1990 LS400 sluggish start off problem
Old Jan 10, 2007 | 02:04 PM
PlutoBHG's Avatar
PlutoBHG
Unhappy 1990 LS400 sluggish start off problem
Hello everyone,
I was driving one day and all the sudden my engine started grumbling and slowed down like crazy, i had to give it lots of gas just to get from 0-10 and the exhaust smelled like fuel really bad, my first guess was bad spark plugs, so i replaced them and my battery. And it didnt fix the problem, it made the car start much smoother, but its still grumbling and really slow off the start and takes alot of gas to get her going. Would you guys say that it might be the spark plug wires...or what? What should my next move be?
Old Jan 10, 2007 | 03:01 PM
mobilyte's Avatar
mobilyte
may be a problem with your exhaust system. visually check your catalytic converters to see if they are glowing red hot.
Old Jan 10, 2007 | 03:09 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
yeah, sounds like clogged cats
it should be throwing CELs at you tho
edit: this is assuming that your cats are indeed glowing red-hot
Old Jan 10, 2007 | 04:37 PM
Och's Avatar
Och
Sounds like a dead ignition coil. Very common problem.
Old Jan 10, 2007 | 10:11 PM
crazimofo's Avatar
crazimofo
yup check your coils..don't be confused by a clogged catalytic converter and a bad or dead ignition coil...
when you replaced your spark plugs, how was the condition of the wiring? and did you check your distributor caps and rotors?
Old Jan 11, 2007 | 12:47 PM
Salil022's Avatar
Salil022
i had the same problem with the car, i replaced the spark plugs, wires, caps and distributor and problem was still there. Cats were glowing red hot, so i figured its the cats, so i went ahead and replaced the cats and problem still there, no i spent $1000 all together and same problem, now my mechanic tells me that it needs a valve job, don't know who to believe at this point.
Old Jan 13, 2007 | 01:51 PM
PlutoBHG's Avatar
PlutoBHG
dang, the wires were not stripped and no exposed metal, but that doesnt rule out the chance that one could have opened up inside somewhere
the distributor and other problems would give me a bad problem with starting the car up wouldnt it? it starts beautifully right now....i will check the cats and if it doesnt look hot i will bring it in for the bad news i guess hehe
thanks for all the suggestions guys
Old Jan 13, 2007 | 06:14 PM
crazimofo's Avatar
crazimofo
check your ignition coils before doing anything drastic....get a multimeter and check your resistance..
let me know what you get...
Old Jan 14, 2007 | 11:00 PM
HKSC430's Avatar
HKSC430
Default possible power steering fluid leak
maybe power steering fluid in the manifold?
due to problem with the power steering idle up valve...
(or even other fluids- e.g. motor oil)
in any case, it will foul up the spark plugs over time,
causing imperfect combustion and poor fuel economy...
Old Jan 16, 2007 | 06:38 AM
EastWind's Avatar
EastWind
How do you do this?
Old Jan 17, 2007 | 07:43 AM
Lexushead's Avatar
Lexushead
Read here
https://www.clublexus.com/forums/sho...d.php?t=254089
and here
https://www.clublexus.com/forums/sho...d.php?t=252211
bambam1666
Aug 27, 2012 06:51 PM
josephgary
20
Jul 9, 2012 08:55 PM
Liguid
Aug 6, 2008 09:25 AM
UofACATS
12
Jul 20, 2008 09:25 AM
96ls400ky
12
May 24, 2008 07:25 PM
