traction control being affected by ride height?
Old Oct 16, 2011 | 12:35 AM
whit3b0y's Avatar
whit3b0y
Default traction control being affected by ride height?
I need some help! I Went to a stance meet, on my way i drove over a few steel plates in construction zones. when i got back my RR strut was making noise and my lr was making a rubbing noise. So. i raised the car and took it in for an alignment and oil change. car drove fine no problems. After oil and alignment i lowered the car. back down to 24in from ground to top of rear wheel well (was previously at this level before stance meet)...
took the car for a test drive and every left turn the rr tires drops power and then peels out when exiting the corner. turn the traction control off and it just peels out through every left turn. right turns are fine. car was 24in from ground to the top of the rear wheel then 24.5in now 25in.
Old Oct 16, 2011 | 01:37 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
is it even across the axle?
Old Oct 16, 2011 | 08:48 AM
whit3b0y's Avatar
whit3b0y
yea. i made sure each time it the same height cross axle.
forgot to mention i have old school jic's....
is it possible to bust a pillow ball off the shaft? that would explain the niose and allow the axle to slide side to side causing the vsc to kick in and dismiss power through the corner....? does this sound logical at all to anyone? wondering if my thinking is correct. is there a way to fix this, or delete the pillow ball. otherwise its stock suspension through the holidays
Old Oct 16, 2011 | 10:48 AM
PFCTTZ's Avatar
PFCTTZ
total wheel tire size will effect traction control...
Old Oct 16, 2011 | 10:07 PM
whit3b0y's Avatar
whit3b0y
Pretty sure that I was atleast partially correct! tonight put on my stock struts with tanabes in the rear(talk about rake!). Took it for a test drive and can rally a corner and tires only spin if I want them to! No problems with the VSC! Now i just gotta figure out how to fix the rake. looks like rodded out 70s malibu.
Anyone know if you can put the front struts in the back, they are shorter and that would drop the rear some. would i need to swap top hats or anything? from looking quickly it looks possible.
Old Oct 16, 2011 | 10:34 PM
PureDrifter
BahHumBug
CL Folding 100,000
the damping would be way off since the fronts are damped to compensate for the motor weight....
Old Oct 17, 2011 | 08:42 AM
Hilux22RE's Avatar
Hilux22RE
So if Larger than Stock wheels are Installed it Affects Traction Control??
Old Oct 17, 2011 | 10:09 AM
whit3b0y's Avatar
whit3b0y
Didtn think of that, maybe i will look into swapping my jic springs over. Have factory rear strut JIC FLTA springs with factory front top hats.
Generally it would be smaller wheels, Smaller wheels have a shorter rolling rotation and less rolling resistance. ie they are ganna spin easier. Witch through a series of sensors can be read as loss of traction. In that situation vsc or traction control will step in and reduce power to compensate for the loss of traction.
Old Oct 17, 2011 | 12:49 PM
PureDrifter
BahHumBug
CL Folding 100,000
this doesnt sound at all like a traction control issue, it sounds like you're dog-legging the car on corner exit because the rear suspension doesnt have enough travel.
Old Oct 17, 2011 | 04:22 PM
Hilux22RE's Avatar
Hilux22RE
So going Larger Wheels Wont make a Difference??
Old Oct 17, 2011 | 04:57 PM
PureDrifter
BahHumBug
CL Folding 100,000
you say you're on old SF1s, arent those single-tap coilovers? that could be it...
tarponman
RC F (2015-present)
15
Mar 18, 2021 01:40 AM
KING
Nov 24, 2014 02:18 PM
VNN326
Suspension and Brakes
Mar 22, 2010 05:46 PM
sojah
Oct 20, 2009 11:06 AM
FITYSCENTS
Jun 26, 2006 02:16 PM
