New guy - help pls =) - control arm and bushings
Hi everybody, recently I've bought a LS400 (99) for my wife to commute in. Really nice car I've been lurking for a month or so now and trying to wrap my head around the cars suspension. I had a mechanic inspect the car and he came back with some bad news. Everything is supposed to be great with the car, but the front control arms are on the worn side. Supposedly there are two lower control arms per wheel and the parts are obscenely expensive. I was quoted $1600 for parts + work, $1100 being the parts.
I've checked the parts and it seems its the whole friggin control arm instead of just the bushings which actually go bad. So, naturally, I checked ebay and pretty quickly found the ROCA bushings but people here have had mixed feelings about those. Supposedly FIGS are better. Thing is - I have no idea where you guys buy parts, because most of those links to parts are dead :/
Also, I'm not entirely sure those bushings would fit and if I'm even looking at the right ones =)
I have a bmw, and they have a nice page like this: https://www.realoem.com/bmw/select.do where you can drill down to what you need - is there anything like that for my car?
Not sure if this is the right forum to post in
There is only 1 lower arm per front wheel and 1 upper arm per front wheel. Here is where I get my OEM parts but you still need to look around for alternatives to some of the pricey OEM stuff.
http://www.lexussouthatlantaparts.co...rimLevel=19107
http://www.rockauto.com/catalog/rafr...ttype=10401&ck[year_1995]=true&ck[mkt_US]=true&ck[mkt_EU]=false&ck[mkt_CA]=true&ck[mkt_MX]=false&ck[viewcurrency]=USD&ck[ID]=0&ck[idlist]=0&ck[PHP_SESSION_ID]=ea804mqkeeh9ri7tchd585j0e4
Hey, thanks for the link - i remember rockauto from when I was looking for some parts for my e30 =D
However, I cant find the lower control arm on this site - only the upper one. Is it not under suspension? Am I being an idiot? =D
I've had some other issues pop up recently, the car drained the battery in 10min with the (xenon) lights and radio on. While I know xenons sap power like crazy - 10min is very quick. The car wouldn't even start. Had to jump it. The other problem is that the car is throwing a CEL, obd2 says P0440 something with the emissions system. Thats all lol. And the car vibrates considerably around 70mph - could be wheel adjustment or the shot bushings.
I'll test the battery this weekend, but I don't really have a clue about that emission system problem. I did poke around the engine bay and found a loose hose, which looked like it was rubber one day, but is hard as stone now, but I cant find the part or part number for the life of me =)
Can someone help me with that? How do you find or even better - how to you locate parts and get the part nr. on a lexus? This is so much easier with bmws =D
Can someone tell me what this foam coated hose is called? I cant find it anywhere ... Mine is cracked also and i think I'm getting P0440 because of it. The car also starts vibrating at 65mph+ like someone in that tread mentioned.
https://www.clublexus.com/forums/ls-...load-help.html
First of all I really wish some agency would crack down on all the ridiculously bright lights on cars now, in the old days there were limits on candle power of lights by the DOT. I just hate being blinded by them, tail lights too. There really is no reason to have a high power head light on a car other than to irritate the head on traffic. Go back to factory stock and eliminate that problem.
Have you checked the gas cap gasket or oring? Vibration could be a wheel out of balance, a cv shaft out of balance like worn cv joint, could be the drive shaft, could be a bad tire with run out or blister or bulge, could be a bent rim.
The Engine Control Module (ECM) tests the Evaporative Emission (EVAP) system for the following conditions:
- Large and small leaks
- Excess vacuum
- Purge flow during non-commanded conditions
- Fuel Level and Fuel Pressure sensor faults
- EVAP Purge and Vent Valve faults
The ECM monitors the Fuel Tank Pressure sensor in order to determine the level of vacuum/pressure in the EVAP system. The ECM commands both the EVAP Purge Solenoid and the EVAP Vent Valve ON when the conditions are met in order to apply an engine vacuum to the EVAP system. The ECM commands the EVAP Purge Solenoid OFF once the system has reached a predetermined level of vacuum. This test verifies if a vacuum can be achieved in the EVAP system. Failure to develop a vacuum may be caused by a large leak or a restriction.
- Excess vacuum
- Excess vacuum
- Excess vacuum
I'll start with the cheap stuff and have the wheels inspected, there is a lot of weights on there. Wheels look good, almost no curb damage, and they look straight. Tires are new, dont look damaged, but I'll check now. I pray to god its not a cv shaft or drive shaft. I've seen the prices on the replacement parts
I did have the car inspected, and the mechanic told me the lower control arm bushings are on their way out - I'm thinking that might cause the vibrating?
Thanks Billy. There is no way to buy that hose? Hope the salvage yard ones won't be in similar condition.
I'm not sure, but I think the image you posted may be from another year? The lower control arms for my model are the ones pictured below (if, not please someone correct me). Can I change the bushings only on these too?
no it is a 99, just strut rod bushings, sorry.. the lower control arm is 4806950020, and 4906850020 they are 220 each... the vent hose is 1226150021 ... less that 20$
NOW if I can find out this info, why cant you ?? I dont understand .. do you just not put forth the effort?
