View Full Version : Maintenance
- so cal service contact - glendale?
- proper warm up
- shake
- 95 with r-134 ac
- iridium plugs - NGK or DENSO?
- Weird sporadic shift hesitation in '97 LS4???
- wont restart straight away
- How many miles past 90K did you go before changing the timing belt?
- ****HeLP*** Anyone know where can i get steering rack bushings???
- Engine codes
- Major Tuneup or Fix Leaking A/C?
- Rubber Preserver/protectant
- NAV reset for maintenance.
- A/C stop workin in 95 degree weather (HELP!!)
- Distilled vs Purified Water
- 92 SC400 Washer fluid not working
- Best place to buy..
- How many miles for changing differential fluid?
- Transmission shifting too late
- something wrong with my engine
- double post
- How often should I change my oil?
- Alternator issues and a/c.
- New Oil Approved by Lexus
- Starting issues; starter or fuel?
- Norm Height Light ?
- HELP with ES
- rear a/c does not work
- Engine Gelling
- Lowered IS300 help
- changing fuel filter? how?
- What is the Best dino oil to use?
- 93 gs300 coolant flush?
- Active traction control system failure.
- Torque Values
- Mcgard Wheel Lock Key Set
- What's the deal with the Water Pump?
- What is involved in a tune up for the SC300
- gas flooding, runs rich, stalls
- 90 LS400 brake rotor question
- Buying from one dealer service at another?
- Switch or Regulator? (window)
- Synthetic oil to Regular oil?
- spark plugs
- 1995 ES300 monroe quick strut
- Adding Freon
- Dealership Programming Changes for ECTs?
- Front O2 sensor Replacement for 98 GS?
- costco gas
- what is the best product i can use to clean out my fuel system?
- Where do you bring your car for service when it's out of warranty
- lexus link
- '99 GS300 engine vibrations, popping sounds, VSC and CEL, hesitation, & lack of power
- 98 ES 300 trouble
- Fluids galore
- Steering Rack Surprise
- Huh? $195 just to change the spark plugs?
- Please read and post the YEAR AND MODEL OF YOUR CAR.
- what does it mean when the 1st shift is very jerky?
- Dead light dimmer
- does the sc300 need premium gas?
- i think i figured out my 2jzge fuel mpg secret
- where to buy T-IV trans fluid?
- 02 IS300 SportCross Lift/Jack points?
- Needle on engine temp. gauge taking a long time to reach mid-line
- * How do I remove Front is300 windows*
- screw in tire
- Power Window Motor?
- What to check on 'new' high-miles, well-maitained 1994 ES300
- looking for lexus corp. extended warranty
- Hope to figure out this antifreeze thing once and for all!
- Something burnt out.... Lighting
- Starter called it quits on my '98 LS
- Avoid Multi Prong Spark Plugs
- Where can I dispose of fluids (other than oil)?
- Oil and Filter change on LS430
- Sealed or Servicable struts? '94 ES300
- Replacing the AC Filter
- Timing belt, when and how much?
- How do I know if my starter is gone?
- Lexus Diagostic Tester
- Are these easy enough for a DIY ?
- Sea Foam mates :)
- I need help...HID's won't shut off
- High milage motor oils...?
- Emmisions experts- 98'ES smog help
- High vibration in my gs300/98 need help ?
- Gapping - Pre-gapped Sparkplug?
- Replacing serpentine belt...
- OBDII readers
- Increase MPG
- SC300 passenger seat problems
- SO i had an OIL change today and i have questions
- Torque not converting?
- Windscreen replacement: factory or aftermarket?
- Lexus-parts website down?
- quick question
- GS400 Maintenance - What / Where? Help Please...
- High mileage + Seafoam?
- Mechanic in Western Michigan
- Am i getting ripped off?
- Good mechanic shop in Columbus Ohio?
- Engine Light Indicator On
- Switching back to Conventional Motor Oil???
- Please help me locate the cabin air filter!!
- Power windows and door locks
- Cracked 2 coil packs removing plugs
- Brake fluid amount
- 93 ls 400 suspension
- show your pics of your skanky a/c cabin filters!
- sc400 power steering hose needed
- Redline Water Wetter
- Part numbers
- oil changes
- Key and Trunk Mat
- Choosing the Right windsheild wipers??
- GS ECU (Body ECU)
- ball joint change. price?
- '93 LS400 Cooling System Problem
- Trunk release
- 60K Service Cost
- Final step in getting to cam seals.. 250lbstq not enough
- how to repair polyurethane bumpers?
- Tighting struts
- Anyone ever use a oil extractor ?
- SC400 Stalls
- steering wheel won't unlock?
- Battery died and the radio stopped working. Help please!
- obd2 readers and cables
- Smoking Catalytic Converter
- Help changing front brakes 95 LS400
- Need a replacement spoiler LED for 1997 SC3
- 30K service GX470 Costs?
- signal light help
- Neld Help! SC300 needs new transmission?
- emissions issue
- video of seafoam treatment
- parking sensor
- Defective wheel bearing
- Ebay Tune Up Kit
- Lexus parts prices that are inflated
- LS 430 Oil changes
- Need help with electrical problems!!
- 75k service
- Replacing Bearings in the Idle Control Valve
- Help! Re-circulate not working
- Power Steering Pump Needed.....
- Security System
- 99 GS 400; 60k SERVICE
- added a few more DIYs on my webpage
- steering
- removing ignition key cylinder? (pics inside) Need Help
- check engine light help
- Gs 400 control arms
- 94 LS400 Instrument Panel Lights
- Repair quotes
- Lubro Moly oil & engine flush
- Service light
- Hot Shot
- Should I get a tune-up?
- 1997 ls400 cracked head lense
- Problem starting due to gas being low?
- Brake Bleeding with Hand Pump System
- weird starting problem
- 5-tire rotation with full-size spare
- RX 300 break problem. HELP SOON PLEASE
- IS250 and IS350 oil change
- tip on did 120k get done or not
- Help again guys! Overheating.......
- Rubbing Noise Help
- RX 330 Drivetrain backlash
- My baby won't start
- i dont know ANYTHING ABOUT CARS BUT...
- 1990 LS 400 water pump/timing belt/ tune up
- Toyota Sludge Nightmare Forum
- Crank/Cam pulleys
- My car hates me - weird electrical problem...
- Diff fluid light golden color at 220K miles....
- Unknown light on????
- Cleaning Fouled Plugs
- Maintance logs and record keeping
- Transmission Failure, Again
- What is this guys???
- Quick maintenance ?s
- Crooks
- power window problem!
- **Need help! Parts for starter install..........
- Long term Storage
- LS4 TB specifics
- key is stuck,need help rx 300
- Door Problems and Unidentifible Beeping
- my SC eats gas like an animal, any suggestions?
- ATF power flush?
- 2001 gs3 brake fluid ????
- Replacing Fuel Filter Question
- Abs , Vsc , Vsc Off
- Help! Traction control? Transmission?
- SRS Warning Light
- Brake question (non lexus).
- 02 ES 300 Plug Removal
- Heated seat - Not Working - Maybe never
- General Maintenance before a long trip?
- Engine Oil
- Repetitive transmission failures on 1993 ES300
- 2000 LX470 Tranny Fill Location
- ES 300 Starting Problems
- How long are TSB good for?
- Steering problem on curve recovery
- Harmonic Balancer Es300
- A-arm Bushings???!!!!
- RX 300 AC compressor is making noise HELP
- Quick quesiton about oil amount in 02 GS300
- heatshield buzz?
- Car seat covers
- New Timing and Serpentine Belt
- Windows weather strip Winter Care
- es300 rear suspension
- how easy is it to change brake pads on LS430
- RX 330 pulls right
- ES 2000 footbrake light on?
- help one vent blowing cold air
- Radio unlock code
- Seafoam
- Do you remember the first piece of "maintenance work" you did?
- Newbie questions
- Head gasket repair for chrismas
- Oil Change...piece of cake!
- LMS How much to make me a s/c for my 98 gs400?
- My 2-Ton Hydraulic Floor Jack is acting up. Anyone know the fix....?
- Tutorial to replace belt tensioner assy. on my '99 GS300?
- ***1998 GS300 suspension noise**
- Help with Maintenance Code
- 94 ES 300 Exhaust noise
- HELP - Tapping Sound (Valves???)
- Help... SC's acting up
- Lexus Parts 1994 LS400
- did i mess this up?
- Toyota Oil Filter 90915-YZZD1 $5.89
- Preference for service visits?
- Do I have a transmission problem??
- ABS light on, Can't get out of park HELP!!
- why's my floor soaking wet ???
- ES300 O2 Sensor
- Engine hose rupture, need assistance
- Question about P0420
- Need '93 SC300 Traction Control bleeding proceedures
- is wheel bearing repack nec??
- Looking for trim removal tools
- 90 k c/u what is important???
