- Try to start and every thing dies
- Undersize tires
- Have some problem.Please Check in.
- 1991 LS400 engine bay noise ( with video/soundclip )
- Wheel Sizing 101
- Bigger rotors for LS400 Calipers?
- Did a spirited run and pulled into driveway and car sounded like a truck....
- Fix 91' dash needles.... in Canada?
- TRAC light on and Check Engine light on, please help
- 98LS400 slow/half nonfunctional rear defrost
- Wheels upgrade
- LS400 caliper rebuild (4 piston)...retaining ring or no ring?
- transmission question
- How to fix a drooping center sun visor
- Rear crankshaft oil seal leak
- Master keys locked in trunk, how do you trip the remote switch?
- To you guys that installed sub using stock HU.
- AUDIO PPL Please Help!!!! pioneer double-din wont power up
- 1995 LS400 Power ECT button
- Need radio help?
- 95-97 Ls400 wierd Radiator fluid leak? Help???
- Will other OEM Lexus wheels fit?
- Fluid flush order?
- Timing belt 00, ls400 need help
- Replacing struts, KYB or Strutmasters or?
- need help asap plz car wont start
- 96 ls400 whole front vibrates
- 93 lexus no power anywhere
- rear fog light?
- 94 5 speed swap in progress
- Windows (not working, 1LS)
- New here and new to these cars help wanted..
- New to Ls400 and the forum
- A series of possibly daft questions
- EbayTiming Belt Kit
- Good deal on '90 LS400?
- ucf10 & ucf21 brake booster & master pump compatibility
- Power steering pump
- Brake Job Question--Where does this washer go?
- Battery or alternator?
- new on forum
- Question about "Check VSC" causing CEL to come on
- 1998 LS 400 - Replacement Shocks Advice
- Anti-lock brake question...
- '96's temp guage jumping around
- Thinking of purchasing this '98 LS 400
- Installation of Rear Sway Bar Links
- Help, Air Bag light keep on even key is taken off.
- DIY 91' LS 400 Recovering front seats
- I didn't search but.. 18x8.5/9.5 +6?? (ucf20)
- ls400 steering wheel
- Front brake strut
- Rigged UCF20/21 Pics
- Thanksgiving story (Tire related)
- Buying used advice: 1996/97 vs 1998
- Chasing a Code 14
- exhaust mod.... free!! (damage)
- Happy ls400 owner
- Intermittent hesitation, no acceleration, no codes, but everything checks out...
- Heater issues
- Help (Temp. gauge, tach gauge and gas gauges)
- Bad ECU confirmation
- new to forum and the celsior.
- Pulled EFI1 and EFI2 fuses to reset computer, now got check engine light and VSC off
- Leaky Oil, Dirty Bottom
- '94 Rear windows
- wrong temp reading
- [1999] ls400 car wont stay on
- TRAC/Brake Fluid flush with DOT 4 ?
- 92 LS 400 car starts, but then shuts off immediately
- Considering a 1st or 2nd gen LS 400 - What do I need to know?
- '96 LS400 transmission behavior?
- 1992 Ls400 a/c expansion valve
- 1993 ls 400 driver seat
- 1992 Ls400 radiator fan
- Question about some ghetto headlight wiring
- LS acting up!
- Napolex.com out of business or what?
- Rear Trailing Arm Bushings 99 LS
- Thinking to buy 98+ LS400....
- Newbie Here, need help with my 1996 LS
- Wipers worked yesterday, now they don't...
- LS400 climate LCD dead. What temp am I at?
- "VSC Off" and "PWR ECT/SNOW" Switch Light
- Our 98 LS400
- 91 ls ecu
- ls400 acceleration issue
- Front seat feels like it is shifting.
- Got some work done now my power seems down!
- LS400 1991: Disconnected the battery and activated the engine kill switch... help!!
- green tint on a 1stgen?
- 91' LS 400 Recovering front seats
- lexus emblem came off
- LS400 used parts source?
- My '97 LS400 woes from last night:
- Wire next to Oil Filter and AC Compressor
- Flashing ECT/PWR light on 95LS
- Has anyone ever replaced a steering shaft u-joint here?
- A cracked ventilation hose on my 98 Celsior
- I have a problem with the dashboard
- 93 LS stalls when warm.
- noob from east tn
- Gas smell
- a heat quetion
- heater,radio not working
- Just bought my '93 today, have a couple questions.
- Dreaded - ABS and Traction Control Light
- Double Din Install Help Needed
- LS 400 - Smoke from ATF an now Power Loss
- Spring Rates
- Offset?
- '92 Gearbox clicking!
- New Member Here Got the LS Fever
- Help-car won't start due to stock alarm
- Rust treatment for 1992 LS400?
- sunvisor and headliner removal question
- Gas mileage issues, help!!
- 90-94 ls400 repair manual
- How do you get the "trac-off" light to quit blinking
- Just a shared cost on getting new spark plugs / wires
- Wheel FITMENT HELP
- What's this engine cover? (92 LS400)
- Tie rod replacement costs?
- Trip a / b
- Power steering idle up valve
- passenger window problems
- '94 LS400 - Head Unit replacement w/ stock amp.
- fixed fuel smell in cab at fill up but found corrosion on fuel tank.
- TRAC and No TRAC Clusters, Interchangable??
- idle problem
- 1991 LS400 Starter pics and more
- Anyone ever put projector headlights in a UFC10?
- LS 460 Wheels on 91 LS 400
- 95-97 ls400 conversion to a 98-00 ls400
- Gauge cluster problems 95 ls400
- 1993 lexus ls400 issues
- someone hit my ucf10
- Another Gen I suspension ?
- Transmission Slipping
- recently lowered 97 ls400 making weird noise
- Will the SC400 pioneer sub fit in my LS400? Also a car audio question
- motor/trans mounts
- New guy here! ^.^
- It is time
- 1992 LS400 Power windows and moonroof don't work
- 96 LS400 power door locks wont work...
- Sunroof seems to be leaking
- Megan EZ's on UCF20/UCF21
- seems to me (1LS electrical issues)
- Wierd Weird WEIRD!!! Tilt Stering
- Steering Wheel Tilt Motor Inoperative
- Ordering new fanclutch, Lexus part or Rockauto part?
- 1995 LS400, New Member w/ Pics
- Identify my old radar detector??
- i shaved.... kinda
- Normal Idle?
- Brakes went out
- Front/Rear Personal Lights
- I Need Help With My Unfixable '90 LS.
- How much is my car worth today? 94 LS400
- Rear air suspension stuck
- supercharger anyone?
- Cam Sensor
- Lowering a Strutmaster's Spring/Strut Conversion with Tanabe Springs
- Battery For A Ls400 1994
- vibration on my 99
- Which of these fees are legitimate!?
- Help No Tail Lights
- 98 ls400 valve cover gasket replacement tips
- I have ABS but it does not work..though no error light or fault is shown...
- Tie rod package
- 1305 code
- Oil on my ac compressor
- Hello! Door Handle Question
- Key FOB Question???
- strange coolant leak!! please read
- Need Help - '91 Strut rod bushing
- A couple key replacement questions!
- Hi there!
- How do you tighten to torque specs??
- 1995 Lexus ls400 fuse box diagram picture?
- 94 LS400 Coldstart need to warmup 5 min or it will die
- Wood/Leather Steering Wheel
- 95-97 Sideskirts/Rear bumpers compatible with a 98+ LS400 ???
- 91 ls400 replacing both inner and outter tie rods
- new and have a clean one here
- Super weird radiator problem *PIC*
- 1996 star sapphire pearl ls
- Air Suspension Controller
- How to fit 22s on my 95?
- nob under drivers side kick panel?
- need new ball joint nut
- 1993 MotorWeek V8 sedan comparison test vid
- New in the Club!
- 20" Wheels on UCF10
- 93 LS400 weird starter "clacking" sound..please help
- Did lexus and others stop selling the front strut rod bushing?
- Rack and Pinion problem 1995 LS400
- Finally got 17" 6-spoke LS430 wheels on my '99 LS400
- 91 LS400 Front end shakes violently at random
- Newb in the House! Greetings everyone!!
- Uf10/uf11?
- Water Methanol Injection?
- 91 LS400 powersteering pump pulley
- Help! upgraded to nav now no antenna raise
- New member with 93 pearl white/black leather
- engine vibration @ 1200 & 2000
- UCF21 Annoying Flickering Foglights
- Ucf21 beatsonic double din install kit - woodtrim?
- Who can make a key to my LS400 95
- Aiming Depo Headlights (UCF20)
- Headlights getting foggy
- LS400 lack of tension on retracting seatbelts (front)
- Timing Belt
- How much does a cluster cost?
- Timing belt @ 118k
- Newbie with a 95
- power steering fluid, need simple confirmation (read the bible)
- (WTBs go in the classifieds...)
- Both power seats don't work?
- 20/21 stock spring/strut measurment wanted.
- Options for tighter steering feel
- 95 ls400 guage cluster not lighting up??
- anyone have the 350z track edition wheels on their ls?
- Stabilizer links just don't fit snugly...?
- Ls400 and winter prep mode.... Snow tires and coilover reccomendations
- LS 400 XF10 1990 vs 1993
- Crown Emblems for LS400
- start up run on starter ,seasonal
- Please help, not getting heat!! 93 LS400
- 95-97 Ls400 Led tail light problem,help?
- UCF10 Replacemeant seat cover
- 98 ls400 low idle / suggestion
- How To tell if first gen LS400 has air ride
- hankook optimo h727
- Just bought my 1st Lexus (94 LS400)
- cant find leak
- Little photoshop action, which do you prefer?
- Has anyone repaired cracks in '99 LS steering wheel?
- Does one need to pull engine to replace upper oil pan gasket?
- Rotor questions?
- bendix/ starter won't stop turning
- Anybody know what this is ?
- Pinging on light acceleration and cruise control at 60 mph
- newb questions
- UCF20 - navigation cd
- Another EGR issue
- New Lexus (1990 LS400) owner
- traction control being affected by ride height?
- UCF21 Headlight Aiming
