View Full Version : Suspension and Brakes
- Info on B&G springs
- Who Makes Front Rotor?
- Pics of the Rear cross/slotted brakes from Steve Ganz!
- ABS and VSC light on after upgrade, help!
- coilover clanking
- GS430 Brakes Saved Me by a Short Hair!
- Suspension suggestions
- brake calipers
- TEIN Questions
- First Gen Supra TT Brake Upgrade
- Shocks installation
- ok, questions on Tein HA, CS, and Flex
- Installing L-tuned susp in NYC
- shocks question
- Need new shocks: L Tuned or Bilstein
- Slotted Rotor Question
- lowest you can go?
- Another Brake Caliper Set painted
- gs400 alignment problems
- idea on prices for tein HA and Flex
- Alignment Out of Spec After Drop
- spring settling
- Brake Pads for stock 99 GS 300
- brake pads for stock GS 300
- Supra Brake Upgrade
- Rubber Bump Stops
- Toms STB Pictures
- Ltuned and H&R installation
- Toms rear STB Install Question?
- Bilstein PSS vs Apex WS
- Shock and Spring Installation
- take a sec and choose...SSR's or SS6's
- Toms or Tein Flex ?
- front/rear pads
- BFG g-Force TA KDWS???
- stainless steel brake line make difference?
- lowering my car
- EBC pads and Goodridge SS lines
- Help! Creaking noise in back of car.
- Bay Area, California
- Shop Installed TEIN CS coilovers today
- Response from Tein: EDFC will work on HA & RA dampers + Will your STB clear?
- thumb noise from the front
- Zeal coilovers...
- wow, what a difference !!
- l-tuned = eibach, and...
- What is the least expensive place to get the L-tuned suspension?
- supra brakes, got the specs?
- Brake By Wire
- Need help on 2W/4W Alignment Schedule
- even or uneven drop?
- Shocks Question
- Arc swyabars?
- Alignment Problem
- Suspension for '95 Gs300?
- How low is this?
- Cost to Install TRD STB and Sways
- TRD Sways....
- Adding oil with TRD STB...
- Trd Stb Powder Coated Red
- Group Buy Brake Upgrade HELP??
- l-tuned suspension
- Brake System Upgrade
- TEIN knowledge??
- L-Tuned Wheels??
- Installing Springs
- alignment
- Headlight Question
- Question about Bilstien PSS Coilovers
- STB which one is better?
- H&R Sport Springs
- Just how much is a 1" drop?
- Hey guys I'm new here...
- Where did you get your suspension installed at?
- Gauging Interest on Brake Package Deal
- re: Where to find Stock Lugnuts for 98 GS300 ??
- power slot rotors??
- Need Help.. I want a Big Brake Setup
- Atlanta - seeking high speed tire balancing
- Testing Shocks before Install
- General suspension questions
- Strut bars
- TRD Brakes with EBC Green stuff
- 2k Platinum Series = 99 GS4?
- lowering computer thingy
- Straight slots Vs. curved slots?
- bORLA
- Tein HA
- Steering problems.
- Springs
- TEIN FLEX...finally installed!
- L sportline suspension parts
- H&R with Ltuned shocks!!
- STBs vs. sways
- L-Tuned and stock 16" on GS300
- brake pads
- Wierd noise coming from my new L-Sportline suspension.
- Break questions, please help
- Where is the Cheapest prices for Tien FLEX
- camber kit...
- alignment with springs
- brake kits
- where can i buy L-Sportline springs?
- Supra Brakes Special Buy
- gs with one finger gap
- suspension mod
- 19in rim gap with H&R Springs on a 98gs4?
- Brake question
- Upgrade suspension without lowering?
- Distinguishing L-Tuned shocks
- Adjust Tein HA Drop - its stuck
- Motul 600 Brake Fluid
- brand-new GS430, suspension height uneven?
- strange steering wheel movement
- Supra Brake kit fit L-Sportline!
- L-tuned shocks
- Which brake pads are better?
- Dose Tom’s Strut bar fits GS430?
- how to install tein flex
- Rear end sway, how can I stop this???
- question...
- Dropping my GS....
- brakes
- Impressions of my new suspension..
- Stripped stud replacment: how difficult??
- FYI: Wheel spacer pics w/265's
- Problem after install TOM's 6 links
- Tein vs L-tuned
- Best Place to buy L-tuned Suspension?
- Q: about coilovers vs. stock setup
- Wear on stock shocks with lowered springs
- 1st Gen GS help
- L-tuned shocks and struts
- L-Tuned vs. L-Sportsline
- Non-functional rear brakes....
- Pics of Centric Parts rotors
- GS430 Springs different from 400?
- lowering
- lowering kit
- Need help on adjusting stiffness of shock on Teins
- More Tein Questions
- opinions
- Advice on next mod? Back-end walking...
- L-Sportline springs....eibach?
- Selling of Tein HAs
- L-Sportline Vs. RMM Brakes
- L-Sportline VS. Rod Millen
- Which Brakes?
- Coilover question
- Eibach vs. Intrax on First Gen. GS300
- Goodridge stainless brake lines
- Tein Flex w/ EDFC
- Brake Pads
- i think i want break kit.. what to get?
- alignment on lowered car
- painting calipers
- TOM's Advox installed!!!!! Great!!!!!
- Just installed L-Tuned Steering ECU. Difference??
- steering wheel shudders at diff speeds
- whats a good drop on 19's?
- Wondering about JIC Magic
- Does anybody GS400 Use Alot of Gas
- Help...Coilover install in LA. area
- what the best tire gauages
- got the Toms advox today..
- Cusco Coilovers
- Air Suspension
- Tein CS & Ha
- TRD STB install - do u ned alignement?
- Tein Questions....
- Are those good rotors?
- Tein CS Coilover Install Advice..
- Need some Tein CS install advice..
- specs for tein HA and CS
- L Tuned And Trd Stb
- Suspension Help
- Where can I get TRD rotors?
- L-tunded GS300
- Brakes
- Life of TRD pads? Long?
- Shocking question....
- brake squeaking
- L-Tuned Steering ECU Install Help Needed.
- Tein HA with TRD STB Picture
- Significant Shimmy when Braking
- Tein HA nightmare Ended.... LONG STORY
- Are The Tenabe Lowering Springs Too Low?
- Tenabe Lowering Springs Too Low???
- Rmm Stb
- SUPRA rear brake upgrade...pics.
- DIY brake pad change and recommendation
- Tein HA making sound
- Can you buy just a rear sway for GS?
- Figured out my next mod!!
- Tein CS Coilovers
- Shocks
- Experience with TRD GS400 brake upgrade?
- lexus warranty with H&R shocks
- L-tuned Springs and Bilstein Shocks
- What kinda brakes should I get??
- WTB: Rear rotors for 94' GS300
- Are you gas and brake foot pedals level with each other?
- lowering shocks/struts
- Brake Dilemma
- UGO STB vs TOMS STB
- Clearance problem with TRD front strut tower bar install...
- Coilovers (HELP)
- any notice the gas/brake pedals are level with each other?
- Stock vs L-tuned vs RMM suspension
- Just got L-Tuned: First Impressions
- Fog Light Question
- GS400 Suspension Upgrade?
- 4 Wheel Alignment Problems in MA with Tein HA
- L-Tuned Warranty, conflicting information
- Dont get it
- Hours to Intall L-Tuned?
- Alcon Brakes (Manaray)
- Coilover Spring Rates - Not all coilovers are for racing only!
- GS400 Suspension
- Will aftermarket Supra brakes fit a GS?
- Spring Pads
- level head lights
- trd rotor help please
- Stock suspension
- Considering Adding LCBs - Too Stiff?
- Suspension Setup
- Lowered Gs With Hid
- Bilstien PSS Coilovers
- Wheel Spacers Info
- Tein CS Rethread
- Pics of Different Springs
- TRD LSD Install
- For those with Tein Suspension......
- Picture Of My Car In TEIN Workshop
- New member, needs your modification tips
- strut bar
- Front Brake Pads
- Lowered My TEIN A bit
- LSD Help
- Brake Upgrade Questions???
- Improved Handling
- GS430 Feathering tires
- Help! Tein HA installation
- Slotted/Drilled Rotor Noise
- Alignment Specs wanted for 98 GS300
- Any good alignment shops in MD?
- TRD Brake Kit Very Nice...
- Increase steering rack speed
- will the SUPRA brake caliper fit the 18's Ltuned wheels?
- Suspension mods for GS300
