is it ok to use 10w-40?
Old Apr 30, 2005 | 04:49 PM
blaznsc4's Avatar
blaznsc4
Default is it ok to use 10w-40?
i have a 93 sc400 with 103k. is it ok to use 10w-40 oil?
Old Apr 30, 2005 | 05:01 PM
toy4two's Avatar
toy4two
not recommended
Old Apr 30, 2005 | 05:29 PM
blaznsc4's Avatar
blaznsc4
what would happen if i do? could i use it for a car that has 133k?
Old Apr 30, 2005 | 06:51 PM
HarrierAWD's Avatar
HarrierAWD
Not recommended, but some people use heavy oil like 10w-40 to reduce oil burning. Use it only if your SC burns oil really bad and you don't want to spend the money to fix it. I'd stick with 5w-30 and just top off the oil once a month. That's what I did with my old car.
Old Apr 30, 2005 | 08:16 PM
T0ked's Avatar
T0ked
There is no problem in using 10W-40. Older engines generally need a thicker oil to maintain good compression. Also, they can protect better in very hot temps. The manual actually recommends 10W-30 for my car if you normally see temps above 100F. Now I know that's not too common, but sitting in traffic on a hot sweltering day on 5th Ave in NYC, the temp can get way above that. My Lexus dealer routinely used 10W-40 in my car during the summer months when I used to go to them during the extended warranty period. During the winter months, stick to 10W-30 or 5W-30. A heavier oil may help with slight burning when there is no indication or need for a complete overhaul. I would not go any thicker than 10W-40, however. I use it during the summer months ,July through September, here in NYC and use 10W-30 the rest of the year.. No problems.
Since 10W-40 has the same viscosity rating when cold as 10W-30, it is fine to use in our cars. Just at hotter temps, it is a bit thicker and can offer better protection. There is a reason racing oils are 15W-40 or higher although you shouldn't use something that thick in our cars unless you have a block/oil heater and are always revving like a maniac (which may actually include some on this forum!)
Old Apr 30, 2005 | 10:24 PM
blaznsc4's Avatar
blaznsc4
thanks for all the info guys. yea it gets really hot here so i'll just stick with 10w-40 for now and when winter comes around i'll switch back to 10w-30.
Old Apr 30, 2005 | 10:28 PM
nthach's Avatar
nthach
In Australia, there are people who run 15W-50 or 20W-50 in the 1UZ. Personally, for most 1UZs, i think 10W-30 is a good choice for the motor. I was thinking about using Chevron Delo 400 15W-40 diesel engine oil, just for the stronger add pack. I run 10W-30 year round, my car runs fine even during those hot Bay Area summers...
Old May 1, 2005 | 01:36 AM
T0ked's Avatar
T0ked
I actually have a couple of friends who use diesel engine oil in their Volvos for that exact same reason. I wouldn't do it in my SC, but they have been using it for several years and their cars are still pulling strong, not one problem. Australia can get pretty darn hot. I drove about 60 minutes towards Broken Arrow from Sydney in NSW and wow was it sweltering out there.
Old May 1, 2005 | 09:29 AM
Lexusfreak's Avatar
Lexusfreak
Cool
Originally Posted by toy4two
not recommended
I agree! 5W30 or 10W30 only.
Old May 4, 2005 | 06:15 AM
Losiho's Avatar
Losiho
The Australian 1UZ owners manual is pretty simple - 10w30 is the preferred viscosity. In extreme heat, 15w40 or 20w50 is suggested, or in really extreme cold (which you're unlikely to see here) 5w30. I use Mobil 1 10w30.
10w40 is not listed at all.
Old May 5, 2005 | 09:43 AM
got_trd's Avatar
got_trd
I just use 10w 30 year round
Old May 5, 2005 | 04:12 PM
toy4two's Avatar
toy4two
I posted the same question in the Toyota MR2 forum since I accidently put it in, a chemical engineer told me its not a good idea due to the additives or something Oil companies do not have to add to 10W-40. Not to mention it will void the engine warranty... take it with a grain of salt though.
Old May 5, 2005 | 04:27 PM
hyperopt's Avatar
hyperopt
There are pros and cons to each of those popular motor oil weights and there is no magic weight that works best in all conditions, so pick a weight that you reason would work best.
Old May 5, 2005 | 06:20 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
Short answer. yes.
All depends on the climate really. Here in CA, i run 20w50 in my SS. I run 15W40 in my M3 (both of which call for 5w30....)
jrk1956
Jun 4, 2019 05:32 AM
pwrusr
May 11, 2012 04:08 PM
NyCrAzY
RX - 1st Gen (1999-2003)
Mar 28, 2012 09:31 AM
dundfaukus
GS - 1st Gen (1993-1997)
May 24, 2005 12:43 AM
T0ked
Maintenance
Jan 7, 2003 04:57 PM
