High mileage + Seafoam?
I was planning on doing a seafoam treatment on my '95 SC300 w/ 184,000 miles on it. It's never been done on it before and I was wondering if it'd be dangerous at all.. for example, a big *** piece of carbon buildup comes loose and all hell breaks loose.
Originally Posted by JspecSC3
I did it to my 93 SC300 which has over 245k miles on the motor. I pulled out the EGR's vacuum hose and I let her have it. I think it should be safe for you. Just do sips at a time and keep your RPMs at midrange.
Originally Posted by LocknRoll
dont wanna thread jack, but hows your car running with 245k on the motor? i love to hear about how these otors last so long.
they're just cool like that
and jspec, thanks for the info. did you notice a big difference after doing it? i'll do it once it gets nicer out, its been too damn cold in ohio.
There has been one negative report of hundreds on seafoam use. That was from an suv owner than sucked an entire pint of seafoam up at one time & hydrolocked his engine. Idiot...
Carbon doesn't come in chunks. It's a thin layer than can wipe off with about any solvent if wiped hard enough. It's not going to fly out & kill anything.
Find my post on Seafoam in the ES forum & refference that. If you put it in your intake a couple of times, expect better throttle transision. If you flush your oil with (anything) expect a noticeably smoother idle.
That's how you apply it.
If you're still skeptical, find my old ToyotaNation threads on Seafoam & Seafoam in general & count the dozen<s> of people that went nuts over it once it started steam rolling.
thanks for all the info, i did my first seafoam treatment for my sc300 earlier tonight, was a lot more simple than i had even thought. i probably should've put in more through the brake booster. it smoked for about 3-4 minutes then after a drive around it all stopped, i changed the oil and that was the end of it. i only felt a small difference, idle feels a little better, but it seems like a good bang for the buck procedure. i think i'm gonna keep doing it before each oil change. it cant do any harm, right?
my only complaint was it was smoking so much after i had started my car back up that when i backed out and turned backwards out of the garage i forgot there was a giant ****ing yellow pole there and scraped my front bumper!.. i'm gonna try to buff it out tomorrow though. i feel like a moron now. =/
