Should I get a tune-up?
Old Jan 25, 2006 | 01:11 PM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Default Should I get a tune-up?
Currently I can get about 21 mpg on a good week. The car is very sluggish though. My best 1/4 has been 16.4 with some mods. The car has about 250k on it now. I've had it since 216ish. Its had a recent timing belt change and I've changed all the fluids. What should I do to make it back to factory specs? And where is that DIY of changin the plugs on the 2jz? I cant find it anywhere.
Old Jan 25, 2006 | 01:15 PM
VJ RC51's Avatar
VJ RC51
21mpg is very good! I wouldnt mess with that!
Old Jan 25, 2006 | 10:34 PM
exarus's Avatar
exarus
How do you drive your SC? I accelerate pretty gradually, rarely blasting off the line, and I get 25-26 mpg. 97' SC300 68k miles.
Old Jan 25, 2006 | 10:40 PM
RaynArt's Avatar
RaynArt
now i feel bad. im avg'ing out 17-18mpg 95% city driving.
1995 sc300
135k miles
Old Jan 26, 2006 | 08:09 AM
DryBlaze's Avatar
DryBlaze
1995 sc300
135k miles
I get about the same but im 95% highway driving. My car is a 92 SC3 with 116k miles.
Old Jan 26, 2006 | 10:46 AM
VJ RC51's Avatar
VJ RC51
I average 85mph on the local highways and not very hard acceleration at stop lights.. 21ish mpg with the 1jzgte. If i go 65-70 on the highway, i can get better.
Old Jan 26, 2006 | 11:32 AM
ATL-SC's Avatar
ATL-SC
i get 18.6 around town and 26-27 on the highway, 25 w/o cruise controle
Old Jan 26, 2006 | 11:53 AM
lexsc492's Avatar
lexsc492
what exactly is involved in a tune up
Old Jan 26, 2006 | 12:07 PM
indypwr's Avatar
indypwr
changing plugs is not very easy to do. you will need to take out the upper plenum to
get access to nbrs 3, 4 and 5 plugs.
Old Jan 26, 2006 | 02:13 PM
RaynArt's Avatar
RaynArt
clean your throttle body while your at it since thatll come off anyway.
plugs, wires, rotor/cap, timing belt, w. pump, serpentine belt, and i think thats it? thats all the stuff i changed when i did my tune up. and tightened up the throttle cable a bit.
edit: i just notice you drive a 400, im guessing its easier to change plugs on it and not sure exactly where the throttle body is.
Old Jan 26, 2006 | 02:47 PM
lexsc492's Avatar
lexsc492
rotor/cap= is that the disrtibuter?
what is the cost around to get a tune-up... myself or mechanic?
Old Jan 26, 2006 | 03:57 PM
RaynArt's Avatar
RaynArt
roughly 340? about in parts. could be a little more since i remember buying misc parts/access. i didn't really need but since i was buying car parts anyway labor was $60 and a pizza since i knew the guys.
Old Jan 26, 2006 | 08:51 PM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Thanks for jackin my thread
Anyways does anyone have the writeup?
Old Jan 28, 2006 | 09:31 AM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Also, does anyone know if I can use the same caps, rotors, wires, and plugs on a 1jz?
Old Feb 1, 2006 | 10:28 AM
dean s's Avatar
dean s
remember you'll need 2 dist.caps on a sc4 , and get a good set of wires.I've heard through some threads here that it is quite common to get a bad wire in the set exp. with the cheaper plug wires.
