STB which one is better?
Hey guYs, i need some input. Which of these two stb is better?
TOM's or TRD? I know the TOMs one is red and the TRD one is polished or silver. Which one will you guys prefer getting? Advantages or Disadvantages on either one?
thanks
thanks
Have you tried using the SEARCH feature ? This has been discussed too many times if you asked me .
First off you can take the TRD Stb off your list cause it won't clear the engine on the GS 300 . Tom's i'm not sure of .
I have the Rmm STB and it serves its purpose .
Use the Search feature and you will find what you are looking for .
The One
1niceride is correct. TRD will not fit the GS300. I think even with the engine cover off, spacers will probably be needed. There have been mixed results with Tom's.
There is also the UGO, which should fit but I am not sure about the engine cover. I am awaiting my UGO STB which have fit others' GS300s. Since I have a 98 GS300, which have no cover, I won't have a fit problem.
Pending other responses, if you need info sooner, do a search like 1niceride suggests. There has been different discussions on STBs in the past.
Good luck.
Good luck.
