- 2000 RX300 Spark Plugs and Valve Cover Gaskets?
- Solo P1351 - New Owner
- I have a code P1663
- Alarm going off every time I open door, and can't program remote
- Lexus 350 Rx 2012 will not start.
- Possible iacv issue or vacuum leak??
- Multiple RX300 Electrical Gremlins
- PS1130 & PS1135 for RX300 yr 2001
- what type of hitch do we have on the 2001 RX300?
- 01 RX300 AWD rough idle on 'D'
- A/C Leaking Freon
- How to sell car.
- Just bought my first 99 rx300
- headlights
- Passenger door will not lock with key fob or manually (Lexus 2003 RX300)
- CD goes to radio
- Scary MPG numbers. Help needed
- cam end play
- 1999 rx300 door lock/windows
- Radio/CD/Cassette looks right but is silent!? (99 RX300)
- Replacement door lock actuators
- Should I purchase?
- RX300 mechanical issues
- Gas tank cap
- 2000 RX300 Gen 3 Rear Valve Cover
- Shifter won't go into Park
- Fuel Brand
- 99 RX300 not starting/issues
- DENSO IGNITION COILS - Interchangeable compatible ?
- Engine
- mr
- Electric motor/code question
- Rear Middle Brake Light Removal Help
- Parasitic drain in my 1999 RX
- Rx 300 burning serious oil
- 99 RX300 Lost RMPs while driving, now car cranks but no start
- Looking at 2003 for daily driver
- RX 300 - Loses Power & 3 codes
- RX 300 shift issues
- Possible CD Changer Swap from 2000 GS to 2000 RX??
- Allow Me to Reintroduce Myself
- OEM radiator or aftermarket radiator reliabilty
- RX eats a/c compressors
- Code P0171
- is it the starter??
- necessary to clean fuel injectors?
- Seized lug nuts
- Need rims
- Cost for timing belts, oil, etc. ??
- My 2002 rx300 is throwing multiple codes
- Repairing differential
- E-Brake and Throttle Cable Question
- Does the passenger side bottom seat fit the driver's side bottom seat?
- Replaced dogbone to stop low end vibration-only partial fix
- Screwed spark plugs too tight
- P0303 code
- Where to buy black mat for bottom console drawer
- JDM Transmission Conversion
- Replacing Timing Belt & W.P., Thermostat, Power Steering on 2000 RX300?
- rx300 p1351
- Sat Nav unit for RX300 Gen 1
- Trying to add an Aux cord thru CD
- Wheels
- 2003 rx300 abs mtr relay slot empty
- headlight fender gasket seal
- Strange Alternator/Battery Drain?
- Can't buy right rear parking brake cable
- 2001 RX300 journey is over - what to do with a wreck?
- 1999 RX 300 VVT problem
- Rx300 codes po171
- Anybody retrofit newer tail-lights?
- Oil leak question
- ac clicking noise
- Air Flow Sensors/VVT Solenoids/Catalytic Converter
- Modifying windshield wiper controls
- Where to find cars parting out
- rear struts
- Open door light, no temp guage, windows
- After all these years, do you still like your RX 300 ?
- How to remove infotainment section of the car?
- Weathertech owners, help please?
- Damaged wheel rims from working on car
- 2002 RX 300 p 1730 HELP !!!!!!
- Why does Lexus use cr@ppy transmission??
- Clips or Fasteners under Hood
- Side mirrors wont dim or brigten up
- My lexus has a pull to the side
- 2000 RX300 - P1354 but Only 2 Cylinders Misfiring (P0304 / P0306)
- Checking for a bent rim
- Whining/Howling Noise at Specific Speed
- Diagnosing my Cel P0420
- 202,500+ miles... worth fixing these problems?
- P1135 fix questions - a recap?
- RX 300 2003 New shape 1st Gen?
- Upgraded My Wheels To 2010 RX350's
- Need help with; Ignition Cylinder Removal,
- need help with wiring
- 2003 rx300 vacuum line
- VSC and ABS blinking fast
- Gas Station Fuel Pump Problems
- 2003 rx 300 check engine code P0766
- Double din kit for my 2002 RX300
- CV Joint
- 99RX300 Transmission won't come out of PARK
- 2001 RX300 Rear hatch door won't open
- Trail of issues
- No start
- 01 ATF mesh Filter Q
- Who has the lowest and highest mileage on their RX 300 ?
- Where to buy WeatherTech for RX300
- Dual Throttle Bore Dimension
- How do I get a duplicate window sticker
- 3mz swap into a 2001
- How frequent does the PCV need to be replaced?
- Oil leak
- Glenn Merriweather
- Time to do my suspension
- ? re: sway bar end links
- ENGINE IS (most likely) TOAST
- Michelin Premiere LTX
- 2001 RX300 All three brake lights out
- RX300 Phone Holder ?
- Radio screen.
- Transmission dead on 140 000km.
- how many miles and how has the RX held up?
- power brake bleeders?
- Million mile dream? Pipe dream?
- code
- Pulling Fuse to Prevent Starting
- Best Wishes .. Happy Holidays
- Buying 00 RX 300 - What are your thoughts on this service history?
- Should I get 1st gen or 2nd gen?
- Trans failure, shady mechanic, should I scrap my RX?
- Radio Antenna Signal Booster
- Looking for DIY on fuel injectors
- Sounds like a diesel
- Instrument Cluster Panel Light Bulb Sizes
- p1354 Oil Control Valve - Where to Order?
- 99 RX 300 knock sensor
- Headlight Removal 1999 RX - How to?
- 2015 es wheels on 1G RX?
- Photo DIY: "Window Stuck/Stutter" CR2-12V Relay Replacement
- Need to paint roof rack cross-bars
- RX 300 power steering help
- goodbye to the first gen
- Replacing the backlight dashboard LEXUS RX300
- How do I remove driver's seat?
- Never leave your car home with your wife :)
- Trailer wiring
- Low RPM
- Portable jump starter
- Brand New Key
- transfer case mounting holes not lining up
- So i got these LED headlight kit...awsome!!!!
- Rat Ate Wire Near Coils HELP
- 2000 RX 300 repair - suggestions please
- best option for bluetooth and aux?
- BIG suspension problem
- Can I use spacers on my downstream 02 sensor?
- A little help please!
- Engine mount or transmission mount
- Coolant Thermostat replacement DIY
- Buying Used RX300
- I just saved $200 !
- '03 RX300 Slow Cranking
- Fuel Injector ticking noise
- P1155... (i searched)
- Strut Bearings Binding?
- Forum members- Be more supportive!
- 2001 RX300 - Missing-not shifting
- P0171 Code on 00 RX300, repetitive issues / Limp Mode
- Time to say goodbye to rx
- Is there direct "Transmission ECU" with Codes?
- Ability to change door unlock sequence at home?!
- Valve cover update with pics inside
- Approximately how many gallons are in the gas tank when the fuel light is on?
- How does fuel pump and fuel filter work in a RX300?
- Wood Steering Wheel
- Poll- Is your RX300 an OIL-SUCKER?
- AC Gurgle on Low
- Another oil sucker fixed!!! Valve cover ID
- Part identification help
- RX300 Electrical Connector List
- Power outlet on dash not working
- Very bad week
- E brake won't release on RX300 1999
- Confused about obd2. Please Help!
- Rear Antenna Motor
- 99 factory installed taillight converter for tow trailer lights
- CD changer and AC problem at the same time
- 1999 rx 300
- P0420, need to know what the culprit is. I need your help
- A/C fixed but still a problem
- rear passenger door lock issue
- ABS - Please HELP?
- KYB shocks with OE mounts
- Strange. Clock off by 10 hours/week
- Codes PO303 and P1310 timing belt replace
- Strange Transmission Issue
- Decided to take a peek @ BANK 2 plugs
- Nut on harmonic balancer
- My 2002 Rx 300 European spec does not have this
- 6 month/600 mile engine oil change
- RX450 wheels on an RX300. Is this possible?
- Engine jerking when it's hot
- Another transmission burned issue and temporary fix
- Understanding Bank 1 vs Bank 2 trim/volt readings
- Rx 300
- Doors do not lock
- Troubleshooting noise in New-to-us '03 RX300
- 26L/100km help needed. 2002 rx 300
- RX300 2000 how many pins cd changer plug
- Electrical problems
- Need to get alignment and other related things?
- New spark plug wires and mpg
- 99 RX300 rear differential help
- VSC Light & Beeping - no codes
- Chasing a fuel consuming ghost
- P0446 CEL code
- trans oil cooler radiator rx300 2001
- No car light flash after pressing unlock the second time
- Ashtray Bulb
- Power antenna grind
- Weird Idling
- Abs lock out. Gear shift stuck in park
- WeatherTech FloorLiner for RX300
- Air Conditioner Noise
- Fan speed module location?
- Changing Rear Valve Cover - What other work should I do?
- Fuse Box location and Fuse for Display location?
- Transmission help!
- Installing Satellite Radio/Bluetooth
- Sell or Keep?
- P0440 & p0442 cel
- ABS sensor A
- click clack noise - bypass the Air mode servo?
- RX300 will take jump start, dies when remove jumper cables
- Transmission issue
- Rear Bearing replacement ABS ring
- RX-300 Steering Wheel remains Locked w/ Enging running!
- Won't come out of park.
- How to remove the right rear window switch of Rx300, 2002 model.
- Trans issue again but different ? Please help
- Best Hidden Antenna
- OEM Parts Online
- RX consuming 1.5 quarter oil in 1000 miles
- All brake lights are out
- What ignition coils do you guys get?
- Friend wants to sell me 2001 RX300
- Stuck Ignition Coil Cylinder #3
