After 3 years finaly got my 19" '92 LS400
Old 01-04-07, 09:39 AM
VicFerrari
VicFerrari's Avatar
Default After 3 years finaly got my 19" '92 LS400
well its been a long time since i said that i wanted new rims, just every time it came down to getting rims my tires were shot and i had to get new tires, cause i could not discide on rims, and then just wait next time they go bald again. so to the rims break down, they are:
Venti v56 19" 8.5
Falken 235/35/19
now next of cousre i got to lower it i am thinking about the tanabe, i already changed the shocks about a year ago to kyb shocks, the only thing is i really do not want to roll the fenders and mess up the paint or try messing with factors like that. But would the springs make the camber go in just a bit so if people sat in the back or hitting bumps not make the tire and car touch each other?
thanks
Old 01-04-07, 11:05 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I cant see the pics.
Old 01-04-07, 11:23 AM
KilaWombat
KilaWombat's Avatar
I can not see the pictures either.
Old 01-04-07, 11:30 AM
VicFerrari
VicFerrari's Avatar
sorry about that
Old 01-04-07, 11:31 AM
VicFerrari
VicFerrari's Avatar
side of car
Old 01-04-07, 11:33 AM
RA40
Super Moderator
RA40's Avatar
When you lower and spec the alignment, you can have them dial in some -. You will then be on that treadmill of flipping and replacing tires. -1 is pretty mild but tires vary so it may or may not wear that quickly. Shaving the fender in combination with some mild negative camber is your likely choice.
Old 01-04-07, 04:54 PM
VicFerrari
VicFerrari's Avatar
what color do you guy suggest to paint the caliper i was thinking black just cuase i do not want to see those iron rust spots but i photoshoped them red and that looks good too can not discide. plus is it super easy to do it yourself or better to drop it off.
Old 01-04-07, 07:09 PM
Mobstar
Mobstar's Avatar
Very Clean.
If you do sit any lower,
That'll look ****ing great.
GJ
Old 01-04-07, 08:34 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
ehh, id do black since the 1LS calipers are tiny.
now if u do a 2LS bbk conversion then paint them w/e color u want.
Old 01-05-07, 11:26 PM
LS_4Will
LS_4Will's Avatar
I think it will tuck in if you lower it but it might rub a little so I would take that rubber lining off and roll the fender. I rolled my fenders with a copper pipe (baseball bat method) and the paint was fine...but that doesn't mean yours won't. you can just take a hammer and hit the inner fender up a little so the tire won't rub. You don't have to roll it all the way if you don't want that much stress on the paint
Old 01-06-07, 12:08 AM
VicFerrari
VicFerrari's Avatar
i guess they will be the only option, i have seen websites showing how to roll the fenders and looks like they use a heat gun to soften the metal and paint,LS_4WILL btw what springs do you have?
and any one with 234/35/19-8.5 tires on a 1gen LS400 what did you have to do when you lowered it? the springs you used? and rubbing issues this peole in the back seat or speed bumps?
thanks
Old 01-06-07, 12:30 AM
LS_4Will
LS_4Will's Avatar
I have air suspension and have lowered the car to the ground numerous times. For you, I think you should get 4 of your fattest friends and load up the trunk to see what the car would look like lowered and to see if the wheels will rub. =D
Old 01-06-07, 06:34 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
I agree, with a drop it'll look so much better
Old 01-06-07, 12:32 PM
Suneet
Suneet's Avatar
A drop will absolutely help, I can see a lot of potential Dang, lots of recent activity on this forum! A lot of new first gens! Can you post those other 2 pictures of your car that are x'ed out?
Old 01-06-07, 12:51 PM
VicFerrari
VicFerrari's Avatar
the two other pics that i posted were the others x'ed out ones.
btw my tail light have got a tint with a clear coat over it but it is starting to fade so i have to redo it, last time i used rubbing alcohal to get it off, question is what is the best way to sand off or just get back to the original plastic so i can redo it?
thanks
jay-b
07-12-11 08:45 AM
a#'z
Wheels and Tires Classifieds
13
06-25-10 08:40 PM
01gs3
02-10-07 03:15 PM
kel3
IS - 1st Gen (2001-2005)
02-18-02 10:02 AM
Quick Reply: After 3 years finaly got my 19" '92 LS400
