question...
Old May 13, 2002 | 09:52 PM
futuregs's Avatar
futuregs
Default question...
What does the Front and Rear suspension member braces from TOMS do for the GS ?
Old May 13, 2002 | 10:42 PM
RacingAristo
Guest
Posts: n/a
reduce the flex and tighten the body.
Old May 14, 2002 | 02:18 PM
futuregs's Avatar
futuregs
so it's just a bunch of sway bars welded together?
Old May 14, 2002 | 06:42 PM
mooretorque's Avatar
mooretorque
Talking
Nope. Sway bars transfer force from one side of the suspension to the other. Chassis braces prevent as much flex in the chassis when it's under load. Think of your front and rear strut/spring combination as the corners of a box without ends or two seperate squares, but without one side (see below).
A strut tower brace ties the top of the box together and makes the box less likely to deform when it is pushed on (cornering force). This means that the geometry of the suspension stays more uniform and also that the forces involved in cornering are not lessened by flexing the chassis but rather are handled by the tires, as they are supposed to.
The front and rear box can't really be tied together at the top without running a roll cage through the car, which sort of spoils the luxury of a Lexus. But you'd have a very strong Lexus if you did.
(I tried to draw a couple of things to illustrate, but it didn't work right when posted so you may feel free to be more confused by my explanation than you were before.)
Old May 14, 2002 | 08:11 PM
Something like this? (old CL joke)
Old May 14, 2002 | 08:38 PM
garnet92's Avatar
garnet92
Default Porno
Bit - you ought to know better - this is a family thread and there you go posting a picture of a sunburned Anna Nicole Smith holding up her red and green bikini top.
Old May 15, 2002 | 12:52 AM
Manaray's Avatar
Manaray
Default Re: Porno
Anna Nicole Smith? Hmmmm, I thought it was George Burns...hehehe...guess we could call this the BITschach Inkblot Test...
Old May 15, 2002 | 04:52 AM
It's actually the 2004 GS!
Old May 15, 2002 | 07:18 AM
mooretorque
Talking
I had that drawing in mind when mine posted wierd.......reminds me of the TOMS 6 piece rear brace, too.........
Non sequiter: L-Tuned springs and shocks go on tomorrow!
Old May 15, 2002 | 04:25 PM
futuregs's Avatar
futuregs
ummmm, yeah ok, im just gonna agree with you. WIll it harshen my ride at all??
Old May 15, 2002 | 08:12 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Looks like a photoshopped ES to me.
Old May 16, 2002 | 01:06 AM
Manaray's Avatar
Manaray
Eh, I wouldn't use the term "harsh"...it will stiffen it up a bit, but not to the point where I would consider it "harsh"...
Seefo
Dec 12, 2016 06:00 AM
shawnberry
Suspension and Brakes
May 1, 2008 06:39 PM
dtran023
Nov 24, 2007 07:38 AM
