120K miles service.... have a list ready to go
I'm ready to do a 120K major tune up. I've done the service on my 93sc400 at around 60K. I was wondering if I need anything else? I've compiled a list below. I would like change any and all fluids and hoses. If you guys can come up with anything else, let me know. I'd rather do it all at once. Thanks!
DESCRIPTION Quantity
(All items for 1UZFE...UZZ30)
ELEMENT SUB-ASSY, AIR CLEANER FILTER 1
FILTER, FUEL (FOR EFI) 1
CAP SUB-ASSY, DISTRIBUTOR 2
ROTOR SUB-ASSY, DISTRIBUTOR 2
CORD SET, COIL AND SPARK, W/ RESISTIVE 1
BELT, TIMING 1
IDLER SUB-ASSY, TIMING BELT, NO. 1 1
IDLER SUB-ASSY, TIMING BELT, NO. 2 1
*** 1993 SC400 Water Pump
*** 1993 SC400 Cam Seals
*** 1993 SC400 Crank Seals
*** 1993 SC400 Serpentine Belt & Tensioner
*** 1993 SC400 Thermostat
*** 1 GALLON Toyota RED Engine coolant.
*** is the Idler and Crank pully already order in above?????
*** how much to replace ALL hoses in the engine bay? Includes upper and lower radiator hoses... etc. Etc.
BELT, TIMING 1
thanks for the info LexusFreak...
Joshthorsc, yes, torque master spark plugs
I already have the toyota type IV tranny fluid sitting at home as well. That's for the tranny flush.
anything else? I'd rather do everything now, i don't care what it is, since I'm already paying a set rate for installation.
Just went thru this myself
Not on your list & the first part to actually fail on me was the 16307-50011 Bracket Support for Fan. That bearing inside this piece totally failed at just shy of 170,000!
I don't see a TB tensioner? There are 2 idler pulleys & a tensioner.
I don't see any front cover gaskets on your list. They to tend to get brittle.
I went ahead and changed all the bearings on parts that spin along with the serpentine belt. You are short one pulley here.
Alternator Parts
90099-10192 Front Alt. Bearing
90099-10194 Rear Alt. Bearing
27370-75060 Brush & Holder
Since I went a little extra mileage before service & I was going to be in there anyway I replaced my fan clutch w a Hayden aftermarket unit. Basically, if it spins out front of my 1UZFE it got replaced.
Plugs. I used NGK, but who am I to preach.
This was my "bible".
http://www.lexls.com/tutorials/engine/timingbelt.html
good luck, damon 94 LS
Alternator Parts
Alternator Parts
Alternator Parts
When you order the front cover gaskets at the dealer, do you just say "front cover gaskets?"
I need a tune up too! So how much is the alternator parts listed above? I never knew we had to change those....
Also, how much is that bracket for the support fan? Im assuming you have a SC400 too? I gotta call Carson Toyota soon.
You by no means have to do the alternator parts. I was worried about the condition of mine due to some odd electrical occurences. The brush & holder were in bad shape, so I'm glad it got serviced.
Front Cover Gaskets
11319-50010
11329-50010
11346-50010
11347-50010 2 Total
11357-50010
These are 94 LS 400 #'s , but I guess it is the same for your SC. Fan bracket is expensive! $180.00 or so.
Front Cover Gaskets
11319-50010
11329-50010
11346-50010
11347-50010 2 Total
11357-50010
