the ecu also . something about tricking the computer system of the car.. Man I wish i taped that show.. I'll try to find out if I can find some info on this subject.
Registered User
Do you think a Twin Turbo Supra engine would fit in the sc 400 for a swap, including throwing in a manual trani with the engine?
If yes which year supra engine would fit into the 92 sc400?
I know some one posted up a perfect write up on how to make your 1UZFE a 5 speed. They used alot of custom parts and in the end he didnt even spend alot on it. The 5 speed was used from an MK3 Supra. Search it up.
Ok i found some stuff its not iS400 its an IS430 (Koma is right) & its not on speed channel . It was tlc (rides with jason priestly) My mistake.
but its a nice article to read . check it out
check the link http://www.rodmillen.com/Is430.htm
Registered User
I read that the Soarer sc comes either 2.5 twin turbo or the v8.... which is more luxury than sport. So you think the 1JZ-GTE 2.5 tt engine would be able to be put in the sc 400 5 spd....
also can you just put a turbo on the sc 400?
I know about it but I would love to go a 6 speed route if it was possible.
from my understanding, the W58 bell houseing will work with the V160 6speed from the supra. there is supposedly an addapter to fit the W58 to the 1UZ. therefor you have the option of either mounting up the W58 or the V160 if you change the bellhouseing. ill try to find out who makes the adapter plate.
We have a few turbo SC400s on this board.
As for dropping 2JZ-GTE (Supra TT engine) into the SC400 it's possible and easily done.
Registered User
Originally Posted by Koma
Many people swap 1JZs into the SC.
Also where can i get a front clip of a 2JZ-GTE supra... or just an engine with the trani. Thanks
Zombie Slayer
UACS, welcome to CL. The questions you are asking have pretty much been discussed and answered over the years. The search function yielded these answers.
The manual conversion is doable but rather pricey. If you want to spend $2000 + in parts alone............
https://www.clublexus.com/forums/sho...l+transmission
Swapping a 1J or 2J in place of the 1UZ
https://www.clublexus.com/forums/sho...00+engine+swap
https://www.clublexus.com/forums/sho...ht=turbo+sc400
Turbo sc400
Enjoy!
Turbo sc400
Enjoy!
