View Full Version : Suspension and Brakes
- Front Brake Pads
- Lowered My TEIN A bit
- LSD Help
- Brake Upgrade Questions???
- Improved Handling
- GS430 Feathering tires
- Help! Tein HA installation
- Slotted/Drilled Rotor Noise
- Alignment Specs wanted for 98 GS300
- Any good alignment shops in MD?
- TRD Brake Kit Very Nice...
- Increase steering rack speed
- will the SUPRA brake caliper fit the 18's Ltuned wheels?
- Suspension mods for GS300
- TRD sway order saga....
- Do you guys install the rear strut tower braces yourself?
- Front/Rear STBs that work with coilovers??
- Steel brake lines?
- EBC brake pads
- What are the differences in Tein models: HA, NA, etc.
- Tom's advox coilovers VS Tein HA
- Replace rotors/pads w/SupraTT brakes
- TEIN HA Pics
- Supra TT brake upgrade on my 98 GS400
- TEIN HA Writeup
- Bilstein and Eibach
- Gs300 Shocks
- STB, Swaybars, Suspension Brace to improve handling?
- Do we need a camber kit?
- with Tein HA CL members
- Anyone done L-Tuned Shocks and Springs with 16"Tires?
- Put in the TEINs.......BUT.......
- TEIN Advantage
- Rear brake upgrade???
- Trany rumble
- Colour code for 1999 White GS400
- H&R Sport Spring Set
- Height Adjustment in TEIN HAs.
- Brake Fluid Leak
- What coilover kit to go with.....HKS or Tein???
- TRD Slotted Rotors and TRD Pads Installed F & R – PICS
- Blistein of LTuned Shocks
- "Shim Kit" Needed For TRD Brakes?
- SS Brake lines
- Brake upgrade
- Daddy likes his new shoes!
- Supra TT Brakes
- spring question?
- Brakes and offsets
- Do GS's have their own camber?
- Need advice H&R Coilovers??
- Sway Bars
- i am cracked!!!!!
- Sway bar effect on front/rear balance
- Camber Kit
- about Tein HA
- about Tein HA
- Alignment Specs Please
- Shock Torque Specification
- TEIN HA or L-Tune?
- help here guys!!
- sturt bar
- L-Tuned Shocks & Springs
- Bilstein PSS coilovers installed!..and I am pisseD!
- Anyone might be interested in these???
- What kind of brake pads should I get?
- Any NJ L-Tuned Members out there?
- Eibach Springs
- Tein Ha upper pillow ball mounts
- Sway Bars
- Quest For Coilovers
- TRD F&R Sways Installed - Impressions & Link to Pics
- Brake Pads???
- What kind of Brake Pad Mileage R you getting?
- Squeak? Rear Susp?
- car shaking when I brake at high speed?
- Can upsizing your wheels damage your wheel bearings?
- Shocks
- Does Your LTuned Susp Get Vocal When COld?
- TOM's Racing has a STB that will fit over the GS430 Engine Cover!
- FYI-Brake pads
- COILOVERS ????? Cant Decide
- Brake Noise
- TEIN HA - Weight Balancing
- ** TRD Sways are in ***
- Lowering
- TRD Strut Tower Brace
- Painting the brake Calipers
- Howling/Humming noise from front suspension...any help?
- TOM'S 6-Piece Suspension Brace Kit & Rear LCB
- Brake Upgrade How To??? (JacobT, HI98GS, etc.)
- Airbag Suspension vs. Tein HA
- Important Info on TRD Sway (Cause of my painful clonk clonk noise)
- Suspension Housing
- Does Anyone No Who Makes This Body Kit.
- Help! Strange noise coming from Suspension
- Warning If You're Thinking Of Getting Trd Sway Bars...
- Handling Problems on GS 400
- I just posted some pics of my 19s w/my brake caliper sticker
- HELP...purchasing soon
- Upgrade Stock Tires/Wheels GS300 '01
- Anyone know what this could be?
- New Allignment 4 my 19's!
- Bilstein or Eiboch shocks?
- Completed installing TEIN CS
- ** SS brake lines in **
- Brakes Sqeeking - ARG!!
- Got my new TEIN CS
- TRD Lower Suspension Brace and Strut Brace
- Tein CS VS HR
- DIY Steering ECU 101????
- UGOs Installed
- Brake Pads: TRD or Stock?
- brake upgrade
- big wheels/handling
- Brake Lines Question
- Sway Bars / Strut Bars (Under and Over Steer)
- How hard is it to install coilovers?
- Anyone has Tein HR??
- Does anyone have the Bilstein PSS Coilover?
- Tein CS/HA's for sale!!
- Tanabe sprgs/bilstein vs. H&R/bilstein
- Whats the best brake setup used or new....Supra?
- Popping/Creaking Noise???
- Brakes Making Noise
- ** New TRD Brake Upgrade **
- After Reading Racing Aristo's Review On Tein HA...
- Wheel bearing noise on the front
- First problem with my GS....brakes
- HKS Hyper Damper Coilover
- shaking in the rain
- which company makes a strut bar for a 98-01 GS300??
- tanabe coilover
- Vibrates like H**l
- new TRD brake pads impression
- Just getting the L-Tuned Springs
- Chaos: GS300 Suspension Upgrade
- GS300 Suspension Upgrade
- Stainless Brake Lines with OEM Brakes?
- Steering ECU
- l tuned shocks and springs installation
- Ted caliper sticker
- Suspension/Spring Install
- Rear strut tower bar
- What the F***!!!
- Lowering GS
- Apexi WS?
- Supra brakes
- Will ride quality suffer if only lower springs are installed?
- coilover question
- Help Tein Problems
- any one have JIC coilover suspension?
- Installing steering ecu HELP!
- Suspension Choice
- Brakes!
- what width should I go with
- Bilstein
- Important question
- what brake kit to get?
- That Time Of The Year Again!!
- Will it fit?
- Steering/Hydroplaining at 56-60mph?
- Steering ecu upgrade
- More Steering Wheel Tilt
- Bradi Rotor replacement - Help a rookie!
- Alignment question??????
- traction control
- L-tuned and L-sportline??????
- bilstien coilovers?
- Help!... need torque specs for rear brakes on my GS300...
- What model compares to the GS300 / my repair manual has ES,LS & SC??
- Sway Bar
- ill post this again
- Breaking In
- The final word on brakes
- Coilover suspension vs. L-Tuned
- Brake Upgrade
- Eibach springs???
- How do you spell relief? T-O-Y-O
- GS400 TRD Mods
- I've made my suspension choices.. how does this sound?
- What is this car lowerd with ? any idea ? Pic inside.
- suspension
- Suspension Components - who are the best suppliers
- L-Tuned Suspension - how can I learn more?
- Lease just expired on my 99 GS400.. need advice on suspension mods!
- problems with l-tuned suspention
- L Tuned Test drive
- Just ordered my TRD STB.. WOOT!
- Sway bars ...
- New GS3 - Where do I start with upgrades
- Brake Upgrades
- Ride Height w/ L-tuned
- GS with Supra brake upgrade pics
- tanabe springs
- GS430 L-tuned wheels and suspension
- Supra Brake Conversion
- fully sooped ^ GS300 Vs a sooped ^ 5.0
- From Ltuned to coilover, help!!
- Tein-HA installed
- Anyone have rear suspension brace?
- L Tuned Steering ECU
- H&R Springs...I need alignment specs...PLEASE HELP ME OUT GUYS!!!
- Aero Kit With Sports Springs
- Front/rear sways and lower chassis brace installed
- TRD LCB VRS. STOCK LCB....Who will win?
- Wheel Spacers info?
- Tom's rear strut bar is cool!
- ride on TEIN CS coilover
- Can I use stock shocks with a 1.3f & 1.4r drop??
- Need help! Ltuned Shock & Alignment
- Unhappy with Stock brake system...
- ***group buy on BREMBO cross drilled/slotted rotors****
- Brake Pads for drilled/slotted Bradi's`00 GS3- Whose to use?
- Tom's rear strut bar install probs!
- Weight of rims
- L-Tuned & Alignment Problem
- L Tuned Installation
- Bilstein Question
- For TEIN HA owners
- TRD Lower Braces needed?
- installation of stb on gs300
- rmm/intrax vs. trd sways
- Cusco REAR STB installed this afternoon
- Alignment specs after suspension alteration
- sway bars or stb?
- L-tuned suspension Install - NYC
- Need new tires, input appreciated
- Painted Logo on Brakes Calibers?
- sawy bars
- L-Tuned Spring and Shock
- What do I need to do to put Supra brakes on 1G3?
- BMW 540 handling?
- Which Bilstein??
- Do I need another alignment?
- Lsportline
- INSTALL: UGO Front & Rear STB
- Rotor/Caliper paint???
- tein coilovers
- GS cross drilled rotors
- about Supra brake swap:
- Chassis brace, good idea for the money????
- Suspension questions
- Handling mods
- Going To A Lexus Dealer For A Wheel Alignment
- Lexus Calipers??? Very Nice!!!!
- Anti-lock brake setting
- Twitchy Ride
