Help No Tail Lights
Old Oct 31, 2011 | 12:10 PM
Hilux22RE's Avatar
Hilux22RE
Default Help No Tail Lights
I Recently Performed the Fog Lamp Mod On my UCF10 With Success. But now i have a Major Problem.. I Don't Have Parking Lights Or Interior Lights (With Exception to the Cluster which works fine. I Check all Fuses and do not have Power going to the 7.5A (Panel) and 15A (Tail) Fuses.. I Check all Connectors under the Fuse box and Even Undid the Fog Lamp Mod with no Results..
Anyone have a Bit of Insight on this...?
Old Oct 31, 2011 | 02:08 PM
billydpowe's Avatar
billydpowe
undo what you did and see if you are back to normal.....
Old Oct 31, 2011 | 02:47 PM
Hilux22RE's Avatar
Hilux22RE
I Did i put everything back to its Original State. and i got nothing
Old Oct 31, 2011 | 04:07 PM
sethjon's Avatar
sethjon
There are no coincidences. You either unhooked something umknowingly or you broke a wire when hooking it up.
Old Oct 31, 2011 | 05:03 PM
timmy0tool's Avatar
timmy0tool
if you don't have power to those fuses, go from there. did you replace the fuses?
Old Nov 1, 2011 | 08:40 AM
Hilux22RE's Avatar
Hilux22RE
I Checked and Double Checked.. i even left it taken Apart.. Checked all the Wiring Twice and its the Same Thing.. Im going to wait for the New Headlight Switch i Ordered and going to test with that. We Will See whats up..
Old Nov 1, 2011 | 11:24 AM
Hilux22RE's Avatar
Hilux22RE
Update: New Headlight Switch and Problem Persists.. i check all fuses again replaced both of them and Still nothing.
Old Nov 1, 2011 | 12:25 PM
3UZFTE's Avatar
3UZFTE
Don't guess, get an wiring diagram and find out what give power to what and where and what wires your dealing with, go to. So those 2 fuses do not have power going to them, it should be fairly easy to trace the wires back to the power source.
Old Nov 1, 2011 | 02:45 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
uh oh, what did u do mang!
Old Nov 2, 2011 | 08:08 AM
Hilux22RE's Avatar
Hilux22RE
Right Above the Fuses there is an "Integration Relay" It Turns out i Must have Shorted that in some Strange way.. Going to replace today.
Old Nov 3, 2011 | 09:56 AM
Hilux22RE's Avatar
Hilux22RE
Update #2 (Final) : Integration Relay was Replaces and i have Parking Lights Once more. it was a 6 Dollar Repair getting the Relay from Ecology. So im Happy now.
sj408
Feb 14, 2016 04:23 AM
SpadedOne
Apr 1, 2015 02:54 PM
SCYAL8R
Apr 1, 2013 09:07 PM
mkultra
Apr 26, 2011 03:01 AM
mdwags
RX - 1st Gen (1999-2003)
Jul 14, 2009 09:18 AM
