Wierd noise coming from my new L-Sportline suspension.
Hey guys, I just purchased from another Cl member the L-Sportline suspension (springs&shocks) and I'm hearing a strange "clunking" or "toink" noise coming from the rear everytime I drive over a speed bump at work. Any ideas what it could be? Could it be the same problem that the L-Tuned shocks have in regards to the bump stop? Help please....
Originally posted by Shinchan
did your installer installed back the stock bump stop?
I just remembered that I took a pic right before they put on my wheel. Can anyone tell me if the bump stop off my old shock was put on the new shock. Can you tell in this pic? Thanks
1. Try to narrow the problem as to which side of the rears it is happening by driving just the one side over the speed bump. If you hear it on one side, then try the other side.
2. If both sides have it, then you know you're dealing with incorect installation. Bring it back to the installer.
3. If one side only shows it, then that side was incorrectly installed so bring it back to installer. At least, you know that the other side was installed correctly and the installer will know more or less what the problem is by comparing it to the good side.
OK, driving over the speed bumps at work, I starting with the driverside then the passenger side. The noise occurs on both sides of the rear of the car. Does not happen up front. Any suggestions before I take it back.
The shop should be able to recreate the problem by putting the car on a lift just enough to raise the rears. Then, with a long piece of wood, put the short end under the tires and lift it, using the wood like a lever, as if it is going over a speed bump. Someone would then look below and determine if the noise is occuring from the top or lower part of the suspension. My guess is one of the rubber bushings or pads that came with the replacement springs/shocks is not thick enough or not up to the task. A solution could be to reuse the old rubber parts from the OEM. Another possible scenario is that the rubber parts were not installed in the right order. Still another one, check the tightness of the rear sway bar and other suspension compoments before doing anything.
I hope its not very bad.
whitels: thanks for your help. I will let you know what happens on Sat. This is the first time I bought anything from another cl member, and now I have this problem...
Suspension Problem Solved
Well guys, after 3 hours at the shop having my suspension torn apart and many test drives, the installer found the problem. The noise was coming from the rubber bump stops inside the shock. Why? On the L-sportline suspension, there is a clip on the shock that allows you to lower the car another .5". That's how you get almost a 2" drop. Well, by doing this and the added weight of my car (stereo stuff probably) the bump stops must have been flexing when driving over speed bumps causing that awful noise. Solution? The installer cut about a 1/2 inch off the rubber bump stop. Put everything back together and the noise went away. Also, the ride seems to be a little better. Less bumpy in the rear. Special thanks goes out to whitels and Shinchan for their suggestions.
Quick question...I have been dealing with the same problem for a very long time now, about 25,000 miles. Actually, ever since my Eibach install. I ended up just replacing the springs, so I still have the stock shocks. I haven't run into any problems, but I have that same noise coming from the rear. I plan on buying some Tein HAs soon, but I was wondering if these help help correct the problem? Any suggestions?
Originally posted by MikeGS4PE
LXOGOOD - If you don't mind me asking, what kind of bulbs are you running in your clear bumper lenses?
Thank you! I am actually running those for my wedge bulbs, so I think those would work out pretty good. I only wonder if that is legal for a side marker, meaning the color difference.
