cam end play
Old Apr 3, 2017 | 09:15 AM
bearhawk's Avatar
bearhawk
Default cam end play
I am doing another 90K cam belt replacement. This is the second time I've done this but this time I replaced the water pump and pulleys as well. In reassembling I find the stick out of the front cam is 1/8" shorter than the rear cam. This prevents the cam pulley from seating against the face of the cam due to the backing plate which causes the back of the cam pulley to drag against the belt backing plate. What happened and how to I remove it?
Old Apr 3, 2017 | 09:25 AM
salimshah's Avatar
salimshah
25 Year Member
You stated. replacing the pulleys ... do you mean actual pulleys or just the seal. Your issue can be the seal not fitted properly or the actual pulley being wrong [that is if you have replaced the pulley].
If by pulley, you meant idlers ,,, then reinvestigate the seating of the seals.
Salim
Old Apr 3, 2017 | 10:07 AM
bearhawk's Avatar
bearhawk
You are correct, I am just replacing the idlers. I haven't done anything with seals in the head and the seals on the back of the backing plates are still good. The backing plate sits tight to the head so that is not the problem. The problem is the cam juts out of the head seal 1/8" farther on the rear cam than the front one.
Old Apr 3, 2017 | 10:13 AM
bearhawk's Avatar
bearhawk
Disregard this thread, I just discovered that the pulleys are not installed the same way. The front pulley has the lip toward the engine while the rear pulley has the lip facing out. Don't know how I missed that.
Old Apr 3, 2017 | 11:21 AM
salimshah's Avatar
salimshah
25 Year Member
If you are doing 180K miles service, do replace the cam seals.
Salim
Mlkbj05
Apr 29, 2019 07:28 AM
Arcturus
Aug 1, 2018 07:41 AM
Equalizir
Mar 26, 2017 11:31 AM
davincity
Dec 28, 2013 01:09 AM
mackintosh
Mar 29, 2011 03:00 AM
