RX300 mechanical issues
Old Mar 30, 2017 | 10:25 AM
lacpn05's Avatar
lacpn05
Default RX300 mechanical issues
Purchased off of Craigslist. Previous owners obviously never maintained the car at all. Have sunk in a couple of thousand dollars so far. It's still needs struts, and I'm sure a transmission down the line. Now whenever I turn the steering wheel it squeaks. Mechanic says might be a problem within the steering column. I like this model a lot and I'm hoping it was just neglect that has created such issues. Should I take a chance and get another one? Maybe get the next model the 330? It has a little over 145,000 miles on it. I wonder if I should just put it back on Craigslist and see what happens. Any advice from RX300 owners?
Old Mar 30, 2017 | 10:40 AM
maxSteel's Avatar
maxSteel
I don't know why you would do this. The sum of the parts costs more than the car is worth,
My (unhelpful) advice is don't buy a car that hasn't been maintained unless it is drive-able and the plan is to drive it as-is until it dies, hopefully where you can get a cab. I've driven some butt ugly cars that I got for free, put in maybe a battery and some plugs, and drove for months. I would never have put major work into them unless they were classics of some sort.
Old Mar 30, 2017 | 11:00 AM
salimshah's Avatar
salimshah
25 Year Member
Not sure how to respond.
The squeak we hear is typically is at the cabin exit point. Small shot of silicone lube fixes it.
I have 1/4 million miles and have no issues .. so I cant say if your transmission will go bad or not.
Only good suggestion I would make is try to evaluate your purchase first.
Salim
Old Apr 1, 2017 | 02:09 PM
lacpn05's Avatar
lacpn05
Well I took it to a well known recommended mechanic to look it over before I bought it. He said it needed brakes, a water pump and a radiator. That was IT. Then once I purchased the car all this other stuff came up. Found a much better mechanic who was stunned that the first one missed so much. It needed an o-ring, all the spark plugs, and the fuel lines were leaking. Had that all fixed. Then this new mechanic said watch your fluids. Your transmission fluid was low. *sigh*. So not worth keeping? I LOVE this model car. I am hoping they aren't all bad.
popeyerx
May 9, 2017 09:05 AM
chenxingha
15
Apr 21, 2017 05:05 AM
LarsLexus
Dec 10, 2011 01:05 PM
Flyrockies
Dec 6, 2005 10:05 PM
whatuusay1
May 28, 2004 12:19 AM
