Are these easy enough for a DIY ?
Old Mar 27, 2006 | 11:06 AM
OceanView's Avatar
OceanView
Default Are these easy enough for a DIY ?
Just got my car back from the Stealer.
Spend $1200 on stuff I didn't think I needed to replace.
Now they are recommending that I have additional work done.
Valve Cover Gasket - Leaking - $520
Front Lower Control Arm Bushings Cracked - $995
Are these items that I can do with limited mechanical skills or should I just find a good Indy?
This is for a 98 ES300.
Thanks in Advance.
Old Mar 27, 2006 | 01:20 PM
muldrick's Avatar
muldrick
Thanks in Advance.
"Limited skills"???, no, but you take it to another shop and maybe get it done cheaper. But those prices aren't to awful bad. Lower control arm bushings...the intire control gets replaced on that. Valve cover gaskets...the intake plenum must come off.
Old Mar 27, 2006 | 01:27 PM
Tammy's Avatar
Tammy
You're leaking oil and causing excessive wear on the tires. The steering may seem loose.
Suggest you check the condiction of the PCV valve plugged into a rubber grommet located at the passenger side, rear valve cover; that is closest to the firewall.. a failing or clogged valve would allow pressure to build up and blow oil out the valve cover seal or gasket.. If in doubt, the PCV valve replacement is reasonable. Get one at a Toyota dealer. The oil leak might stop, if your lucky and it hasn't been leaking long.
Locate in your area through yellow pages, the internet and word of mouth a good Toyota Repair facility...
Toyota dealer could provide a quality repair at a better price, ordering Lexus parts if different than the Camry.
mandyfig
Nov 5, 2019 01:09 PM
Shazim
Apr 6, 2018 04:39 PM
wpm66
Oct 14, 2013 05:23 AM
evenparr24
Sep 30, 2011 05:07 PM
joodafoo
Jan 22, 2009 05:13 PM
