Flashing ECT/PWR light on 95LS
Old Nov 14, 2011 | 04:34 AM
atlls400's Avatar
atlls400
Default Flashing ECT/PWR light on 95LS
I just want to thank everone on this site for all the tutorial and tons of info on here
I've had this car for about 2mos now and have already done alot but I know it has just started.
Recently my ECT Pwr light has been flashing.. I try switching back and forth btwn the diff modes and it won't let me do anything until i Turn the car off and maybe it will or won't come back on,
Doesn't really effect the way it drives though.
Anyone else have this issue??
Old Mar 15, 2021 | 08:25 PM
UCF21's Avatar
UCF21
I'd hate to be that guy but I'm going to bump this cause I'm having this issue now.
Car starts fine, as soon as i give it a little acceleration over 2k lets say the car just decides to limit power on take off
and flash that little pwr light on my dash.
If it matters, it is a 95 Toyota Celsior.
Old Mar 15, 2021 | 08:43 PM
sdls's Avatar
sdls
Since it’s a JDM vehicle it won’t work with a typical OBDII scanner. Perhaps you can retrieve the blink codes. Sounds like something going on with the transmission?
Old Mar 16, 2021 | 12:42 AM
Yamae's Avatar
Yamae
The paper clip method is just the same with a LS400 and all you need to do first is to read 2 digis TCCS code as sdls suggested.
Old Apr 27, 2022 | 04:48 AM
muluwe's Avatar
muluwe
Default Flashin ECT pwr
Check 10amp ECU/IGN fuse inside the car on driver side door panel it's must be blown I had the same issue some time back
Old Nov 30, 2025 | 02:11 AM
Establishment1cy's Avatar
Establishment1cy
6th Gear
hey man did you end up figuring out what the issue was? im in the same scenario with my GS
Old Dec 1, 2025 | 02:31 PM
CELSI0R's Avatar
CELSI0R
You should probably post or create a new thread about your issue in the GS forum for better help. It looks like you have a 2nd Gen GS
When you post, make sure to include any codes you currently have. I assume you already checked the ECU/IGN fuse as was previously mentioned in this thread (I know it's an LS vs a GS but the engineering is similar)?
wickedtaco
Feb 15, 2017 04:53 PM
Romulus8th
Oct 30, 2009 11:51 PM
DVac3
Feb 8, 2008 01:09 AM
snidehocke
Jan 29, 2008 05:20 AM
southtrian
Mar 21, 2006 08:05 AM
