- K Sport UCF20 coilovers on UCF10?
- 2000 LS400 arm rest squeak - how to remove?
- '93 LS400 noise comming from rear wheel
- Front strut reinstallation - Help!
- 1994 Lexus LS 400: Starter needs replaced?
- Coilover question
- '93 LS400 noise from engine compartment
- window motor/ loose connector HELP
- 1994 LS400/when cold transmission feels like its slipping?
- Almost 100k Miles
- Is it just me or .....Electonic Control Throttle-surging
- ls400 need help
- pulley belt tensioner
- New To Me LS400
- steering play
- An ECU question
- Exhaust modifications
- Exhaust tips
- 92- LS400 weird engine sound.
- Painted Factory 90-94 LS400 Rims?
- warm and cool air at the same time (1996)
- Considering 95-97 LS400, common issues?
- green glass
- interior and exterior ls400 2000
- After a rain, the car runs horrible(?)
- Saying good by and hello RX family
- 1995 LS400 wiper arm access
- Stereo wiring Schematic '99 Celsior
- General Questions
- Some cluster lights comming on?
- Looked for exhaust leaks, now car pulsates
- JDM vs USDM 1UZFE VVTi questions
- Car Overheating LS 400
- New here- first LS!
- Question about wheel bearing
- 92 LS400 Rear Susp. Bushing
- Gen 1 front suspension
- how to compress the front caliper pistons
- Need Help-LS400 stuck in park, dash lights out
- 1994 ls 400 : Front coil springs
- Road noise
- Flickering Cluster: Does Anyone Repair Them?
- My 1st lexus - '98 w/200k
- Dashboard electrical problem. (Vid included)
- Turbo sizing
- ucf11 steering problem
- LS400 outside Door handle
- Cluster Change 90 to 93-94
- It feels like the transmission jumps into neutral
- TOYOBD1 and its wonders.
- 93 running rough. Need some insight.
- Labor cost 94 ls400
- Best aftermarket LBJ?!?
- Yamae question
- 1999 Celsior Radio Cassette Part number
- 1UZ swap looking for new dif setup
- Are mismatched tie rods OK?
- Interior Interchange???
- Alignment necessary after strut replacement?
- Compressor problem or leaky ECU caps?
- First gen vs. second gen front bumpers
- Power Steering Geyser From Reservoir
- What are the beginning signs of power steering pump failure
- 1990 Celsior UCF11
- Coilover tool help
- HELP: Fender removal
- Power steering reservoir question. 00' LS400
- timing check on '92 LS400
- 1997 LS Crankshaft Position Sensor Help
- First Time Buyer Tips
- 94 radio bull****
- UCF-10 Car Phone?
- Need help -Error Codes on ls400 1998 - p0420, p1126, p1129
- 1992 LS400 factory camber adjustment
- Avid.1 AV50 on the 1992 LS400
- UCF21 Climate Control Unit Smoking !!
- ls400 acceleration issues
- What Does A Million Miles Really Tell Us?
- Wanted: feedback from those running aftermarket UCA's.
- '92 LS400 -motor has missing problem
- 96 lexus ls400
- Anyone have a pic of the Low Beam cannon plug/connectors on a 95-97?
- Just a bought a new LS 400
- Rear Strut replacement cost
- 99 LS400 Upper ball joint replacement: control arm needed too?
- '99 Celsior. Changed battery now won't start
- Oil Change--They put in wrong kind?
- 17 years of great service from my 1991 ls 400
- Limp needle fix (impact)
- LS400 valve adjustment shim diameter?
- New struts - buy whole assembly or just cartridges?
- 98+ bumper On 95-97
- '92 LS 400 firing order needed
- Maintenance Question- 41,000 miles, TB/WP never replaced
- help finding a part number, or name! ls400 trans sub-harmess
- No matter how huge the wheels.I love this
- Headlights come on by themsleves...ideas?
- Invisible Audio Elves Fixed My Nak
- Need help finding intake torque specs
- Transmission groan/whine. Strainer clean.
- 1998 LS 400 Headlight replacing/removal tips NON-HID
- Fully Loaded !
- Changing it up a bit
- Car starts runs for an instant and dies
- Fog lights
- Speedometer Diagnosis
- Ticking/tapping/clacking 1UZFE?
- need new seats? 1990 with cloth seats
- H & R Springs question
- Fuel pump relay resistor
- El Cheapo Parts On eBay
- Tire Help re: 2000 LS400 with 18 Inch LS430 Wheels
- cd changer error 21, now working
- 1995 LS400 differential bushings shot? with pics
- Brake/stop light bulb in tail lamp - how to remove?
- 90 ls4700 - stall out every 5-6 secs
- Coolant bubbling in reservoir
- Help: Rear brakes and rotors
- Radio Fuse Location
- What do you think I cooked this weekend? (Electrical)
- Changed My 1995 Ls400 Fuel Filter Today
- Power tilt steering wheel noise
- Identifying leaky EGR pipe
- Different Power Steering Failure! New Unsolved Topic! Help!
- Hello going to look a 95' LS400 today
- Blowing 15A fuse #36 1995 LS400
- Hello everyone, I'm Jon
- Rob Ferretti driving my LS
- LS400 98 vvti engine swap to 95
- going to look to buy LS400
- Question about front corner lights
- horn wont stop help me diagnose
- Oil spewing in front of oil pan, bad seal?
- Wait... Did my AC just suddenly go out???
- Steering Linkage Question
- Timing Belt Hack - 1995 LS400
- 1993 ls400 oil pressure
- 96 lexus ls400 - 22's fit?
- Ignition Switch..I think? HELP ME PLEASE!! NEED INSIGHT!!
- Blowing Alternator Relay - LS400
- Tilting wheel kills car
- Tune up parts ?'s
- 99' Cracked Outer Door Handle
- Considering purchase of a 1994 LS400
- I can only go in reverse
- Coolant blocking plate leak, 1999 LS400
- Good places to buy 98-00 LS400 and Timing belt questions....
- from 1 acura to 2 lexus! new guy here!
- 26th Anniversary of LS-400
- 98 LS400 broken airbox/vacuum leaks
- Tanin electronics
- LS400 Tranny Solenoid Cleaner?
- Help with possible timing belt poor installation
- Cluster board giving out ??
- so I think I'm going to need a power steering pump soon.
- Stereo -Pioneer to Nakamichi?
- Burning smell in the Cabin of 1995 LS400
- Unable to get obd2 codes on 96ls400
- Steering Wheel Problem
- Cat converter, exhaust leak, or egr tube?
- 1991 Lexus LS400 CEL after work done
- Help with part #
- Weird electrical problem 95 ucf20 HELP!
- 1993 to 1996 ls400 interchangeable ?
- '90-94 Factory Hubcap Removal
- What is considered the normal for a 94 ls400 to idle at in park
- help with air suspension diagnosis
- P0773 - Shift Solenoid 'E' Electrical bad ecu?
- New 1998 UCF20 owner....with a miata too :-D
- i think i might have found something super rare!
- Talk me out of buying a 1993 LS400 !
- Load Rating question
- Strange shifting at high rpms
- new owner '93 ls400
- Hello. My '93 LS400
- Center armrest/compartment latch broke on my 98 LS400
- Another new owner that MIGHT stick around...
- 1995 LS400 Gauge Cluster
- Timing Belt Replacement Question
- Shifting problems
- Dead Battery?
- Opinions on changing the pinion seal. 91 ls400.
- What is't ?
- 1998 LS400 Overdrive
- Help: 95 ls400 rack & pinion, front lower ball joints
- Camshaft Oil Seal Replacement
- How long is the original wheel studs
- New Owner 1994 LS 400
- HELP: LED Corner Turning Signals
- 1994 LS400 Transmission Flush questions
- Turns over but will not fire!
- 94 LS400 - Code 28 - Upstream O2 Sensor Rgt Bk?
- VVT-i Question
- Worn leather - How should I fix this?
- Are Lexus OEM shocks worth it?
- Catalytic Converter Advice
- A/C condenser fan question
- 94LS400 Code 35 (HAC) sensor signal ?
- 99 ls400 fuel range issues
- 94 LS400 Code 35 & 47 Car Bucking/Shifting & Dies problem?
- Code 12
- 91 LS400 car starts after 2 seconds dies
- Bought a '92, been under the hood all day.
- Automatic setting of alarm
- Odometer hidden menu
- Can $4K buy a well-maintained/good cosmetics LS400?
- Is this a good buy?
- mass air flow sensor problem
- '00 LS400 OEM Engine harness availibility?
- 1997 LS 400 alternator replacement help needed
- 2,400 Mile Road Trip Observations
- That 3000 mile LS ?
- My "new" car
- UCF10 offsets
- cooked alternator?
- U.S model ls400 vs Canadian ...any diffrence
- Rear wheel bearing replacement with knuckle on car
- Gas Mileage Lexus LS400 1997 4.0 Liter 260 HP V8
- 95 LS LED tails and clear blinkers
- Loss of power, both cats glowed red
- Adjustable Upper Control Arms
- '93 LS400 OEM Wheel + Tire Swap
- Fuel pump relay location 1994 LS400
- Question about 1999 LS400 suspension
- Code 0500 along with vibrations from rear end?
- 1990 LS400 instrument cluster help
- can these wheel still be mounted
- Good aftermarket headlights?
- P0135, p0420, p0430
- Need you guys opinion on what tire size I should get
- Replacing alternator brushes
- 2000 ls400 Instrument cluster & hi beams out
- Need help-93' ls poor idle, no acceleration and running rich
- NEED HELP - CD Changer ideas
- Largest tire in '92 spare wheel well
- Black Gold - Out of Bounds
- OBD port in 1993 LS 400?
- Ls400 2000 belts ??
- control panel a / c
- 1990 LS400 in Georgia
- My new ride is here!
- steering/front end rattling sound?
- Initial Impressions of my '95 and p0420/p0430
- 95+ brembo rotor blanks
- Speedo inaccurate, other weirds
- 92 lexus ls400 tsm?
- Would the wheels fit my 1998 LS400 Celsior
- 98 LS400,Driving around fine, then super rough idle and car dies
- need help- electrical problem-radio cutting out
- Help! I need tips to weld together a broken piece from water pump inlet
