Fog light Mod for UCF10???
Old 01-13-07, 02:30 PM
dinh626
dinh626's Avatar
Default Fog light Mod for UCF10???
Searched but could only find for the newer Ls and even then weren't great pictures, or detailed instructions.
What I'm looking for is the mod (for 1990 LS400) so that the foglights can be turned on anytime independent of the headlights.
pictures of which wires to used and how to access them would be great.
example picture...
Attached Thumbnails Fog light Mod for UCF10???-picture-20241-20-28large-29-20-28small-29.jpg
Old 01-13-07, 11:54 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
if u could get me a wiring diagram of the interior and engine fuse boxes i could show you what you'd need to do.
Old 01-14-07, 12:06 PM
dinh626
dinh626's Avatar
i'll try and get them.... anyone else have any input?
Old 01-14-07, 12:31 PM
PureDrifter
BahHumBug
just take a pic of the stickers on the inside of the fuse box lids. i think i can find the actual wiring diagrams somewhere.
Old 01-14-07, 12:39 PM
Lexkost
Lexkost's Avatar
Here's a simple way ,I turned mine into DLR's buy running the wires to the heated seat fuse under hood. ( I don't have heated seats but fuse is there )
...So this means lights come on when ignition is turned on.
I have 2nd Gen but same can be done for 1st Gen.
Old 01-14-07, 10:34 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
All you have to do is find the foglight relay. Should be one of a few in the drivers kick panel. Then you have to run a wire from the switch on the stalk, and 2 for power source, and 1 hooked up to the parking light fuse so you can operate fogs with the parking lights.
Old 01-15-07, 11:12 AM
dinh626
dinh626's Avatar
I get the general idea but I kind of need a tutuorial with pictures to follow along.
I've done the mod before on a acura integra, but it was easy cause i just popped the switch out and and rewired it to the rear defrost switch right next to it...
I'll try to get the pic of the fuse box up .
Old 01-16-07, 08:46 AM
lorenzo816
lorenzo816's Avatar
Default I was looking for this myself
I was just talking about this.
Here is some pdfs of the wiring.
relayloc.pdf
fogusa.pdf
Is this what you need?
Old 01-16-07, 01:32 PM
dinh626
dinh626's Avatar
thanks lorenzo I think that's what puredrifter needed...so what do i do?
Old 01-16-07, 09:34 PM
PureDrifter
BahHumBug
ok, basically it seems that you can follow this tut for the 95-97 LS400
https://www.clublexus.com/forums/sho...d.php?t=144434
but use this diagram instead of the one given.
wire number 2 is the one youl want to rewire to a 12v source. probably an ign. 12V is ur best bet, so it isnt on all the time.
Old 01-16-07, 09:43 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I'd connect it to the parking light fuse, so that you dont have to turn them on, and off everytime you enter and exit the car. Have them come on with the parking lights. I found that to be much easier. THats how I have them on my LS, and now on the GS. You can easily change that last part around... if you want to do ignition, then use the wipers fuse.
Old 01-17-07, 08:11 AM
dinh626
dinh626's Avatar
is there any way to have the fogs so they can still be turned on and off with the switch on the stalk, but only with ignition on.
Old 01-17-07, 08:32 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Have you been reading this thread???
Old 01-17-07, 09:25 AM
dinh626
dinh626's Avatar
yea i just figured it out, just interpreted it wrong. Thought that the fogs would come on with the ignition but with the lost of control with the switch. Thanks guys.
Old 01-17-07, 01:45 PM
Big Steve
Big Steve's Avatar
so for this foglight mod, to my understanding. i'll have to pull the relay out, make an extension, and connect 1,3, and 4 back to the fuse box area, and run #2 to a 12v source such as the parking light fuse? just wanted to double check what my thoughts were. i've been wanting to do this to my UCF21 but don't quite understand the directions. any help would be great.
Quick Reply: Fog light Mod for UCF10???
