gs with one finger gap
Old May 22, 2002 | 03:15 AM
jbbnet's Avatar
jbbnet
Default gs with one finger gap
I want a one finger gap on mysuspension from the tire to the body. Will it rub if you hit a bump? How much travel do you think is in the flex coils?
Old May 22, 2002 | 06:00 AM
Johnny Mo's Avatar
Johnny Mo
GX and 2IS Moderator
Default Gap
I have about 1-1 1/2 on mine with L-TUNED
Old May 22, 2002 | 02:17 PM
Manaray's Avatar
Manaray
rubbing will depend on your offset and tire size. If your car rubs now, then till rub when it's lowered more (since you're making the "gap" smaller, there's less travel need for the tire to rub the fender...) As for travel in the coils, you'll probably have to hit up your manufacturer to find out that info...
Old May 23, 2002 | 05:47 AM
jbbnet's Avatar
jbbnet
i guess my question is, how much travel will the suspension have even once it's lowered. How does this work with tein flex or HA?
If i lower it and allow a 1 inch gap and the travel on the suspension is 1.1 in, then it will rub.
I assume the 1.1 inch of travel on the shock would be the occiasial pot hole..ops......
Springs have lots of travel.
Old May 23, 2002 | 07:39 AM
JacobT
Guest
Posts: n/a
This is just about "one" middle finger
The suspension can travel more than the gap since the wheel tilted in when hitting bumps not straight up. So it will tuck in to the wheel well.
Old May 23, 2002 | 07:43 AM
futuregs's Avatar
futuregs
nice rotors
Old May 23, 2002 | 01:09 PM
jbbnet's Avatar
jbbnet
so a one finger gap will not rub when the wheel is turned? What about when it's straight and you hit a pothole. (good example!) It's going to hit the fender plastic hard, right? Even if the offset has it tucked in enough.
I was trying to determine the travel on the shocks. I want it low but don't want it to rub. I think it's inevitable! What's your thoughts?
Old May 23, 2002 | 01:30 PM
Manaray's Avatar
Manaray
The wheel will hit when the wheel is turned to one extreme (left or right) IF YOU hit a dip/bump while turning...
When it's straight, so long as your width and offset is good, you won't rub at all.
As for suspension travel, it really depends on the suspension. With the Tein FLEX for example, you can retain FULL travel AND lower the car...but with most coilovers, you are adjusting the travel along with the height...
Like I said, if you're tires don't rub the edge of the fenders now (when you hit a dip...and one that makes your wheel tuck into the fenders), then it won't rub if you lower it another inch...this is in regards to the wheels being straight, not turned.
What setup (wheel/tire) do you have that you're concerned about?
Old May 24, 2002 | 06:55 AM
jbbnet's Avatar
jbbnet
i have ssr gt3's with 19x8.5 and 19x10 with 245/35 and 275/30 and i wanted to lower it with either tein flex or l-sportline suspension. I live in massachusetts and i think i seen a pot hole once....lol......
Old May 25, 2002 | 07:06 AM
blue wax's Avatar
blue wax
nice wheel, nice rotor, nice gap......
in 1 word perfect........
yezzzzzzzzzz
Old May 25, 2002 | 09:36 AM
jbbnet's Avatar
jbbnet
yezzzzzzzzzz
hey, what is that a picture of? what motor? lexus 4L V8?
Old May 28, 2002 | 08:08 PM
GS400_PUSHER's Avatar
GS400_PUSHER
Man I just love that black & chrome!!!
Old May 29, 2002 | 03:53 PM
jbbnet's Avatar
jbbnet
yea, that is sweet.. i dont know if i would go black next time...........
Old May 29, 2002 | 05:22 PM
///MDex's Avatar
///MDex
Wink
Judging from that inserted strip (which looks like a Roadster), I bet its a BMW powerplant.
GeorgeGS3
Sep 22, 2017 10:15 PM
RedlineAZ
IS F (2008-2014)
12
Aug 20, 2014 07:35 PM
210IS300
IS - 1st Gen (2001-2005)
Feb 26, 2013 02:51 PM
mikeho
Jun 18, 2008 04:52 PM
tmasta
May 4, 2005 01:31 PM
