- LIL something I did over the weekend..!
- ok whats the limit with the stock distributor and this turbo? (pics)ha ha
- aristo vs usdm gte auto trans, same?
- High Idle and gurggling?
- trans NO not a swap thread
- Whipped up a CAI 'till the turbo
- '93 SC4 CRANKS, but engine would not turn over, HELP!
- 1996 Supra Torsion LSD swap into SC300?
- car wont start, alternator problem?
- 97 SC300 w/Tach Adapter - Question - Wiring Diagram Attached
- Smoke near passenger side.
- SC4 vacuum hose q???
- shift lock problem
- soarer front clip
- Another Question
- HELP with 1JZ Car won't go above 2k RPMS and crappy idle
- No Spark Wont Start! Help!!!
- Just Changed Clutch And Now It Wont Start
- SC3 with t67 vs evo
- Backyard Mechanics?
- clutch problems
- some newb questions...
- I think my Alternator died :(
- AC Compressor Not Working
- Koyo Radiator and fans
- header design demystified
- 1jz/w58 clutch/flywheel
- electric lockers 93 sc400
- O/D light keeps blinking..
- 2JZ Pulley question
- Swift Racing Technologies (SRT) Intake on 98 SC300
- need to know help!!!!!
- 1jz question
- SC400 Driveshaft support
- IDLE vibration?
- vibration problem on '93 SC400
- Measure Back Pressure
- Na-T question
- Cheaper Alternative to a "real" SR Intake?
- Goal atleast 450rwhp, on 1uz = how?
- really bad gas milage
- sc300 turbo kit
- Stalling problem: plz help
- i searched its too late to search more! help 2jzgte
- SC400 alternator rebuild
- Mounting Nitrous in trunk..
- will supra mk4 intercooler kit fit?
- Reliability of a SC300 5 speed with a turbo kit??????
- SC300 2JZGE Turbo kit compared to a 2JZGTE Swap
- SC400 exhaust headers/extractors/scavangers
- Problem, TPS Causes engine to cut out at low RPMs, SC300
- built w58??
- Stock Timing belt
- Need help with CEL Bank 1 sensor 1
- 3.76 torsen im gonna buy need some advice
- Front clips?
- Supercharged SC400 nasman
- Injen Intake
- Boos Logic Midpipe question
- 1UZ Driveability
- I let it sit for 2 weeks and now it wont start.
- A341E Transmission
- Need write up on HG
- Starting problem IEEEE
- Definitive 1JZ/5speed thread??
- How many Qts or Gals to fill entire 1993 SC400 coolant system
- Replacement/Aftermarket Shift Handle for 1992 SC?
- How many whp can a 98+ sc400 transmission hold
- Supra Exhaust and Moroso Oil Pan??
- Nightmare mechanic.. what to do?
- lightweight battery
- ECU swap from auto to 5spd?
- Anyone have any info on bullet performance chargers for the 1uz?
- ODB II Question (emissions)
- Code 13 - RPM Signal or Knock?
- 97 SC300 with 1JZ
- How many quarts of transmission fluid does the sc400 hold?
- any sc400s come with l.s.d.
- Time to replace SC400 starter/alternator?
- 1jz swap giving me the blues!!
- SC400 No start :(
- traction control
- SC400 compression?
- 1JZGTE...MAF or MAP?
- I know, I know, but I really need help!
- WTF - 5 codes at once?
- My 1JZ swap
- how do i tell these trany's apart
- Report: Replaced Transmission mount on 13 year old car
- 1jz power fc problems
- Center muffler?
- pcv hose?
- Cheap generic flowmasters advice please...
- best managment for obd1
- Brake Light in cluster, can I Just fill up my reservoir?
- SC400 Power Steering Removal/Install FAQ ?
- another bad alternator?
- SC400 trans flush
- single exhaust exit?!!?!
- I dare you to figure this one out.........
- Strange whirring noise?
- Egr....egr
- Tranny upgrades for 1j?
- Need a part number...
- possible rear end problem with my new sc3
- 1JZ ecu&harness controlls jdm aristo ??
- How hard is it to swap at 1jz
- swap question
- 1JZ GTTE Intake on 2jzge
- non SC exhaust on an SC?
- lots of engine noise under deceleration
- Plans
- 90k Mile service parts?
- 97 SC400 starts then dies!!!!
- Which turbo is best for me?
- 2jzge engine
- Car Shut Down!!!...Help!!!
- GTE swap, need help with wiring
- Where to buy Tanabe mufflers?
- Changing valve seals in the 1UZ with heads on.....
- Coolant is leaking from the "thermostat housing" area.
- Battery Problem
- 2jzge block weight
- the hell with 400whp ! im changing the setup again !
- DANG Stupid thing happened
- NA-T website
- Engine Pro's and Con's
- Specific 2jzgte questions
- R154 shifter extension mod writeup w/ PICS !
- MAP-ECU 2 Released!
- what is this?? some guys will do anything for boost
- New Tune ... Need New Management....sc31jz
- aristo 2jzgte into sc300
- Finished R154 shifter extension mod for SC/Supra w/ PICS !
- Can I post items for sale on this forum? or is there another one?
- Check Engine and TRAC OFF Lights on
- Need A MAF For My 1992 SC400
- What tranny mount bushing to get for r154 soarer
- Fuel filter???
- Cost?
- OBDII + Turbo?
- How much power can the stock 5spd handle?
- Short Shifter?
- My headlings bulbs keep shorting out...
- What could I have done wrong!!!! Timing belt
- th400 pros/cons and ?
- Search isnt working... 1jz max boost psi question
- Changing head gasket for sc300
- jzz30 body plugs,IJ1&2,IK1&2
- Anybody with remus exhaust on a sc300?
- 1UZ Aussie Header Outlet Diameter
- W58, R154/r154 trans
- Engine Questions.
- 1JZ 5 speed swap question. My current car is a 5 speed...please read
- Specific question - Toyota *Red* coolant and "Green" Ethylene Glycol
- engine harness ?
- SC400 Catalytic Converter= $11,221.60 EACH!!
- 2jz-gte swap into SC400
- used O2 sensor
- exhaust... maybe?
- Thinking about picking up an SC300 turbo/2jzgte
- The good ole' electircal ghost.
- Car is running bad!
- would it work
- SC300's with 2jzgte swaps
- A Few Questions (1JZ, Tuning, ....)
- ps reservior?
- How to minimize higway noise with exhaust?
- Tranny Fluid
- Aftermarket Intakes for 98+ SC300? (SRT)
- 1JZ clip or just buy the motor
- Cost of USDM 2jzgtte
- Heat problems 101 for newb's plz sticky!
- 2jztt and 5 speed Sc300?
- 1jz & stock trans
- newb ? on 92 sc300.
- Ignition Signal?
- 400 won't shift into 4th!?
- Which intercooler should i buy?
- Engine mounts
- 1jzgte Vvti Question
- 1jz cold start fluctuating idle issue
- ??From D to N when brake is hit hard???
- Code 78 Fuel Pump Control?
- 1jz oil return
- Fuel Pump Located?
- How long do you warm up your engine?
- 12 psi of boost on stock SC400, SC300?
- Loud ticking noise from engine
- heater problems revisited and yes i searched
- Power steering Problems Help!!!
- how to check for CEL?
- New Member: Help Please
- Water pump replacement sc400
- apexi afc neo help
- What to do to the SC while im gone......
- Turbo compressor Extended Fin?
- Exhaust options
- non vvti 1j in vvti sc300
- 1jzgte sc300 - RPM gauge not working.
- R154 Speed Sensor
- Coolant spray (& steam) across front of engine from fan/radi?
- Coolant *SPRAY* from fan back across engine front and pulleys on V8?
- Windshield Washer Fluid
- Two specific issues
- heater fix???
- 1jz tcc
- MKIII W58 question
- SC300 Gear Ratio
- MAF sensor? T-belt?
- 6 speed swap coming need input.
- What about Valve Seals??? Smoking SC400--
- How To Test The Distributor On SC400
- 2jz Vs 1jz
- How to test MAF
- HELP Please! Car won't start and shows 3 codes
- Exhaust Manifold Question
- Alternator power cable?
- finally plug wires and ignition upgrade for n/a
- which parts for Starter Rebuild ?
- help! map ecu's are confusing
- My engine shut down....
- DIY 1992 SC400 Alternator Rebuild--
- Swap At Rndfactory!!
- 98 - 2000 ge's
- sc400... supercharger?
- Interested in 2gzgte swap lots of questions
- Why don't more people use the TT SMIC?
- Best place/type of replacement alternator?
- motor mounts?
- How come i havent seen any 2JZ tt 6 speed clip swaps?
- Code14 Ignition signal
- Billet Dual Fuel Pump Hanger at MVP
- found this little chip on ebay, do u think it could possibly work?, at all?
- i need help! check engine light is on.
- Help...Drop in RPMs after shifts
- Stroked 2JZ NA
- 95 SC400 leaking Please help
- Can running too rich or lean cause the engine to shut down?
- Ek tuning headers!!
- to Turbo or not to Turbo...?
- Possible to use short shifter in a 92-94 SC300 with tranny swap?
- Crank Pulley Marriage is over
- soloution for bad sc transmissions
- 92 transmission fit a 97?
- Unknown mech. problem. Can anyone help?
- Accessory Problem, P/S Pump, Alternator, Belt Tensioner or Waterpump???
- 2jz-gte vvti into 400 with 400 a/t tranny?
- DRAGON Torque Convertor Single Disc
