Radio Antenna Signal Booster
I have a 2001 Lexus RX with a stock OEM antenna mast. The thing is, I got tired of replacing the antenna mast every time I accidentally break it from backing into a tree branch (I forget to turn off radio before backing up, and the antenna mast is at a blind spot), so I bought a new antenna mast, left it unretracted, and removed the power to the motor. So now my radio antenna signal is weak. I can only hear some radio local stations, but some gets static-ee when I drive under the bridge/overpass.
Does antenna signal booster help me get better reception? I'm looking to buy this:
http://www.ebay.com/itm/HD-RX8-RADIO...QAAOSwEetV-nNC
I'm kind of confused by the fix. You were tired of breaking masts, so you put in a new mast and made it non-retractable?
My car has an OEM antenna mast. I left it unretracted by removing the wire that powers the motor. So the antenna sits inside the car, and none of it is exposed (just the tip of it of course).
Extended the antenna is almost 3' long. Retracted it is about 7" and encased in the metal car body. It might be a bit better than not having an antenna.
A window antenna might be an alternative if you don't want a mast. The car already has one of those, in the left rear window.
My nylon cable snapped, so I unplugged the motor. Half up, I get decent signal on most stations, just a bit quiet. Anything less than half, lots of static and some stations don't even come in. You can't boost what you don't have. The mast is hollow, so it's pretty weak getting signal as is.
Someone here swapped theirs for a stubby antenna had a decent luck. There's a DIY in the sticky, take a look there.
b2884987
12-14-16 02:36 PM
1995LS400
12-04-07 06:43 AM
