- Misifiring... Electricals?
- Overdrive??
- Climate Control PROBLEM...
- I think my engine mounts are shot - what do you guys think?
- update on my 2jz-gtte
- Got my VPC
- na-t Supra 9.46@143mph
- How to remove the crank shaft pulley...help..
- I use the wrong tranny fluid. Need help please!
- 1uz-fe needs a kick!
- where is the intake temperature sensor
- does it really matters?
- Apexi s-afc On a 2jz-gte
- What do I need to get a sc300 into the low 14's
- water pump torque specs
- exhuast help
- Straight exhaust
- TT transmission is dead
- gs motor in sc4???
- Built 2JZ-Ge?
- New 2 the board and pulling a swap
- What do I need to change my timing belt?
- orders of mod
- Engine Mounts in SC 300 - What all do I need?
- transmisiion vibration?
- big problem need advice quick- alternator and battery is dead
- hesitation
- finally got my jdm 2jzgtte in!!!!!
- MLS Eye Candy
- Hks Vpc
- Engine CEL Code 28
- Location of the power steering ECU in SC400
- Replacement Clutches
- V8 manual & V8 turbo!
- Gm Dis
- Turbo Kit Installed...
- Is the 2jz-ge an interference engine?
- cat gasket?~!~!?
- ? about injectors
- SC300 Weight Reduction Worksheet
- PHR Alternator for sale
- tune up
- anybody know where to get soarer shift linkage??
- The end of the road for me
- magnaflow 14829
- SC400 Tranny!!
- car hesitates when accelerating hard.
- sc300 radiator fit in sc400?
- Whats the best turbo for street and Drag?
- A short story, a thanks, and a question
- 92 SC300 5-spd...Vibration
- Power Plan... The Best Path?
- how many cranks or turns does it take before your engine starts in teh cold?
- I hate CALI, they won't do my exhaust
- problem with magnaflows
- Belt pulley came OFF while I was driving?
- SC300 Cats - Pre & Main?
- Misfire
- Trac off light came on.
- electric fans low budget setup???
- When does it end...
- SC300 auto to Stick swap
- AT what throttle setting does the 97 sc 300 change from open loop to closed loop?
- i'm stomped
- SC3 Parts interchangealbe with Supra
- Overheating Problem
- overheating (but recent flush/fill)
- Friction Plate
- auto to getrag 6 speed
- Engine Management Options, and fuel setup ?
- Need help with misfire!!!
- Anyone here with a 96 or newer done the ECU upgrade?
- SAFC Fried?
- SC vs Supra Parts
- Need Suggestion on Timing Belt Types
- Car won't start in the morning
- Car died while driving. Please advise.
- sc300 exhaust
- Punching Cat
- Post exhaust install 600 mile trip
- Compression in motor -> Vibration = rebuild?
- Magnaflow exhaust
- NA-T: which one is more reliable?
- Does the SC4 have slots for clutch cyl like the SC3? 5 spd
- (iat) Intake Air Temperature
- LSD Swap Questions
- Acquired 94 Auto Supra TT diff, now I have some q's
- Need info on 1jz swap
- Weird loud FAN noise at idle..what the heck?
- those with swaps... do you still have AC?
- For those with 1jz's
- GTE Swap Progress
- car starting weak
- toyomoto ?
- Optima Yellow Batteries
- Ignition mods
- why is my car so loud?
- Another Head Question
- rev limit? speed limiter in our cars?
- oh man... more noise...
- front pipe
- JDM question????????
- Spark plugs...Which one would you use??
- Doing my exhaust with Magnaflows, and running into problems...
- help battery problem!
- Cat elim pipes
- 98-00 SC300 2jzgte possiblity?
- Use of N/A & N/A-T
- MKIV and SC300 shift knob fitment?
- Intercooler piping question
- Are 1jz/2jz harmonic balancers the same?
- Oil Pan
- injen intake for a 96' sc300 will it fit??
- Spark plug wires not lasting
- Ultimate Lexus Guide? Legit?
- Dragon torque converter
- Supra Exhaust
- Please help! Bad fuel?! (SC300)
- Egr Faq
- BFI and Torque converter upgrade on sc300?
- How to make a clean factory looking BFI DIY
- power steering leakage...common problem
- guys, need yr help to find the link..
- SC300T Vs. SC400T
- Electrical problem!!
- strange ticking noise during cooloff
- custom exhaust
- I Need Help Fast!!!!!!!!!!!!!!!!!!!
- Apexi safc-II
- guys, need your opinion on this...
- advice on an intercooler
- How to maintain motor over 60k
- computer and TPS questions
- dyno results after sound performance
- sc300 engine question
- Power Adders for SC400?
- 1jz or 2jz
- Need help pruchasing new radiator for 95 sc4
- Got wheel, auto transmssion upgrade, question ^^V
- bfi and headlights done! pics up
- Check Engine/TRAC off Lights came on...
- Can I use the Meziere electric water pump?
- Transmission Question
- W58 1jz bellhousing
- installing fuel air ratio guage
- Very new to this 1jzgtte swap to a sc300 need help plz
- sea foam brake booster line
- PS pump and alternator
- motors
- Radiator Light , and Battery Light
- Engine shut down whenever AC turn off
- Vacuum Noise Under Hood
- Need help on installing Ground Wire Kit
- This Sucks!! Smoke.....
- Installation of S-AFC? Need opinions
- 5-speed tranny shaking?
- Greddy 4 row fit in front of sc300?
- I'm very close to getting rid of my SC....
- sc300 distributor install
- 2 types of Catalytic Converter ???
- ...and behind door #3, my next mod! - clutch replacement
- squeaky clutch?
- Jerky SC 300 Transmission-Automatic
- Automatic shifter change
- auto tranny drain and refill capacity SC400
- sc400 turbo
- ssc300 5 speed tranny into a auto sc400
- SC300 Morning start problem
- Any intrest in BFI templates drawn in AutoCAD?
- how knows about the 400 drive shaft in the gte swap and what do i need??????
- remote mount turbo
- Diagnostic code #12, no RPM signal on 1JZ swap
- lost power
- Throttle body position sensor voltage output
- New NA-T project
- Changed plugs yesterday- have a guestion
- For those looking to do the BFI with velocity stacks...
- sc300 resonator length
- sc300 reverse to drive clicking noise help!
- catback exhaust questions for the turbo guys
- SC400 Supra Tranny Swap
- Harmonic Dampener pulley broke off, now what?
- Catback Exhausts
- Is Your Transmission a Slow Learner?
- Turbo thoughts, costs
- General SC Questions-Transmission shift knob shaking
- Electrical problem?
- Really weird engine noise?
- TT auto transmission into GTE swapped SC300
- V8 Picture
- Cheaper to modify stock exhaust or get a Borla?
- This may be a stupid questions, but...
- Can flowmaster mufflers be put on SC400?
- HKS Cams
- ECU differences, compatibility
- SC400 having stuttering/shaking problems
- Manual Mode?
- Car hard to start!..Code 78!!!
- Bad ECU? not sure... need expert advice from SC guys
- I just cannot decide what to do
- vvt-i
- Engine mount question
- Anyone removed ignitions switch? Or have a FSM??
- MSD 6A install - Pictures & Info
- Could a/c clutch cause loud belt whining sound???
- how to change alternator on SC400 ??? please help asap
- powersteering death whine?
- exhaust system
- throttle body, maintenance cleaning
- AC clutch throwing sparks. Help.
- Ractive exhaust concerns
- HKS Pod Filter Q?
- Got 97+ Refresh Fog Connectors? You do now!
- head swap
- Old newbie need answers
- Magnaflow HI-flo cats?
- 97 sc300
- SC300 motor hunting help..
- looking for an older model sc (I KNOW NOTHING ABOUT THESE CARS! )
- "X" pipe
- where to buy GTE head gasket?
- sc300/sc400
- Battery check light
- SC300 and 1jzgte swap
- in search of an exhaust system
- More LSD questions
- Mainfold cracked on turbo engine, help? (thread edited to be a bit more creative)
- Shaking
- Nos fuel pressure tap for sc400
- Will 1JZGTE work with W58
- Clutch wont disengage.....
- weird thermostat happenings..help!
- Anyone ever get the C's short shifter for the SC300 (NA Supra)?
- Replace Tensioner on SC400
- anybody have info about CAMS?
- Clearance Under the Hood
- Blown 1UZ - Some talk, Some do....
- differential hex bolt size
- Hole in exhaust
- Weird compression test results.
- ijz-gte
- got my "jdm" mufflers today.
- rmm intake
- sc400 2jz-gte swap
- What should I do with a 190K old engine?
- high idle after tb cleaning
- Yes, another power steering problem
- 1jz-gte auto to 6-speed swap info
- Loose rear drvers side wheel
- WILL A 95 SC 400 POWER STEERING PUMP WORK WITH A 92 sc400
